I flipped a coin to decide if I should post this here or under General,Mig-Tig-Stick or projects and decided the park might catch attention of some who've ran across this before. 20 horsepower Kubota,B1750HST to be exact has 4 out of 8 bolt holes coupling bellhousing to engine snapped off. At the time I bought it I figured replacing bellhousing is no big deal. After checking on replacement bellhousing it turns out to be a common issue which pratically makes non-damaged used part non-existent with new being scarce and really pricy. My plan is to weld tabs to bellhousing to replace those missing. Browsing Kubota forms turned up a couple of people with good solutions to prevent reoccurrence but nothing on a work around without replacing bellhousing. I removed the front loader and brought it home but tractor isn't here yet where I can determine type metal (cast or stamped). Judging by rust,definatly not aluminum or same material as cars. Kubota mfgr's support doesn't reach beyond marketing new tractors and although dealers are abundant, I haven't found one that can give clue to type metal used. I realize until I can say cast iron or not,welders can't offer meaningful advice but my question is whether I should attempt to identify alloy beyond whether it is ferrous and if cast? I can use the time before tractor arrives at my shop to try and locate documentation of type alloy unless waiting to do a grind test is all that's recommended. Applogize for bringing a pig in a poke but i thought I might luck out and find someone that already been down this road. Drawing on years experience keeping domestic built farm tractors in operation my contribution to the masses is advice to check part lists for prices and shop manuals for proceedures before investing in a tractor built in foreign countries. Looking at shop manual for the first time I couldn't believe the number of fiddly-bit parts used in single components and clearances that must be maintained.
