Home made tools! - Page 18
Page 18 of 38 FirstFirst ... 8161718192028 ... LastLast
Results 426 to 450 of 946
  1. #426
    Jun 2004
    NE Oregon
    Re: Home made tools!
    Probably my favorite project. A friend has an antique table that uses a slotted wedge to hold the legs on. He was missing one. I think my copy turned out pretty well. Done on an old Jet mill/drill, out of steel.
  2. #427
    Utah
    Awesome dupe!
  3. #428
    Nov 2011
    Indianapolis, IN
    Made this for my porta band....
  4. #429
    Jul 2011
    North,Ga
    Those porta-band stands are very handy, especially when you can revert back to porta-band in a minute or two.
    Lincoln pro mig 180
    Lincoln Square Wave Tig 300/wp 20/home built water cooler
    Victor, Purox, Harris, O/A welding/cutting setups
    Vintage Craftsman drill press
    Vintage Craftsman/Atlas 12"x 36'' lathe
    7''x 12'' w/c band saw
    Everlast 140 st
  5. #430
    Nov 2011
    Indianapolis, IN
    Quote Originally Posted by DemonSpeeder View Post
    Definitely...take out the three screws that hold it to the the table and put the original backing plate back on but, I usually leave it on the table more than anything. I have a mock up stand to turn it into a chop saw or you can swing it up and use it as a vertical band saw but, it's still getting minor tweaks done. Will post pics after it's fully welded.
  6. #431
    Apr 2007
    Prunedale, Ca
    Realistically how well does that porta band work? i cant see why it wouldnt work bitchin.. I always need to make little brackets and tabs and gussets and such.. 1/8-1/4" or so. Ocasionally 3/8". would this work well for that??
    HTP Invertig 201
    Lincoln Idealarc SP250
    Miller 180 AC Stick
    By farmall:
    They should have held the seagull closer to the work, squeezing evenly for best deposition.
  7. #432
    Nov 2011
    Indianapolis, IN
    Quote Originally Posted by fordman View Post
    Honestly, it works well enough for me to build a stand for it. Eventually, i would like to buy a new vertical bandsaw but, since I'm in the market for a new air compressor this will have to suffice. I actually use it more than my chop saw now. If you're using the 1/2" blade that is typically on the porta bands then the blade tends to wonder a bit but, you can solve that by buying a 3/4' blade. The thickest I've cut so far has been 1" solid round stock and there was no issues at all. I have the trigger zip tied but, you can pick up a foot pedal from HF for around $20. Definitely worth it if you're not trying to do production runs and have limited space.
  8. #433
    Jun 2008
    Las Vegas,Nevada
    Made this to press bearings in on sheaves for ski lifts... Nothing special..
    SIN CITY METAL WORKS
    visit my YouTube channel
    https://www.youtube.com/user/devvon
  9. #434
    Hellinois
    Quote Originally Posted by wd40prerunner View Post
    It's very pretty. Can we get some pics of it in action?
    "Stick-man"
  10. #435
    Jun 2008
    Las Vegas,Nevada
    Ok I will when I go back to work on Monday.
  11. #436
    Jan 2010
    1000 miles from nowhere........
    I didn't realize that it snowed in Vegas......
    How many Hours a year?
    JK..
    -Rhyno
    07 Fowler 200D
    65 RedFace
    04 Miller TB 302, 22hp
    Miller 12RC
    Miller HF 251-1
    Lincoln SP135
    HyperTherm PM 380
    and a few others...
    Quote Originally Posted by Rhyno View Post
    But, if I "all of a sudden disappear.... ...." hopefully I didn't suffer too much....
  12. #437
    Jun 2008
    Las Vegas,Nevada
    JK..
    -Rhyno
    About an hour or two... Haha actually there are no lifts that are made by the manufacture that I work on in las Vegas the closest one is in California but the do have trams in las vegas that use the same rope and sheaves....
  13. #438
    Oct 2010
    Prison city Illinois
    Ok the first pic is a drill press table with a bolt through the vice. under the table I took a piece of 3/4 Pipe and welded it to a nut, and put a T handle across the end, now I can quickly hand tighten my vice with only one wrench- I got sick of wrenching the underside. Second is a swivel tray for the lathe. welded right to the stand. keeps all my tool holders and oils and wrenches ready to go.. I can swing it out of the way when I need to. The last two pics are of a quick and dirty bung wrench for plastic 55 gallon drums. I got sick of knuckle busting to get drums open at work, so a piece of aluminum for the socket and mild steel for the handle because thats what was available. Ive punched out some cheesy two pronged ones in the past but this one is dead on perfect bite. and I know, they sell these but if I spend an entire day inside with the girlfriend its equal to two off the end of my life so ya know... gotta do something out in the garage.
  14. #439
    Dec 2009
    Stevens Point, WI
    Quote Originally Posted by citizen smith View Post
    Best investment for the drill press I have found is a X-Y table. Clamp in the part then just move the table to the desired location.
  15. #440
    Oct 2010
    yeah, ive been keeping my eye out for one of them theres.
  16. #441
    Feb 2010
    New Hampshire
    Name:  11-27-2011 12-56-20 PM.jpg
    MIG, Stick, Oxy/Fuel,
    mostly one-off fabrication and repairs
    MC Road Racer
    'kit' Cobra
    2 Vista Cruisers
    '29 Ford AA Dualie dump
    "Live-Free-Or Die"
  17. #442
    Oct 2010
    yeah, the bolt grips 99 percent of the time anyways, so its barley an issue.
  18. #443
    Nov 2011
    North Idaho
    about 10bucks and a bunch of time.
    The grinder is a toolpost grinder for my lathe.
    Pic isn't working.
  19. #444
    Nov 2011
    North Idaho
    lets try this again.
  20. #445
    Nov 2011
    Melbourne Australia
    Here is a very slow speed drill press I put together from junk I already had lying around, maybe twenty years ago.
    The blue right angle reduction gearbox has 10:1 reduction.
    The purple pulley on the very top is for the ultra slow automatic feed that this drill press happened to already have.
    Big drills and very large hole saws can be used without chatter or overheating, and it can be run slow enough not to require coolant.
    Not used very often, but quite useful to have sometimes.
    Cheers, Tony.
    _________________________________
    Transmig 310 + Argoshield Light
    Oxy acetylene
    Oxy propane
    Prehistoric stick welder
  21. #446
    Athens,Louisiana
    I bought a similar contraption for $15 at an auction..
    What's the purpose of the "pink" pulley? Mine don't have that.
  22. #447
    Nov 2011
    Melbourne Australia
    Quote Originally Posted by mudbugone View Post
    On this drill press, you can engage a clutch, and the drill (or hole saw) automatically feeds down into the job without having to do it manually.
    From the top most pulley there are three stages of worm gearing to the rack on the spindle. It feeds about .003" per revolution.
    About 15 minutes to put a very large hole saw through 1" steel plate on the slowest speed, without any coolant.
    And the hole saw runs just warm, and stays sharp a very long time.
    It is slow going, but I can go away and do something else while it is working.
    Cheers, Tony.
    Oxy acetylene
    Oxy propane
  23. #448
    Athens,Louisiana
    SLICK ! Pretty cool tool. I really like it now..
  24. #449
    Jul 2011
    North,Ga
    Quote Originally Posted by fredschrom View Post
    Pic isn't working.
    Do you have a pic of the grinder set up on the lathe??
    Lincoln pro mig 180
    Everlast 140 st
  25. #450
    Jul 2011
    North,Ga
    I use my porta-band saw all the time, both on the stand when I am making small brackets etc or I can remove it from the stand and put the handle and small original cutting plate back on then I can cut just about anything up to 6x6 ( I have a dewalt, the Milwaukee has a deeper cut). I cut each side separately when I need a nice straight cut.... MUCH better than those damn abrasive chop saws.
    Lincoln pro mig 180
    Everlast 140 st
