Show us what you welded today! - Page 395
Page 395 of 411 FirstFirst ... 295345385393394395396397405 ... LastLast
Results 9,851 to 9,875 of 10257
  1. #9851
    Nov 2018
    Re: Show us what you welded today!
    Yeah the hand rails are bolted
    Ringfeeder mount
  2. #9852
    Outside of Raleigh, NC
    Quote Originally Posted by Rustin8 View Post
    Ringfeeder mount
    Very clean fab!
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  3. #9853
    SE Saskatchewan, Canada
    A coal dust "hopper" used as part of a coal fired power plant here in Saskatchewan. The one station is in the middle of a shutdown right now so its a rush job.
    Coal dust is extremely abrasive so it's constructed of chromium carbide clad plate. They basically lay down a 1/4" layer of Chromium Carbide alloy onto a 1/4" mild steel plate. I think they do this with a sub arc and wide ribbon electrodes.
    I needed to use 3 welders for this job. One that matched the chemistry of the hard surface layer, another that matches the mild steel and a third with 309L stainless for the portion of the welds that will contact both layers.
    Left weld is mild steel final pass, the one on the right is a "root pass" of stainless. The other side will get a pass with the hard facing wire.
    Red Seal Journeyman Welder (2003), Red Seal Journeyman Metal Fabricator (2018), Welding Engineering Technologist (2005)
    Pressure - ASME Section IX
    Structural - CSA W47.1, CSA W47.2
    Transport tanker - CSA B620
    Aerospace - AWS D17.1
  4. #9854
    Very nice SaskWelder
    I was gonna ask if you welded the inside too and what with... then I read your last sentence
    Any idea what the service life on that part is???
  5. #9855
    Nov 2018
    Also very nice SaskWelder
    Coal is very abrasive .Heres a Dump truck i weld in some wear plates in for carting coal
  6. #9856
    Sep 2015
    West coast of Florida
    Quote Originally Posted by SaskWelder View Post
    Nice fab work!
    Richard
  7. #9857
    I honestly don't know about this part.
    There have been parts that were originally AR plate and were replaced every 5 years but when we build a unit made with this clad material its been over a decade.
    Works well in the right situation, but is certainly not for everything.
  8. #9858
    Mar 2019
    North & South America
Size:  72.8 KBName:  Front.jpg
    Done, the bare cart tips the scale at 220 lbs. Loaded out...probably 500. Rolls smooth!
    Self-sufficient...to the end...
    Engineer and build it all
    Miller CST280
    ESAB EMP 235
    Abene
    Rockwell
    Atlas
    Fluke
    and the list goes on....
  9. #9859
    May 2017
    Pitman PA
    Nice lookin work you done there, that's a lot welding to be done there we did 2 of those last summer.
  10. #9860
    May 2017
    Pitman PA
    nice lookin work you did, did you do the fitup and all the other good stuff that goes along with it too?
  11. #9861
    Aug 2016
    I'm gonna put these in a box,
    send them to Jody, for a microscopic inspection.
    Could not have done it without "welding tips and tricks"...
    1/8 bed frame metal, .030 mig wire
    thank you Jody !!!
    Charl
  12. #9862
    PDX PNW
    It’s possible Those will pass inspection
  13. #9863
    The tank I made up for water a few years ago is just too small so I had this 575 gallon laying around but it only had a 3/4 port on the bottom so I found a 2 inch coupling sawed it in half and welded it up
    Didn't want to start the genny or load it in the truck so I ran a couple hundred feet of 12 gauge extension cord for my old miller 211... used .030 flux core wire... seemed to weld just fine.
    Done welding, looks ok for a 110volt weld job
    Filled er' up and put some pressure in it.... no leaks
    Just gotta decide what pigment to use on it ....
  14. #9864
    Yeah, to be honest I am more of a fabricator than a welder.
    For a long time I was try to expand my welding skills and certifications; focusing solely on welding. But there are too many other welders out there.
    When I decided to focus more on fabrication work, things really expanded for me. While there might be less "glory" in fabrication work as compared to welding, I look at my tax statements and am satisfied.
    If you are on Instagram look up "petayswelding" which is my account. I have a time lapse video of fitting this unit.
    All parts were drawn on Solid Works and then cut on our CNC plasma table (not by me) then I fit it up (making the necessary adjustments needed) to make sure the customer got the product he was promised.
  15. #9865
    Cumbria, UK
    Quote Originally Posted by Renaissance1 View Post
    looks really nice and beefy!
    Saturday, welding up alloy mower hood, with my new Lorch TIG welder. It's a revelation.
  16. #9866
    Mar 2019
    Thank you
    Miller CST280
    ESAB EMP 235
    Abene
    Rockwell
    Atlas
    Fluke
  17. #9867
    May 2017
    Pitman PA
    In my younger days I did some fabrication, built big hoppers and stuff for coal breakers and such, and some other oddball stuff, I don't do so much of it anymore, mostly because im all tied up with this mining machinery, when I did do it though I did pretty good just having a torch a grinder a mag drill and a welder. The little knickknack stuff where they want 60 of em and they all got to look alike and be perfect Im no good at, drives me bananas.
    Aint no shame in bein a good fabricator. It all starts with a drawing, fabricator got to know how to read it then operate the shears or whatever hes gonna cut it out with, got to know how to bend it if need be, and he got to plan ahead to put it together without getting in a bind... mean while the guy with the worn out eyeballs his smokin cigarettes and watchin Capt Kangaroo cause he got nothin to do til you say tac me...but you do your own tacking and welding so you do it all start to finish...Good deal and somethin to be proud of. You do good work
  18. #9868
    You did it all wrong. YOU'RE SUPPOSED TO WELD IT UP WITH THE VALVE SCREWED IN. Seals better when the nylon meltsName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  19. #9869
    HEh heh... I won't show you the first try when I did leave the pvc fitting in there to keep things from getting out-of-round I went to the local home duplo to get some 2 inch fittings and stuff.... they don't carry anything over 1-1/2 any more???? WTH I guess I was lucky I had that one coupler laying around or I'd be SOL
    Originally I was gonna replace all the fittings cause the top 2 inchers were all beat up and you couldn't get a plug started in them.... fortunately I found a set of taps in the shop to rethread em'
  20. #9870
    Sep 2016
    American Samoa
    Name:  O1 chisel.jpg
Size:  91.4 KBMost of my welding lately has been keeping the riding mower deck functional, not pretty at all. In fact, not many of my welds are pretty; i am satisfied with functional usually. I had forged this bent handled chisel for woodworking out of O1, and had a cracked neck on the handle that basically fell off when I tried to peen the end over. I had to fix the gas solenoid on my welder, hooked up the TIG torch, and welded on a piece of rebar as a handle. Problem solved.
  21. #9871
    You do some really nice work! I wonder if that is the same wear material that I was supplied a couple of years ago to line a load hopper for a redi-mix concrete plant. The customer supplied the plate and referred to it as 'tungsten carbide'....told me it was something like $4k for a 4x8 sheet of it. They specified the hopper to be built out of AR-400 and the aggregate side to be lined with the wear plate. They requested the wear plates be bolted in to facilitate replacement. The back side won't see much wear as the cement sock hangs down all the way through the load hopper and into the load sock. I had no idea as to the weldability of the wear material, it's very interesting to see how you handled that. Nice work!
Size:  104.5 KBName:  003.jpg
Size:  122.5 KBName:  004.jpg
  22. #9872
    Nov 2018
    Fabed some new steps for this 890 and weld them on today
  23. #9873
    Looks good Rustin8 you sure they're tough enough.. nice bead !!!
  24. #9874
    Nov 2018
    Should be 25mm grade 450 and 12mm 450 for the front ,had to work sunday so the fat bugger can get into the digger monday morning!
  25. #9875
    Sep 2015
    SE Pa
    Nice job
