DANGER using BrakeCleaner to clean your Parts
Results 1 to 25 of 27
    Nov 2012
    Stuttgart Germany
    Using brake cleaner and the effects when welding with argon?
    What happened was a friend of mine was doin some Alu welding,(was oil on the stuff) he used brake cleaner to clean it,
    and just before welding sprayed on a little more, waited abit,
    welded about 4 in. and fell over.
    His wife called me, after the amb. was there,I figured he got shocked.
    hospital called and said he had a (name i cant pronounce)
    poisoning.
    Anyway it comes from when you mix a heated chemical
    (thats in brake cleaner) with argon, the chems in brake cleaner turn to gas and mix with the argon,
    IT IS DEADLY
    He died today from it.
    ( Ive done it too with the brake cleaner) and i dont think i am the only 1
    NOT ANYMORE
    I dont wanna go in that kinda way, I think the gas chamber would be better.
    WE dont need to lose people who are in our field of work like that.
    Take care. And remember, you get paid for pretty welds,But are they worth your life?
    Frank
    Sep 2012
    Bitburg Germany
    Re: DANGER using BrakeCleaner to clean your Parts
    Very sorry to hear about your friend.
    The chemical it produces is called Phosgene. It was used as a chemical weapon in WW1. Very nasty stuff. The same chemical can be produced with welding and alot of other cleaners. It's the chlorine that does it. For welding I stick with acetone.
    Feb 2008
    North of Philly
    Sorry to hear about your friend also.
    The dangers of brake cleaner as a prep has been covered here several times, but it's always good to bring the subject up again as needed so this won't happen to others. Just a few of the many threads to cover Phosgene and brake cleaner..
    http://weldingweb.com/showthread.php?t=57472
    http://weldingweb.com/showthread.php?t=37201
    http://weldingweb.com/showthread.php?t=32501
    http://weldingweb.com/showthread.php?t=33421
    Ronald Reagan
    Feb 2009
    Chicago
    I didn't think brake cleaner had chlorine in it in anymore, but I'll still never use anything other than acetone.
    Sorry for your loss!
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Feb 2012
    el paso, texas
    Sorry for you loss!!!!!!!!
    Sep 2006
    NJ, USA
    Frank,
    Es tut mir leid zu hören, dass Ihr Freund tot ist.
    The deadly chemical was probably "phosgene".
    http://en.wikipedia.org/wiki/Phosgene
    The intense UV radiation from arc welding can cause a chemical reaction with some chlorinated chemicals (such as some spray brake cleaners), most likely or commonly containing 1-1-1-trichloroethane
    http://en.wikipedia.org/wiki/1,1,1-Trichloroethane
    or possibly dichloromethane
    http://en.wikipedia.org/wiki/Dichloromethane
    The argon gas really has nothing to do with phosgene formation via UV radiation on the chlorinated solvent, and neither does heat (temperatures hotter than ~200C actually cause phosgene to break down into carbon monoxide and chlorine, neither of which are good for the body and which are both toxic but not to the degree that phosgene is).
    The chlorinated brake-cleaner sprays around here are being phased out and now they mostly seem to be other solvent or solvent blends (most common that I now see and use is pretty much acetone in a spray can, works OK but not quite as well as the tri-chlor solvent).
    You still have to be careful with ANY cleaning solvent, as most are still flammable and/or dangerous.
    Ventilation and being aware of the dangers/risks from the solvent(s) you are using is impostant. Read the label!!!!
    If using solvents and welding, make sure that ALL of the solvent has evaporated before you weld.
    Be aware of solvent vapors, and also of solvent-soaked rags (IIRC, 'our' Zap had an issue with an acetone-soaked rag. At least once. )
    Again, sorry to hear about your friend.
    Be safe and be careful.
    Sep 2012
    Bitburg Germany
    Quote Originally Posted by MoonRise View Post
    Forget the label get the MSDS. If ...chlor... is anywhere on there do not use it. If you can't find the MSDS, DO NOT USE IT!
    Sep 2011
    Iowa
    Sorry, man that really sucks.. Prayers for everyone involved..God Bless
    Feb 2012
    The Netherlands
    I'm sorry to hear this... My condolances...
    I use thinner when mig-welding steel and let it evaporate well, is this safe? Just took this thread as a wake up call...
    Sep 2012
    Bitburg Germany
    Quote Originally Posted by CulinaireZaken View Post
    Find the MSDS for the specific brand of chemical you are using. If you see phosgene, cholrine, chlorinated or any other form of chlor, don't use it. Failure to do so is risking your health/life.
    Mar 2004
    I am a skeptic.... 4 inches of weld? Sick yes. lethal I doubt. WW1 vets took a lot more and survived.
    May 2010
    Sparks, NV
    Quote Originally Posted by lotechman View Post
    Why don't you test it out and let us know if u die or not. 6 parts per million of phosgene gas can be fatal.
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Feb 2012
    ny
    WOW, very sad story, and very sorry for your friend.
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
    Feb 2012
    The Netherlands
    Quote Originally Posted by Snuffy View Post
    Thanx.
    Feb 2010
    Northern MN
    I got a shot of the chlorinated stuff one day, Phosgene isnt the only problem, chlorine gas can also form. It was a scary experience, one Im not willing to repeat. Felt like crap for several days, all I could smell was chlorine, dark urine, Not good at all.
    Feb 2011
    Near Dallas, TX
    Umm.. just to be clear, our breathing zone monitors in the wafer fab would alarm at 25 parts per billion of Arsine or Phosphine gas.
    Yes, it takes very little to kill you. WF6, aka Tungsten Hexafluoride is another real nasty gas.
    Look on an MSDS for the IDLH value of Phosgene. That stands for Immediate Danger to Life and Health, or as my buddy used to say, it's the "I Don't Like it Here" threshold.
    Papa
    Lincoln Idealarc 250 (circa 1962)
    Lincoln Weldpak 155 w/Mig Kit
    Lincoln Squarewave TIG 175
    Aug 2007
    Sacramento, Calif
    A couple guys here got it right. I've been 100% DEAF for 21 years due to about 5 minutes of TIG welding around some Chlorinated solvent. 1-1-1 Trichlorethane. The UV in welding arc converts that into Phosgene, a very strong vervous system 'irritant', quite deadly. Military in WW1 called it Mustard gas, ever heard of that?
    Dougspair
    Mar 2012
    New Britain, CT
    Sorry to hear about your friend.
    This is why there are no chlorinated solvents anywhere in the shop I wok for, or at my house. If the label doesn't say "Non Chlorinated" on it don't take the chance. One giveaway that a solvent has chlorine in it is the "Non Flamable" label.
    It's all non chlorinated solvents and final clean with acetone for me.
    What creates Tungsten Hexafluoride?
    Jan 2010
    Seagrove N.C.
    I'm sorry for your loss. But thank you for telling the story, I read the older story that was posted on here some time ago about the other guy that got poisoned from it. And I have told so many guys the story that iv'e welded with about the danger of the brake cleaner and they didn't even know and some of them have actually used brake cleaner before welding something.
    Miller Bobcat 250
    Westinghouse ac arc welder
    Its better to be hated for who you are than liked for who your not.
    Feb 2011
    Near Dallas, TX
    Quote Originally Posted by Alex22 View Post
    It's an industrial gas mixture used in making semiconductor devices.
    Sep 2006
    NJ, USA
    Quote Originally Posted by dougspair View Post
    Just an FYI, "mustard gas" and "phosgene" are NOT the same thing.
    Both are dangerous, both are toxic, both were used in WW1.
    But they are not the same chemical.
    Phosgene = COCl2 (or CCl2O) Damages the internal protein structure of the lungs primarily, which results in impaired or no oxygen trasfer and then suffocation. In the "choking agent" group of chemical weapons.
    The 'typical' odor detection threshold of phosgene is 0.4 ppm, which is ~4x greater than the 'safe' Threshold Limit Value. If you can smell the phosgene (described as a grassy or hay-like smell), then you greatly exceeded the 'safe' exposure limit. ie: You're probably toast.
    Mustard gas = C4H8Cl2S Causes delayed (on the order of 24 hr after exposure) nasty, painful chemical burns and blisters, and long-term mutagenic and carcinogenic action. In the "blister-agent" group of chemical weapons. Smell described as mustard or garlic-like, from the sulfur in the molecule.
    http://en.wikipedia.org/wiki/Mustard_gas
    http://en.wikipedia.org/wiki/Chemica...on_designation
    Jan 2006
    All chlorinated solvents will break down into dangerous chemicals when heated not just brake clean. In fact very few brake clean products are chlorinated. But, the easiest way to tell is if it says flammable on the can it's safe to use. Chlorinated solvents will not burn. Electric motor cleaners and solvents meant to work on energized equipment will be the chlorinated type. Key words to look for on the label are perchloroethylene, trichlorethylene, and tetrachlorethylene. Most refrigerants will also break down into similar chemicals when heated as will fire fighting agents intended to interrupt chemical chain reaction such as Halon.
    And yeah, .4 ppm is 4x greater the exposure limit but that's the safe limit for continuous exposure. When chlorinated solvents break down they give off hydrochloric acid which burns your lungs. It's very uncomfortable to be around (I have been exposed). But, you immediately want to move away because of the discomfort so your exposure is not continuous. The biggest trouble with chlorinated solvents is that they persist a lot longer than other types. You can clean a part with brake clean and weld on it 5 minutes later and there will still be some residue. It also lingers in low lying areas so if you are cleaning switchgear in an enclosed space make sure it is well ventilated before performing hot work even though it is no flammable.
    Nov 2012
    Stuttgart Germany
    Hi yall,
    Been along time since I was in here,Work work work........
    My friends wife said Thanks to all the People in here for there kind words.
    Funny thing over here is they dont put on the cans whats inside.
    German Enginiering....
    Acetone from now on yall
    Thanks again
    Frank
    Oct 2007
    Hendersonville, Tn.
    Yep, all the ruckus about chlorinated compounds breaking down to yield Phosgene gas as a by product are true.
    Some other possibly obscure (in the modern day) stuff that we had to deal with back in my youth were Carbon Tetrachloride...usually just called "carbon tet" slangily.
    This stuff was widely used as a dry cleaning solvent and de-greaser. It was also famously (and unbelievably) used as a FIRE EXTINGUISHER fluid marketed under the name of "Pyrene".
    Another class of products we had to be careful of was the Freons (such as R12 and R22 for example).
    I have heard tales of people discharging those refrigerants from air conditioner systems in a close space while smoking a cigarette and keeling over on the spot.
    Such is the potency of Phosgene.
    Thanks to all for helping to raise the awareness of the dangers of using these compounds.
    Dec 2012
    Denison TX
    Something else you guys should know.
    Burning refrigerants aka freon makes phosegene gas too. It will kill you.
    So becareful when working around any kind of refrigeration equipment.
