HF tools that don't suck - Page 37
Page 37 of 37 FirstFirst ... 27353637
Results 901 to 908 of 908
  1. #901
    May 2017
    Pitman PA
    Re: HF tools that don't suck
    Quote Originally Posted by ndnchf View Post
    So do you think the larger one is made better or is it just the same design on a larger scale?
    I didn't take the little one apart to see what was inside so I couldnt say for sure, but I think its basicly the same parts just smaller, all I know is it wouldn't run anymore and I heard pieces rattling around inside of it. The bigger ones last about 6 or 7 months for me and I use em pretty hard evry day. I put some pressure on the bigger ones peening the welds on this stuff. That day I tried the little one I was just cleaning slag and wasn't pushing on it, maybe I just got a bad one who knows. I figured I wasn't gonna waste any more time messing with a little one when ive got a bigger one that I know will do what I want it to do
  2. #902
    Feb 2017
    Quote Originally Posted by Popeye an old miner View Post
    Thanks - I appreciate hearing your experience with them.
    Home tinkerer and old tool junkie
  3. #903
    May 2017
    Pitman PA
    I can tell you this, they've never given me a hard time when I brought one back and last winter I brought 3 of em back in a month, they just wore out that fast. Maybe I got some that were just junk or maybe it was the cold weather, but they keep one under the counter for me. Everything Ive ever got them if it was junk they would replace or give me a refund, so they are for real in that sense. Now maybe its the particular store Im dealing with I don't know, Ive only ever been to one of their stores so I couldnt say
  4. #904
    Jan 2009
    Sonoma County
    I have the larger one, hadn't used it for a year. I had to take it completely apart and polish the moving parts before it would run. I suppose moisture in my air had made minor corrosion so the piston wouldn't slide.
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
  5. #905
    Feb 2014
    n.w. of chicago
    I try ed the little one for 20 bucks I did return one the second one did the same thing like it wasn't getting air, it was in the little pin/valve under the trigger, I think I re bent the trigger lever and unhook the air when not using for awhile, other than that it's got a lot of hours on it and I do mean alot for a 20 dollar air tool, I also took it apart and cleaned often and lubed with moly lube
  6. #906
    Laredo, Tx
    I had been using this cheap 3" extended reach cut off tool because I liked the orientation of the grinding wheel. I didn't use it as a cut-off tool since it was really lacking in power, but rather to grind out tacks or weld beads where I couldn't fit a 4˝" grinder.
    Then I saw this one last month, seemingly a copy of the Aircat 4" cut off tool:
    Pros:
    • very beefy construction, as you can tell it's not made by the "typical" Harbor freight tool manufacturers. It's heavy and solidly built, a virtual copy of the Air Cat version, including the nice trigger lock switch and push-button wheel-lock for disc changes.
    • Price is very reasonable with a 20% coupon @ $119.99 before taxes.
    • It runs very smooth, with no discernible vibration that would leave your fingers/hand numb.
    • includes a sound "muffler" integrated into the rear-venting exhaust that not only quiets it down just a smidge, but most importantly drowns out the high-pitched noise that most other smaller air tools exhibit.
    • you can even mount a 1/8" thickness grinding disc instead of the usual 1/16" and smaller cut-off wheels, to use as a light-duty grinder, as I am using.
    • It has good power for smaller cut-off/grinding jobs and does not stall out like the whimpy $40, 3" cut off tool. I would compare the power to a 4˝" air grinder of similar price/size, approx 0.7-0.9HP
    Cons:
    • it only accepts 3/8" arbor discs, so you have to make sure you can easily find the discs you need with that arbor hole size, since you can't use your typical 7/8" nor 5/8" arbor-hole discs
    • as with all air tools (not just harbor freight tools), the average air consumption listed is misleading. Aint no 4CFM gonna power this thing. It needs a good 15+ CFM as with any reasonably sized air grinder.
    • Not really a "con" but it's not super-mega-powerful to really hog out/cut thick material, but it is decently powerful if you have the airflow behind it.
    HTP Invertig 221
    HTP ProPulse 300 MIG
    HTP ProPulse 200 MIG x2
    HTP ProPulse 220 MTS
    HTP Inverarc 200 TLP
    HTP Microcut 875SC
  7. #907
    May 2018
    nevada
    I love the 14" industrial chop saw, great for the price.
    "Whether you function as welders or inspectors, the laws of physics are implacable lie-detectors. You may fool men. You will never fool the metal."
    -Lois McMaster Bujolda
    Miller AEAD-200le
    Lincoln Power Mig 140C
    Thermal Arc dragster 85
  8. #908
    Quote Originally Posted by SamC View Post
    I burned up a couple of their regular 14 inch chop saws so finally decided to buy the industrial one.... it lasted a little longer but finally toasted it too so then I picked up the dewalt... it still spins
    The other day I got some pipe wrenches as they were having a big sale at the local HF was using one of them for the first time today and noticed it has a 'USA' on it ??? so I went back to the garbage where I had just thrown the HF label barcode I ripped off it... and it says made in china as expected... now mind you it don't say 'Made in USA' cast into it but still!!! and no where in the casting does it have a 'china'.
