Home made tools! - Page 2
Page 2 of 39 FirstFirst 123412 ... LastLast
Results 26 to 50 of 960
    May 2008
    Orange, TX
    Re: Home made tools!
    Quote Originally Posted by Bob Warner View Post
    I've made a few things:
    A knife with differential heat treatment:
    You guys that can build knives are awesome!
    Also a Treadle hammer
    I've seen your treddle hamer before here. That big treddle so you can switch legs when one gets tired?
    A Hydraulic Press with a treadle pedal to operate, leaving hands free to work:
    I just realized that press is in the background of your avitar. I like the hands-free feature. It appears the bed is non-adjustable - is that true? Nice unit.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2006
    Royse City, Texas (Dallas area)
    duaneb55
    I would bet anyone here, with a little reading could make a knife that is great. Heat treat is the key.
    The treadle is large to accommodate right or left handed people. I have a lot of visitors to my shop.
    The bed is not adjustable on the press. The press was made as a dedicated tool for making damascus steel for knives. The welding process is a lot faster with a press than an anvil and hammer.
    There are pictures of my damascus railroad spike knife in another thread.
    Unfortunately I need to rebuild the press, I sold it (and a bunch of other stuff) after a motorcycle accident to pay the bills, I really miss it.
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Lets see, I have made pullers, specialty sockets, punches, all kinds of stuff. My favorite was the day I cut a torch tip in 1/2 to make a "boiler tube tip" to get in to a tght spot, everyone thought I was crazy when I went to the chop saw with the torch, till it worked. All the tools I have made have saved me countless $$$ off the tool trucks and many hours of doing it the hard way.
    May 2008
    Orange, TX
    duaneb55
    I figured the press was a designated purpose item.
    I've seen the damascus railroad spike knife you're talking about. I take it 'damascus' is a term for a type of steel. Is it specific to knives?
    Sorry to hear of your misfortune with the motorcycle. Biggest bike I've been on was a 500cc Yamaha dirt bike and I'm afraid if I ever got involved with 'crotch rockets' I wouldn't be here today - or at least a lot more busted up.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  5. #30
    Nov 2007
    Bob, you are GOOD.
    I was digging through the tool boxes today looking for an air chipper and found several tools I have made that I had forgotten about. I've even forgotten what a couple of them were made to do. A couple made for a one time use were so crude I couldn' believe I made them. I won't bore you with pictures though.
  6. #31
    Sep 2005
    middle tennessee
    Nice job on the press Dewayne. I take it you can slip a larger capacity jack in there if needed too?
    Yup, and I can slip in a set of brake dies.
    Dewayne
    Dixieland Welding
    MM350P
    Lincoln 100
    Some torches
    Other misc. tools
  7. #32
    Aug 2008
    The press is built as well, if not better, than my 20 ton commercially bought press.
    Paint would do marvels
    Ever been to an estate auction on a farm? If it's not painted, it's called "shop built". Bidders walk away with it for nothin'.
    Slap a coat of paint on it, and all of a sudden it's gold
    http://www.farmersamm.com/
  8. #33
    Jul 2006
    duane,
    Damascus is basically steel folded and welded many times and it creates a pattern. In my case it is not TRUE damascus but it is universally called damascus. What I do and the other knifemakers nowdays make what is called "Pattern Welded steel" and consists of alternate layers of two or three different steels. After welding and manipulating it you make your knife and then etch in ferric chloride to bring out the pattern.
    for those that may not have seen the knife duane and I are talking about, here it is:
    Here is a gate and my headache rack:
    Oldtimer,
    I am sure that anyone here could make what I have but thanks for the compliment.
    And remember:
  9. #34
    Nov 2008
    in a dream world
    thats phenomenal.
    when i get some good pics of the rear wheel runout indicator, stepped axle tool and valve spring compressor adapter (for use on shim-under-bucjet bike motors) i'll post up.. all my pics are garbage.
    http://kawispeed.com/ -moderator and tech deluxe
    www.myspace.com/trickortrack -cuz i have no life
  10. #35
    Nov 2007
    needed to bend rebar for a job
    didnt want to spend $39.00 for a bender
  11. #36
    Jan 2008
    Arkansas
    I don't know if this will work:
    link - - http://weldingweb.com/showthread.php?t=25448
    A butterfly without wings,
    is just an ugly bug
  12. #37
    Jan 2008
    Arkansas
    Jig for tiging band saw blades
    Wire, spring or small rod bender
    pilot brg puller
    is just an ugly bug
  13. #38
    Jan 2008
    Arkansas
    [QUOTE=Bob Warner;227395]duane,
    How long does it take to make one, and how many folds?
    is just an ugly bug
  14. #39
    Nov 2006
    You guys have posted some very creative solutions.
    Sometimes the answer is just the same old tool, but used more creatively.
    For example, I needed to pull this apart, but with the limited cheap tools that were available at the job:
    Attachment 25414
    The Crescent wrench became a Crescent-puller. The 3/4 wrench became a chain de-railer. But I was still lacking a hammer...
    That's when I was offered a local specialty tool - a "Cammer."
    Attachment 25415
    Ergonomic handle, and a nice hard strike face too!
    I guess they have two popular lengths - six and eight.
  15. #40
    Nov 2008
    in a dream world
    hers some stuff i made for my bike shop.. mostly made when i was a machinist, being that the allen drives you see are courtesy of lunch break time at the company.
    they're 302 stainless.
    the gold claw lookin thing is 6061-T6511. i milled it using a CNC (in manual mode) with a 2 flute mill .500 endmill and a keyseat cutter. i needed it to be perfect, thus why i didn't do it on the bridgeport like the axle tools. runout and angular misalignment between the mating face and pointer (.250 stainless rod) is a few thousands IF that.. i got it pretty much in the ten thousandth.
    the valve tool adapter is just some 1/2" conduit (emt) that i nitched and welded washers to.
    i REFUSE to pay several hundred bucks for something i can make. you guys are the fisrt to see my creation!! i should patent.. lol
    axle tool. mainly for use on kawi crotch rockets like mine in my avatar. 17 and 21MM
    i've made 18, 19, 20 and 22MM ones as well out of 1" stainless hex bar
    my fav tool .. it looks like it's got a bow, but i assure you it's straight!! hah.. i shellmilled it square before AND after milling the pocket.
    basically, the poiter HAS to fall in between the chain's sideplates and point right at the drive sprocket.. if not, this will indicate which way the wheel is out.. it'll work on any spocket it seems (so far).. 5 series and 6 series chain (5/8 and 3/4 pitch) and 520-530 width ( 520-.252 roller width, 525-.313, 530-.375) chains all comply.
    valve compressor adapter. (ugly as hell, but very functional)
  16. #41
    Nov 2008
    in a dream world
    your typical $20. sear automotive valve compressor (impossible to use with bikes)
    now, a shim-under-bucket valve removing BEAST!!! haha!
    suzuki LT-r450 head (oh man, the things i'm doing to this motor.. it'll be REAL fast. too bad it's a customers)
    bucket on
    bucket removed. note the teeny tiny retainers
    when done right, the retainers fall right into the ipe and stay. Beautiful!!
    thats it for now.. i'm sure i'll be building more crap as i see fit.
    i'm stuck with this darn flux core mig machine at the shop.. sad, but it's better than nothing, even tho i despise flux core.
  17. #42
    Jun 2008
    The Cove
    whitehendrix I like the axle tool, i could use one for my bike! the motion pros are expensive. Very creative tools guys!
  18. #43
    Jul 2006
    Magnetic Mechanic,
    That knife has layers of steel that I then twisted to get the look you see. It took about 40 hours to make that knife, most of it was making the damascus, maybe 30 hours the rest to make the knife.
  19. #44
    May 2008
    Orange, TX
    Quote Originally Posted by ed mac View Post
    I don't blame you - neither would I. Simple, to the point and cost effective. That's what it's all about.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  20. #45
    May 2008
    Orange, TX
    Nice job on the special tools whitehendrix. I'm not into bikes but fully understand the benefit of the alignment tool you've made due to your excellent explanation of how it's used. I'm very familiar with those valve spring compressors and your adapter is a great example especially the fact that it catches the valve locks so you don't have to go chasing them. BTW - special tools don't always have to look pretty just work as intended.
    On another note - don't forget to resize your photos so they fit when displayed. Your words get cut off when you don't and it raises havoc for those on dial-up.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  21. #46
    Jan 2008
    Arkansas
    Brake bleeder
    is just an ugly bug
  22. #47
    May 2008
    Orange, TX
    Quote Originally Posted by Magnetic Mechanic View Post
    Brake bleeder
    More info please.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  23. #48
    Nov 2007
    setting up a 12x20 garage in a box from northern tool
    needed a to set the anchors
  24. #49
    Nov 2007
    3 more pics
  25. #50
    Jan 2008
    Arkansas
    More info please.
    4" pvc pipe w/2 caps
    is just an ugly bug
