HF bead roller modifications do I want any deflection?
Results 1 to 25 of 27
    Dec 2005
    arlington va
    well I had the same problem as everyone else with the HF bead roller way too much deflection of the arms which I measured at 7/16 of an inch when flanging 18 gauge steel. so i beefed mine up using scraps i had lying around the garage. the question i have before i finish all the welds is do i want any deflection in the two arms? currently i have less then 1/16 of an inch in deflection when i tried flanging the 18 gauge steel after the mods. i can easily add some more webbing at the end where the crank is between the angle iron but before i make this too rigid is any deflection useful? thks bob
    bobs77vet/37ford4dr
    HH190
    Lincoln Invertec 155s
    Lincoln weldpak 100
    sears/craftsman (lincoln) 50a 240v buzz box
    O/A rig Harris gauges
    nexion cut 50 dx
    chicago electric (HF) 240v spot welder
    Nov 2007
    Re: HF bead roller modifications do I want any deflection?
    heavy duty, i like what this guy did with his
    Dec 2005
    arlington va
    that is a great looking unit...i was surprised that my deflection that was most obvious was from side to side and not up and down.
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Jun 2011
    Oregon
    By the way You don't want any deflection Mac
    Dec 2005
    arlington va
    perfect, thanks Mac. I will beef up the end down by the crank and stiffen that up some more. thks bob
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Apr 2009
    What about adding a second short piece of square tube right beside the first one?
    Dec 2005
    arlington va
    Quote Originally Posted by wayne55 View Post
    i think that is exactly what i am going to do. i will space it toward the crank handle end so i can weld the bottom to the original 3/8 frame.
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Dec 2005
    arlington va
    done and i added a spline in between the two for some more rigidity. i flanged some 16 gauge and there was no noticable deflection so we are definitely under 1/16" for sure.
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Oct 2010
    western kentucky
    good job, I need to start thinking about a bead roller myself..
    Sep 2006
    The side to side deflection is just as bad as the up and down. If you move the rollers side to side the istance between the contact points increases and you lose pressure just the same as if they separate in the vertical plane. No deflection is what you are shooting for.
    Cut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:
    Part 1
    http://forum.britishv8.org/read.php?13,7581
    Part 2
    http://forum.britishv8.org/read.php?13,22422
    Jul 2011
    Utah
    Ive used that same roller. I had to clamp a square tube brace across the throat because the side to side deflection was way too much when doing 18ga mandrel tubing. Easy enough to fix by getting some 3"x1/4" flatbar and bending it into a U and welding it on to the middle of the flat area.
    Dec 2009
    Stevens Point, WI
    I have that same roller. I added 1/4x2" bar to the backside of the roller, standing on end and welded full length. It helped allot but I still had problems trying to use the roller to bead the tubes I was working on. Then one day I built my own roller to do what I need it to do.
    Apr 2009
    Looks good. I think I have the same bead roller, but I have not added the modification yet as I really have not used it. I need to get on it though. Nice pictures.
    Dec 2005
    arlington va
    well tested out the bead roller.with the mods i made ...and the sheet metal break i made with input from you guys...on my latest project a 1958 MGA coupe. it was our first bead rolls and if i had to do it again i would make my lines offset so that i lined them up with the outside of the die, it was too hard to get them lined up in the middle of the die. i think would also make a "stop" so that the every successive roll stopped at the same same place. and i would have them all end so that it didnt interfere with the angle iron hold down on the break.
    ....we cut out the rest of the floor to give a nice unified look
    made a template out of carboard
    cut it out and made template for bead roller
    rolled the beads in the floor
    bent the sides
    and heres the mock up fit
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Dec 2005
    arlington va
    seems right to add this here also
    a little diversion.....i have some sheet metal parts to make for the MGA coupe and since little joe went back to college i need another set of hands....or a motor
    heres the install materials: mometary foot switch, dayton gear motor which spins at 2.8 RPM, reversible drum switch, and a vintage crank for creating tension, jaw coupling from McMaster Carr
    the old business end a 25mm shaft on the crank
    an already beefed up HF bead roller which doesnt deflect
    the mock up using a hose clamp to keep everything together and lined up
    wiring
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Dec 2005
    arlington va
    "power in" is the power cord white and black
    mocking it up to weld
    cut out of 1/8" sheet steel
    the offset was just where ever it landed but it is parallel to the bead roller
    drum switch mounted
    test run to make sure everything works right
    it works perfectly tomorrow it gets disassembled and painted then the final wiring.
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Dec 2009
    Stevens Point, WI
    Now we're going to need a video!
    Pensacola , Fla
    Here is a bead roller I built instead of modifying one from HF
    have fun
    Tom
    DIY CNC Plasma table & CandCNC DTHC-IV MP 3100 Feather Touch option
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Dec 2005
    arlington va
    Tom thats nice work !
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Dec 2009
    Stevens Point, WI
    Great videos Tom! Very nice machine you built there, I like the quick release very much! Thanks for sharing!
    Dec 2005
    arlington va
    finished up the mock up and painted it.
    cuts 18 really easily
    16 ga was a little more labored nut it still did it but was nt an issue
    heres the motor information
    final wiring
    final reassembly tonight
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Apr 2009
    Looks very nice. I'm up with you except for the motor.
    Dec 2005
    arlington va
    Wayne i am excited about the motor.... it will make it a one man operation
    DONE!!!!! now to make some more MGA parts
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
    Feb 2013
    I was wondering if there is much difference between the harbor freight bead roller compared to the Woodward bead bender. The Woodward bead roller says that there body is 1/2 thick and someone here said they measured the harbor freight body at 3/8 thick. I wonder if the Woodward has as much of a deflection problem or is it really the same bead roller? Can anyone answer this question for me.
    Dec 2005
    arlington va
    Quote Originally Posted by goldfinger View Post
    I dont know the size of the woodward roller but 3/8" thick sounds right for the HF. as a standard to look at in my photos, my angle iron braces are 3/16 and the sheet steel for the motor was 1/8, i know this since i scraped the 3/16" label off this past weekend when i painted it and i measured the steel plate for the motor . my original HF bead roller had both deflection up and down as well as forward and backwards. if the wood ward is 1/2" then the up down defelction would be certainly reduced but the forward/backward I imagine would still be some what of an issue. when people beef these up they always do it in both directions. I cheated by making a triangle out of the angle iron. now remember this all catches up with you when you go to pick it up....
    bobs77vet/37ford4dr
    HH190
    Lincoln weldpak 100
    nexion cut 50 dx
