Copper plus electrodes?
Results 1 to 7 of 7
    Mar 2012
    calgary
    What's the deal with these? Do they help nozzle life or just the electrode? Recomended for just mechanized or hand cutting too?
    Thanks.
    Millermatic 252 w/spoolmate 200
    Miller 250 Dialarc
    Lincoln 180 mig pak
    Lincoln mig pak 100
    Hypertherm Powermax 65
    Precision Plasma Patriot 4x8 CNC table
    Everlast 250ex TIG
    Oxy-acet rig
    10"x18" Modern Bandsaw
    Modern 14x40 Lathe
    Sep 2012
    Bellingham, Wa.
    Re: Copper plus electrodes?
    Nozzel life on a Hypertherm or any plasma is a function of clean air and if you are draging the nozzzle on the the plate or using a standoff. If HYP says it will increase life then believe it.
    Oct 2007
    New Hampshire
    Copper plus electrodes are a recently developed electrode manufacturing technology that dramtically improves electrode life....these electrodes are available for the Powermax65, 85 and 105, as well as for any earlier Hypertherm system that has been upraded with the Duramax torch. They work for hand cutting and for machine cutting on materials up to 1/2" thick....at power levels between 40 and 105 amps. Above 1/2" thickness..it is recommended to use the standard electrodes.
    Electrode life in most cases with the new copper plus is more than double the (already industry leading) life of the standard Hypertherm electrode. The copper plus...due to a more difficult manufacturing process...is a bit more expensive to purchase, but is far cheaper to use as it lasts so much longer. Nozzle life, assuming you are using proper cutting techiques...will be improved as well.
    Link for more info: http://www.hypertherm.com/en/Product...de_upgrade.jsp
    Jim Colt
    Quote Originally Posted by P-J View Post
    Thanks.
    Mar 2012
    calgary
    sounds reasonable to me, I will try some out.
    Miller 250 Dialarc
    Lincoln 180 mig pak
    Lincoln mig pak 100
    Everlast 250ex TIG
    Oxy-acet rig
    Modern 14x40 Lathe
    Mar 2012
    calgary
    Just to satisfy the engineer in me, why the limit at 1/2" material thickness? Thanks Jim, I ordered 40 of these and look forward to using them all up
    Miller 250 Dialarc
    Lincoln 180 mig pak
    Lincoln mig pak 100
    Everlast 250ex TIG
    Oxy-acet rig
    Modern 14x40 Lathe
    Oct 2007
    New Hampshire
    If you look at the consumable choices for Hypertherm's Industrial plasma systems....you will see a different electrode for every power level. There is a 30 , 80, 130, 200, 260 and 400 amp electrode just for cutting steel. That is because to optimize the thermal efficiency (best combination of life and cut quality) you have to designe the electrodes with different heat transfer capabilities for different killowatt cutting capacities.
    The new electrode has similar characteristics....it is a new design using proprietary manufacturing techniques that optimize it for the killowatt rating required on materials 1/2" and under. On 1/2" and above...the new electrode has performance and life similar to the standard electrode.....it cost a little more so there is nor advantage when only cutting thicker materials.
    Jim Colt
    Mar 2012
    calgary
    The reason I love hypertherm. Thanks Jim, I'll put these to good use, 90% of my cutting is 3/8" or less so i couldn't ask for a better product.
    Miller 250 Dialarc
    Lincoln 180 mig pak
    Lincoln mig pak 100
    Everlast 250ex TIG
    Oxy-acet rig
    Modern 14x40 Lathe
