Leaf Spring Uses?
Results 1 to 17 of 17
    Dec 2008
    Blanchester, OH
    Leaf Spring Uses?
    Anybody know what I can make out of some old leaf spring steel. I hate to let it go to the scrap yard, but not sure what it would be good for.
    My Babies:
    MillerMatic 185
    Thermal Arc 300S
    Hobart StickMate AC/DC 235/160
    Dalex Werke Spot Welder
    Oh and the wife and kids are important too!
    Feb 2008
    North of Philly
    Re: Leaf Spring Uses?
    I understand they are good for knife blades. I had one for years I was going to try that with but don't know where it ended up.
    Aug 2008
    Missouri
    You can make forging or smithing tools out of them. They make excellent pritchels (punches).
    Nov 2008
    sw mo.
    I had a customer that brought me some truck springs to make him some auger teeth for his post hole digger. He swore by them, I thought they cut, drilled, and ground too easy to last in our rocks in this area.
    Nov 2008
    Huntington, In
    If you have a garden tractor and a garden, you can make a set of harrow teeth out of them, or a new pair of shoes for a snow blower or snow blade.
    in olden times, they made a good working adz out of spring steel, chisels, scrapers, knifes, the list goes on!
    #1. If you don't like what I wrote, or if it offends you, then don't read it!
    #2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
    May 2007
    SoCal
    I read they make good sword blanks.
    http://www.livesteelarmor.com/how/warsword.html
    Job 28:1,2
    Danny
    Feb 2009
    southwest
    Always made pipe wedges out of them. Had an instructor that made skinning knives out of them.
    Air vantage 500 on the 08' KW
    harris torches
    l25 pro suitcase
    comletely restored 1969 SA200 redface
    on my 08' duramax
    PIMPN AINT EASY
    Feb 2009
    Arizona
    cut a notch in a 1 1/2 " to 2" pipe and then fit the leaf spring in it and weld it. you'll have a cheap/strong prybar.
    Feb 2009
    Coquitlam BC
    Giant cross bow? Think something like a medieval ballista.
    Sep 2006
    Salem Oh
    I saw some thick ones made into boat anchors. The guy made a triangle with a short one on the bottom like a rocker of a rocking chair...Bob
    Bob Wright
    Salem, Ohio Birthplace of the Silver & Deming Drill
    http://groups.yahoo.com/group/southbend10k/
    http://groups.yahoo.com/group/sawking/
    1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
    Nov 2006
    I'll bet they'd be good for cutting scrap tires...
    Because a broken leaf will sure cut a sidewall open when it walks sideways.
    Aug 2008
    Dansville NY
    The nice long ones make a nice post for a mailbox.
    Jan 2008
    Arkansas
    Get another one and build a trailer.
    A butterfly without wings,
    is just an ugly bug
    Dec 2006
    Panama City Beach, FL
    anyone know what kind of steel leaf springs are typically made of by any chance?
    Mechanical Engineer
    Nov 2008
    Huntsville, Al
    Quote Originally Posted by BLUE2KSS View Post
    I believe it is high carbon/chromium 5160 HA spring steel.
    Back in the day we used to make wood lathe tools out of them, gouges, scrapers, skews and such. They weren't nearly as hard as HSS tool steel but they worked well and were easily sharpened do the high Carbon content.
    Mar 2004
    The material can be used for scrapers and other cleaning tools to remove spatter and slag hanging on the bottom of a bad cut.
    Dec 2006
    El Paso Tx
    How about a Helve hammer? You work with sheet metal?
