Help me figure out the correct angles and cuts
Results 1 to 15 of 15
    Jan 2010
    Coeur d'Alene Idaho
    I can't seem to figure out these cuts. i am making a front bumper for my atv and am kind of going off of the original design. i am using 1.5X1 square tubing. The attachment is a quick drawing of the two main tubes that attach to the bottom of the frame. If you were to look at the bumper from the side you would see that it has about a 40 degree angle, then if you look at the same piece from the front view it has about a 25 degree angle.
    I set up my chop saw at 20 degrees and cut the first piece for the 40 degree angle. Then i kept the angle on the chop saw at 20 degrees but then added a 12.5 degree angle on that and cut it. The result was two angles that didn't fit. What am i doing wrong?
    Thanks for your help.
    Dec 2005
    Midland, Texas
    Re: Help me figure out the correct angles and cuts
    I cut a bunch of compound angles on a project I did recently. Even with a compound miter saw, I still confused myself, and the angles didn't always work out as planned. I found the best way to do it was to cut wood pieces first and get them to fit correctly first.
    America Needs AMERICA'S Oil!!!
    "Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
    Feb 2010
    South Mississippi
    My brain hurts just trying to think about it.
    If you don't use your head you may as well have been born with two backends.That ain't exactly how Papa used to say it.
    *Linc'n WeldanPower 200 with a Wis. 2 cyl. w/handcrank
    *Linc'n AC225
    *Linc'n ProMig 180
    *tiny porta torch...
    Apr 2010
    Galesburg, il USA
    Hi adamsmith007;
    The tangent for a compound angle is equal to the tangent of either given angle times the cosine of the other given angle (tanC = tanA x cosB). This will give you a correction to the primary angle if that is all that is needed by subtracting the product from the original angle, changing sign and adding back to the original angle for a new angle setting.
    Confused? Try this for a simpler solution with a miter saw and 2 angle correction.
    If you are using a compound miter saw use the following.
    Miter setting = arctan [tan(40) x cos(25)] = 37degrees 15min or 37 1/4 degrees
    Bevel setting = arcsin [sin(40) x sin(25)] = 15degrees 45min or 15 3/4 degrees
    The bevel doesn't look quite right but I think the calc is the right one. If the 25 degree angle is too shallow try a piece of scrap using the miter calc with the angles switched in the equation for the bevel setting.
    The mind is the last thing to go... first my hair, then my eyes... now the mind!
    Anyway post back as I may have the +/- to the original angles wrong.
    Matt
    Jan 2010
    Coeur d'Alene Idaho
    Thanks Matt! I will work on this project here in the next hour or so and post up some pics!
    Jan 2010
    Coeur d'Alene Idaho
    Well it looks like my original degree calculations were off. It looks like the angles are 48 and 30. I don't have a graphing calculator, so i am trying to figure out how to do your calculations without one.
    Apr 2010
    Galesburg, il USA
    After further review I checked my Machinery's Handbook at the shop....
    I worked the solution in a fashion I understand better (like I'm positioning a plate to put a hole in it at an angle with an second angle of rotation)
    The solution came out closer to what I imagined when I first posted up in my bathrobe...
    This time I came up with miter (first angle) of 43.8 degrees and bevel (angle of rotation) of 29 degrees.
    This could be wrong with either angle or both being corrected the other direction from original, like 36 instead of 44 and or 21 instead of 29...
    I'm gonna take the slide miter out and see which is which. A good carpenter with a framing square would probably have this cut, nailed up and most of a six pack down.
    Attached vision of second solution below
    Apr 2010
    Galesburg, il USA
    Quote Originally Posted by adamsmith007 View Post
    You posted before I posted, gotta go back to the shop I'll check with miter saw...
    You are trying to do this with one cut aren't you?
    Matt
    Jan 2008
    It's pretty simple look at the attached drawing
    I did your 40 degree as an example.
    A straight line is a 180 degree arc. You want something that is 30 degrees less. Thus it is a 140 degree Joint. The two pieces that make a 140 degree joint are 70 degrees.
    IF you are cutting your metal at 90 degrees to normal they are 20 degrees (90-70).
    The arc and tan are valid, but not necessary in this type of work.
    Jan 2010
    Coeur d'Alene Idaho
    I figured out what i was doing wrong. I was making identical cuts on both pieces of square tubing, but what i needed to do was turn one 180 degrees and then make the same cut and it fit fine. Thanks for your help!
    Apr 2010
    Galesburg, il USA
    I was worried I was puffing bad voodoo up your poo-poo, cause I didn't understand the problem (that happens a lot with me).
    What were your final settings, single angle adjustment or both...
    Matt
    Oct 2007
    East Meadow New York
    That is a trick angle. Just set your two angles to half the angle you want. It comes out so close I cannot tell the difference. I got 39.5 plus degrees and 25 degrees. From 20 and 12.5 degree saw settings.
    At that angle it comes out just right. It does not need an adjustment.
    Obviously if you turn the 40 degree angle into a 90 degree angle you are going to get, about a 12.5 degree angle out of a 12.5 degree cut. And your ninety won't be a true ninety. Because you are only using one half the angle. It is pretty wild stuff though.
    I do pipe bends that go down, and to the left or right. And it can get you laughing hysterically sometimes. It is rotation and changing the angle of the single bend to do that.
    I tried it with other adjusted settings, and it did not work. Way over 40 and 25 degrees. I got almost 50 and 40 from the adjusted angles.
    Sincerely,
    William McCormick
    Jan 2010
    california
    COS of angle A multiplied by the COS of angle B, this will give you the COS of the compound angle.
    Mar 2009
    MN
    Square tube is your problem. If you switched to round, you would no longer have a compound angle. That's just my .02 though.
    My name's not Jim....
    Nov 2006
    This is probably too late to help
    http://www.csgnetwork.com/sawmitercalc.html
    but this online miter saw calculator sure saves a lot of fuss cutting compound angles.
