Cambell Hausfeld mig
Results 1 to 11 of 11
    I recently bought a little mig/flux105 with bottle and auto darkening shield for cheap.
    It's an older machine but looks pretty unused.
    The plan is to use it for little sheet metal projects at home.
    I'm pretty happy with the way it welds, other than the arc starting, which is iffy. Once I get a puddle it welds good.
    I've been reading about the HF 151 capacitor mod, and wondering if anyone has tried it with one of these little 110V machines?
    It's live wire, and I've also been thinking about adding a contactor to it, but that might be more trouble than it's worth.
    Beaverton, OR
    Re: Cambell Hausfeld mig
    I have the same machine and was searching for the answer to your question. So far, no luck in finding anything.
    Anyone?
    May 2009
    Wyoming US
    If it can use gas it must be DC.
    Do you have a diagram from the manual ?
    You can contact Cambell Hausfeld for tech support and diagrams and manuals.
    The biggest thing with small welders is to keep the welding wire small. never try wire larger that 0.030 hard wire. most can do 0'035 flux core if the cab reverse the weld voltage polarity.
    You can try slowing down your wire speed just a touch or if using co2 gas try 75/25.
    Checked out a 115 volt welder the other day that would not weld nice on co2. put it on 75/25 and it welded like a whole different machine and buzzed out a nice bead.
    Beaverton, OR
    Quote Originally Posted by Bluewelders View Post
    This is the Wiring diagram for the CH MIG/FLUX 105, model # WG3000.
    May 2009
    Wyoming US
    You would just hook a 47,000uf or so capacitor on the plus (+) and minus (-) sides of the output rectifier.
    The capacitor would have to have a voltage rating about 1.4 times higher than than OC voltage listed for the welder.
    Two 22,000uf capacitors wired in parallel would be fine,whatever is cheaper or easier.
    I used two capacitors on my 131 welder because of space issues.
    You should also hook a 1K resistor at 2 or more watts across the capacitor.
    The capacitor can hold a charge for a long time without it.
    Sometimes a capacitor will still have a charge after months of setting idle.
    Beaverton, OR
    Hmmmm,
    What would you expect to pay for something like that?
    May 2009
    Wyoming US
    About $20-30 for the capacitor,a dollar or two for the resistor.
    Of course you might find what you need on Ebay.
    Realizing this is an old thread, did anyone ever mod the CH mig 105 welder? I have the same welder and was wondering if it worked and what the results are. Also any pics.
    Thanks
    Barry Sims
    Feb 2019
    tenneessee
    Quote Originally Posted by BSims66173 View Post
    Thanks
    Barry Sims
    hi barry do you still have your CH mig/flux 105 welder,i have one and need some info
    Feb 2019
    tenneessee
    does anyone understand the schematic ,i have looked it over and still dont know how to connect my new lead
