Home made tools! - Page 4
Page 4 of 39 FirstFirst ... 2345614 ... LastLast
Results 76 to 100 of 960
  1. #76
    May 2008
    Orange, TX
    Re: Home made tools!
    Quote Originally Posted by Magnetic Mechanic View Post
    make sure the end of the ball is centered in the tee
    Neat little home-made eductor MM. We use slightly more refined devices for fire fighting foam proportioning.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  2. #77
    Jan 2008
    Arkansas
    Thats where i got the idea from - fire fighting school, USN Philadelphia 1965.
    A butterfly without wings,
    is just an ugly bug
  3. #78
    Dec 2008
    La Vernia, Tx
    Quote Originally Posted by littlefuzz View Post
    Here's the press I made a couple of weeks ago and I made a set of the roller stands that are to the right in the pic.
    Attachment 25191
    It is better than one bought at a store.
  4. #79
  5. #80
    Feb 2008
    Massachusetts
    6ton barrel vise / press......A few pieces of angle iron, a couple of 3/4" bolts and a cheap hydraulic jack.....BINGO!
    Action Puller.......Used to "pop" a rifle action out of the stock after epoxy bedding
    Various "Barrel Blocks" to use with barrel vise above.....
    Reloading trays to hold cartridges while reloading. Made from Air Conditioner suspended ceiling grills.
    Roy B
    Dartmouth, Ma
    http://www.rvbprecision.com
    MM 185 MIG
    Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    CM 14" Metal Band Saw
    TP Blast Cabinet
  6. #81
    Oct 2007
    Got tired of forking over ridiculous bucks for moto tire changes.
    Works good on car tires too.
    Airco 300 squarewave
    Mig welding center...
    Powcon sm300/LN 25
    Powcon sm200/PD l
    Hypertherm PM 1100
    Miller AEAD 200LE W/LN25 FC
    and now another sm200 pd l combo.
  7. #82
    Dec 2008
    Long Island, New York
    tube roller with dies cut on a wood lathe out of Delrin (have held up so far)
    my first bender - uses pro-tools dies
    new hydro bender - uses pro-tools dies
  8. #83
    Aug 2007
    Netherlands
    Great stuff.
  9. #84
    Dec 2008
    came across this thread tonight, man I am excited. I will be copying a lot of your guys stuff, this stuff is great, ideas, ingenuity, and improvising. I LOVE IT here's a few that I had laying around, they don't really compare, they are all realitivaly cheap and readily available, but when you don't have the patience to run to the tool store or wait for the snap on guy this what I have made... more to come
  10. #85
    Jul 2007
    Denmark, Zealand
    I just made this today, and its one heavy duty scratching thingy, for drawing lines on steel, i don't know the translation
    http://www.box.net/shared/i9e0hx4yin
    http://www.box.net/shared/qy3ij7i10n
    If you got money, i've got time
  11. #86
    Jan 2008
    Arkansas
    A "SCRIBE" perhaps
    is just an ugly bug
  12. #87
    Jul 2007
    Denmark, Zealand
    That must be it,
    Because if the translate the danish word directly to english it becomes "Scratching Spike"
  13. #88
    Nov 2008
    Texas Near Dallas
    Tool for standing up 2"x6" tubing used for lath. Works wonders when the entire length is a few hundred pounds and you're sitting on a 4" I-beam flange. 4" isn't really enough for a whole buttcheek.
    Dynasty200DX w/coolmate1
    MM Vintage
    ESAB miniarc161lts
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Rage3
    Jancy USA101
    9" SB
    AEAD-200LE
  14. #89
    Nov 2008
    Huntington, In
    OK!
    Here's my contribution.
    One of the tools I have made, its a bending jig, made for bending flat stock of up to 4" wide, I have used this to bend up to 1/2" thick stock, and can bend as short as 2" from one bend to another!
    I made the jig for a smaller shop press that I had, and am now converting it to be used on this monster! "The second pic"
    #1. If you don't like what I wrote, or if it offends you, then don't read it!
    #2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
  15. #90
    Nov 2008
    Huntington, In
    This is one of the bigger tools I have made!
    I am now making one even bigger.
  16. #91
    Nov 2008
    Texas Near Dallas
    Here's a "poor man's" faceplate I made for a friends wood lathe.
    I welded a nut with the threads that match his lathe spindle to a chunk of 3/4" plate. Then mounted it on a piece of all-thread, chuck it in the metal lathe, turned the plate into a circle and faced it off. I've just recently started using a metal lathe and my skills are not so good. I couldn't get a very nice finish. The facing was fair, but the outside edge kept chattering. I don't think I'm grinding my tool bits correctly (HSS). It'll be good enough for wood working.
    MM Vintage
    ESAB miniarc161lts
    Lincoln AC225
    Cutmaster 81
    IR 2475N7.5FP
    Rage3
    Jancy USA101
    9" SB
    AEAD-200LE
  17. #92
    Aug 2007
    Netherlands
    Make sure that:
    The chissel is right on centre
    The angles are right
    There's not too much freeplay in the cross slide
    Then you should be ok.
  18. #93
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Just some handy dandy dogs, they do the trick everytime.
  19. #94
    Jan 2008
    dogs handy dandy deedy dey do..very cool mon
  20. #95
    Sep 2008
    Central PA
    Toz, I like them dogs.
  21. #96
    Western PA
    Woof!
  22. #97
    Dec 2006
    nice job everyone....my problem is not enough time and too many ideas in my head
    anyone ever made a rotisserie for welding pipes with a 3 or 4 jaw lathe chuck and variable speed motor ?
    My weekend hobby -
  23. #98
    Mar 2009
    upland, ca
    this thread should be stickied
  24. #99
    Jan 2008
    Arkansas
    "this thread should be stickied"
    Define stickied please.
    is just an ugly bug
  25. #100
    Jun 2008
    Central California
    Posted by AndyA:
    I would have thought you could get a better hold on it by chucking the nut in a three-jaw, and using a live center on the back side if needed. Also, taking a light, fine cut with a nearly squared edge rather than using a more rounded tool will cut the chatter for the last cut.
    You might find that the libraries in your area have some basic machining textbooks. If not, (ours threw stuff like that away long ago; isn't PC), take a look at the reprints of old manuals and such at
    Lindsay Publications
    Lots of interesting and reasonably priced material here. Even some stuff on a new field they call 'Welding'!
