Siphon suction sand head
Results 1 to 10 of 10
    Brethren, Mi
    I will show 3 shots. first is assembled. The hose on the left goes in the sand bucket and pushes down to about an inch from the end of the conduit,, or so,, and lets a little air in along the top around the hose and allows some mixing of air and sand at the pickup point. I crimp the conduit just enough to allow some movement to adjust if needed but firm enough to keep it in place.
    Brethren, Mi
    This is just a little closer view, the body is a 1/2 pipe T
    Brethren, Mi
    Here are the parts, from left to right. 1/4 pipe nipple, 1/4 to 1/2 reducing bushing, 1/2 T, then small air old air chuck into a 1/4 to 1/2 red bush with it tapped backwards a little with 1/4 pipe thread so the chuck can screw in reverse, then a 1/4 nipple screwed to a valve to turn air on and off or regulate if needed and finally the air chuck I use. I laid the parts on the floor aprox the depth it all needs to be screwed together. This thing also works well with just the hose to vaccuum out fuel tanks too without having to remove them. Like an old tractor, I used it the other day to clean a tank on a welding machine. Sucked the old fuel out and vaccumed the water and dirt out. I shined a flashlight down in and dragged the suction hose around in the tank. Sometimes you an pick up dirt or water without having to take all the fuel out. It was cheap and took about 10 mins to build.
    Oct 2003
    Birmingham Al
    i think i probably have all of those parts in my junk bin, lol
    Stangnet
    Shop Full Of Stuff.
    Joey
    Mar 2004
    Central Texas
    Utter simplicity - and the KISS principle is still the best...
    Get it hot and hit it hard...
    Feb 2004
    England
    We had a bigger version of that - made from 2" pipe fittings - to suck fumes out when welding inside tanks and containers. The company Health and Safety man wanted them buy one, (for quite a lot of money).
    We kicked around the shop for fittings and found enough to make one of our own, worked brilliantly, but was as noisy as hell!
    I'm not very clever,
    But I can lift heavy things.
    May 2004
    Richmond/Midlothian,VA
    Simplicity at its best, I think I could even make one of those? Hey Hollis, you are everwhere tonight?
    Bruce
    The Welding Chef
    Lincoln Weld-Pack 3200
    NORWELD Stick
    Stanford Hill Farm
    Mar 2004
    Central Texas
    Bruce,
    Looks like we have the same interests on all subjects. Do you shoot black powder muzzleloaders also?
    May 2004
    OT, Muzzle Loading
    No shooters in the family, I qualified while on active duty,68-76. Went deer hunting when I was a kid, but didn't care for it, too young to drink bourbon then I guess? Now give me a feeshing pole & I'm happy!
    I am practicing my bead with the mig, getting better, now I'm going to attempt using a plasma cutter!
    How's everything on the home front?
    Bruce
    The Welding Chef
    NORWELD Stick
    Stanford Hill Farm
    Jul 2005
    PO, Spain
    A simply and nice tool. I'll try to build one for me.
