Show us what you welded today! - Page 416
Page 416 of 419 FirstFirst ... 316366406414415416417418 ... LastLast
Results 10,376 to 10,400 of 10460
  1. #10376
    Re: Show us what you welded today!
    Thats job security!
    Yep, I hear that a lot
  2. #10377
    Started on the anti-homeless/vandal gate design the other day and finished up the prototype today
    Got a couple small changes to make on the production ones but overall seems like it'll do the job.
    Went with oversized tube hinges and tabs for the fabric securement, probably saved 30-40 bux in hardware costs and labor was probably quicker.
    Put the temp legs on it just for the demo.
  3. #10378
    Aug 2009
    missouri
    If you only have to hit the bar to open I would counter with a piece of metal bent at a 90 to get in. Or use the same to push in the catch, counter that with a box over the catch.
  4. #10379
    Yeah, that's the first thing I told em' but unfortunately the opener design is required by law... the finished doors will have a bigger anti-reacharound plate but still has the same weakness. It's all about making these properties 'less' attractive to prospective vandals/vagrants/homeless/methheads/etc.... A nice double keyed deadbolt is the best way... but can't do that on fire exits....
  5. #10380
    Jul 2013
    We've been fighting that on a construction site. Fire marshal has been requiring push bars on all the man gates out of the perimeter fence.
  6. #10381
    Yep, about all you can do then is put some alarm on there and then it's just going off all the time when the crews need access...unless you time it but them things just get even more complicated...
    We have to do a bunch of these so the main thing was to come up with a generic design that will work across lots of buildings/sites, I can't change the main design characteristics of chainlink and pushbar... there are things I have thought of to inhibit the bent rebar vulnerability but then it doesn't pass code....
  7. #10382
    A large Rottweiler on a long chain would be a far more effective deterrent.
  8. #10383
    I wonder if they will give discounts if we need 3or 400 dogs....
  9. #10384
    Sep 2015
    SE Pa
    Put sheets of stretched steel around door way to fill in openings?
  10. #10385
    The door ways already have 6 inches of concrete around them
  11. #10386
    Got the demo up, still have to attach the closer and switch out the reacharound plate.
  12. #10387
    Southern CT
    Solder on radiator mounting bracket. Must have loosened up, vibrated and destroyed itself. Too many cracks to weld up so made new.
    16 G bent up on a radius bar on the brake.
    Ernie F.
  13. #10388
    Southern CT
    ronsii, nice job on the gate!
    Ernie F.
  14. #10389
    Thanks, I hope they like it and we get orders for a *lot* more
    Nice job on the radiator bracket... looks factory!!!
  15. #10390
    Nice gate, well done. Why the crossbar at the bottom? Seem like something to be eliminated if you do a lot more.
  16. #10391
    The cross bar at the bottom is mainly for ease of install... to keep things where they should be for a good fit and latch... I will probably have to cut some of them off after install because of the varying designs of the entry landings, some go to dirt inside the walls... and I don't want a tripping hazard
    Will be starting on 6 more tomorrow with the design changes, might even make up some jigs for certain parts of these...
  17. #10392
    Sep 2015
    West coast of Florida
    sounds good, congrats
    Richard
  18. #10393
    Nov 2015
    Phoenix, AZ
    Making a base for a CNC router build, out of 2x2x.083” tube.
    HTP Invertig 221H w/ CK20 water cooled torch
    Optrel Crystal 2.0
  19. #10394
    Apr 2019
    Started putting this little atv flip disc set together last weekend. Just need to figure out a good way to mount the tires to the top, so that the flip over tow option will work.
  20. #10395
    @koenbro, that's a nice looking base you didn't want to make the whole thing from 80-20 huh? $$$
    @ davidpuddy, nice job on hte box frame... looks like it ought to be plenty stout What kind of wheels are you planning on?
    Well, between other jobs I finally got a chance to add a pipe restraint to the lowbuck notcher... something I been planning on for a long time now just never took the time to do it... works great! really cuts down on pipe slip... a lot... especially in the heavier gauges.
  21. #10396
    Nice add on. Now make it hydraulic. Those are nice tools. Mine wore me out.
  22. #10397
    Oh yeah!!!, air or hydro I have thought about... but right now I just slip it in the receiver in the truck( or anything else) and I'm ready to go... if I start making things easier/bigger/more complicated then they're not as portable for field work.... I guess I could get a second one for shop use.... nah...for shop work I'd get something more predictable.
  23. #10398
    Nov 2015
    Phoenix, AZ
    You're on to something Haven't counted but extrusion might be 3+ times the cost of steel tube, and that's before the milling charge. Of course extrusion has its advantages, but I like to weld
    Optrel Crystal 2.0
  24. #10399
    Apr 2019
    Hey thanks Ronsil, they are just wheelbarrow type wheels that I picked up from harbor freight. They are never flat type wheels. Rated for 300 pounds each, so should be able to hold the weight....granted that I figure out a good way to mount them.]
  25. #10400
    Quote Originally Posted by davidpuddy View Post
    I'd just weld on a couple pieces of flat bar or some c channel on each side and a couple 45 braces on it if you go with flatbar... drill a hole for the shaft and spacers... and done
    Oh, and put them at an angle(about 30 degrees) towards the front if you want it to be a little easier to tip.
