Building A Tig Water Cooler For Dummies!!!
Page 1 of 5 123 ... LastLast
Results 1 to 25 of 101
    Dec 2011
    I have access to a piece of 11 gauge stainless approx 16" x 120". I figure this would make for a great tank for a water cooler.
    I would like to see this thread take a course where guys like me that know diddly about water coolers could get info like tank measurements, part numbers and vendor info for the other hardware.....bungs, pump, radiator fans.....etc.
    Thanks in advance!
    May 2008
    Matthews NC
    Re: Building A Tig Water Cooler For Dummies!!!
    I built one a few years ago.Pretty much from junk .It works just fine.
    Someone had posted pictures and I used them as a reference.
    For the tank I used one of those stainless steel Buffet/food trays they use in deli's.My buddy had it in his garage,the motor was salvaged from an old soda dispenser machine and the pump was a Pro Con pump.I got the pump from Ebay,it was like 30.00 and the motor from Craigslist for about 20.00.I had an old heater core from a truck and a small computer fan. The housing is from some scrap aluminum i had and the frame is just some angle iron I had.The rest of stuff(fittings,hose etc...) I got locally from Lowes.I had a pressure gauge and light switch.The most exspensive stuff was the torch and hoses which I got from Arc zone.I think I have about 100.00 into it,if that .I hope the picture posts.
    Utah
    There are calculators on the web that can tell you, given tank measurements, the volume of said tank in gallons.
    Jul 2013
    La Porte, TX
    I like the idea. Keep in mind that yhe tank doesn't have to be big. 1 cubic foot holds 8.34 gallons if I remember correctly. The Miller ones I have looked at hold between 1 and 3.5 gallons.
    Looking forward to lots of good reference material here when I get ready to build one.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    west texas
    I don't know if I would even build a tank. I figure if I was ever going to go tig and build a cooler I would just use a car radiator as both the cooler and the tank since a radiator can easily hold several quarts of coolant and is already built to dissipate tens of thousands of BTUs per hour with forced air.
    I don't even think you would need a radiator fan for most setups. Then if you need a fan, just stick on a 12v universal radiator fan on there or if you don't need that much air flow or noise, stick a few computer fans on the radiator.
    For the line, I would just use air line.
    For he pump, I would just use a sureflo 12v diaphragm agro spray pump since it can pump pretty much any chemical concoction at 1 to 3 gpm.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Miller model 250 and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
    Jul 2011
    Utah
    11ga is waaaaay too thick, I mean it'll work and all but damn... I would use 18ga stainless.
    I've got a lot of info on DIY tig coolers on my build thread, a lot of other have popped up recently too.
    Jul 2011
    Utah
    Mar 2014
    PA/MD
    Mike check your inbox please
    AWS 17.1, D1.1 and ASME IX (GTAW)
    Miller Syncrowave 350LX, Maxstar 150sth, Maxstar 200DX and Millermatic 252 w/ Spoolmatic 30a
    Miller buzz box with Lincolin Tombstone
    Thermal Dynamics Cutmaster 38
    Dec 2011
    Quote Originally Posted by MikeGyver View Post
    Yep........but 11ga. Is free.
    Jun 2009
    Central North Carolina
    I built a Tig cooler 5 years ago by modifying a carbonator that I bought off Craigslist. I used the Proconn pump and the 2 gallon stainless tank that came on it and just re-plumbed and replaced the lines. The radiator is an aluminum transmission cooler that I attached to the side of the carbonator base and I added a sheet metal shroud with 2 muffin fans to force air through the radiator. The coolant temperature has never gone above 110 degrees during any of my aluminum welding since the cooler was built. I have used RV antifreeze and Distilled water 50/50 mix since the cooler was built with no problems. Adjust the pressure relief bypass of the pump to 45-50 psi and you will be fine. The 2 gallons of coolant seems to be more than enough.
    Charley
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF / DIY Cooler
    2 Victor O/A Torchsets
    Milwaukee 8" Metal Saw
    Milwaukee Dry Cut "Chop" Saw
    5 Ton Wallace Gantry
    Various Grinders, Benders, etc.
    Nov 2012
    Quote Originally Posted by Gravel View Post
    7.48 gal per ft^3
    Jul 2013
    La Porte, TX
    Quote Originally Posted by dva View Post
    7.48 gal per ft^3
    You are correct. I was thinking of the weight of a gallon of water...
    Gravel
    Jul 2011
    I've always felt that an old Cornelius keg would be a perfect reservoir for a cooler. Stainless steel, opening to clean now and then, and you can cut and weld to make any size you'd like. Pretty cheap as I recall (haven't home brewed in years).
    Combine with one of those inline tranny coolers, the long round tubular ones with the radial fins radiating outward from the center. Procon pump and motor. Voila, a 5 gallon cooler for under $200.
    Jul 2013
    La Porte, TX
    Here are some rather large stainless tanks on CL. I'd like to see the cart some of the guys would build to move this around!
    http://houston.craigslist.org/bfs/4620689307.html
    Gravel
    Feb 2009
    Chicago
    Quote Originally Posted by Drf255 View Post
    That's a great idea. Then add a Y valve and circulate beer instead of coolant, and open the Y valve when you need a drink.
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Jul 2014
    Bulldog Heaven at the end of my chain
    Quote Originally Posted by Gamble View Post
    I see a guy running out of torch coolant and making some really bad welds.....
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Utah
    Just what the world needs, more hot beer.
    Pensacola , Fla
    Here is one I built for a carbonator from Ebay. Stainless tank and AV evap from a auto. drilled a hole in the end of the motor shaft and mounted a fan on it for cooling of the evap.
    DIY CNC Plasma table & CandCNC DTHC-IV MP 3100 Feather Touch option
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Utah
    What torch are you running off that?
    Pensacola , Fla
    wp-18
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Jul 2013
    La Porte, TX
    Quote Originally Posted by CharleyL View Post
    Charley
    Can you show some shots of the cart. I've been thinking about raising my HF so the cooler is under it. Not sure if I have strong enough materials on hand or if I'll have to buy some new steel.
    Gravel
    Plano Texas
    Here's the one I made. Used a trans cooler, Two box fans and a Procon pump. Homemade tank pictured.
Size:  73.0 KBName:  IMG_0287.jpg
    Plano Texas
    I'm only an "apprentice", so what do I know? lol
    Jul 2013
    La Porte, TX
    Quote Originally Posted by MCE View Post
    Nice. I like the small footprint.
    Gravel
    Dec 2011
    Here's where I am at. I sheared up 12 pieces 11 ga. stainless I got for free. I am got more than I needed just because it was free. I am making a tank that is 8" X 8".........this will give me approx. 2 gallon of coolant. I am wondering what and where to get the bungs and the filler cap. An idea on the cheap would be to weld a stainless nut big enough to tank a funnel and use a bolt as a filler cap. As far as the hose bungs go I was thinking again of welding nuts...........drilling out a bolt on my lathe........( basically a hollow all thread rod) and jam nutting it with about an inch sticking out to connect a hose to.
    Again any comments are appreciated.
