Stay from those old compressor---
Page 1 of 7 123 ... LastLast
Results 1 to 25 of 163
    Soda springs,Id
    if you don't know their history. The pics will tell more than I can type since I only (fortunately) have the use of my dominant right hand. Our son was given an old craftsman 3 hp 220 v. we got him a brad nailer for christmas, so he bought an air hose to try it out. i was hunkered down beside it watching the gauges. when it hit 130 psi i pulled out on the pressure relief to make sure it worked and it did. when it hit 150 psi i was about to lose my nerve and shut it down. then the tank blew, luckily for me, out the bottom. i feel quite fortunate to have survived this.the injuries were: bad laceration on the back of the left hand,all four bones broken where the fingers attach to the hand. left knee took a severe impact from tank spliitting and broke the tibia and femur.amazingly i never lost consciousness and felt a bad pain in the front of my neck. ran my right hand over that area after seeing my left hand and was actually relieved to see no blood in that area. apparently it blew my left hand into my throat.
    the docs pinned the four bones together in my hand, put a plate about 8" long on my tibia and ran 4 screws into my femur.the ol timex took a liiken and is still tickin, just broke the band pin when it hit my neck.
    the truly amazing part is my wife,son and his girlfriend and an older friend were in the garage when this happened, nothing happened to them outside of some ringing ears, not a scratch.
    the fridge next to the compressor was a liitle worse for wear as evidenced in the pics. the little tv behind the compressor had the cabinet half torn off, but the picture tube was still intact.the 16' garage door got one roller knocked out of the track and about 12 sheetrock screws got the mud knocked off them.
    all in all, i feel lucky i survived it. i guess we all have angels watching over us. i'll let the pics tell the rest.
    mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    May 2008
    US Virgin Islands
    Re: Stay from those old compressor---
    wow...never would have thought it would do that.Glad you are somewhat ok
    Jan 2008
    Lansing, MI
    Holy CRAP!
    Man, glad it wasn't worse.
    Good thing your son wasn't face in front of it by himself on a night his girlfriend wasn't around. Could have been a one way trip to the morgue.
    Wow....
    Aug 2010
    Northern CA
    What a nightmare!
    Screw the fridge, tank, and the mess - you and your son survived. Don't imagine if you were standing where that fridge was during the crisis. I could have been much worse.
    At least you were able to be patched up and will be back in time. Hit those pain pills heavily.
    Sep 2008
    SF bay area, CA
    HOLLY ****! And people think im over reacting when i get paranoid about pressure vessels.
    Nov 2006
    What do we think? Stuck pressure switch and inaccurate gauge?
    I wonder why the relief didn't blow off?
    Doesn't look like a rust-weakened reservoir failure, just looks like overpressure.
    Good Luck
    Soda springs,Id
    i think was rusted out enough to create the stuation. wasn't a sign of oil in the tank. i have strict policy now if i don't see it run up to the kickout, i wont even turn it on. it'll be on a oneway trip to the scrap yard!!!
    gwd, i'm hitting the percosets every 4 hrs just like prescription says
    mike
    ps: you noticed no caps and very little punctuation. just try hitting the shift key and the key you want w/ one hand. i've got the equivalent of a boxing glove on the left
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Feb 2008
    North of Philly
    Wow, Glad to hear you weren't hurt more seriously. I think I'll save this for those times when guys think there's no problems messing with compressor cylinders.
    Hope you get well soon. Pm sent.
    Ronald Reagan
    Western PA
    Damn! I'm glad you're still with us, Mike.
    Many of us know the potential danger, but seeing the aftermath really wakes you up.
    Jun 2008
    Central California
    Quote Originally Posted by denrep View Post
    Good Luck
    In the first picture, it looks like the tear followed one end-cap welding seam. I wonder if it might have started there, maybe at a rust pit on one side? Just curious mostly; not implying anything about the welds, or anything else.
    Did the tank have a plate giving date of manufacture, working pressure or any other data?
    Cassville, Missouri
    I've seen several of the small tanks crack due to vibration. Usually they just leak. I'm glad I never seen one explode. Hope you heal up quickly.
    Tough as nails and damn near as smart
    May 2010
    ct.
    I can't imagine being that close to something like that happening,
    While the outcome wasn't good,I'm glad it wasn't worse.(fatal).
    Good Luck
    I could believe a bad gauge(common) or a press. switch set too high,but
    gauge,press.switch and relief valve all bad seems unlikely.
    Also,I've seen relief valves fail and blow off at too low a pressure(bad spring).
    I've never seen one fail "closed".
    How about tank damage(impact) or manufacturing defect?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Northern Cal., Shasta County
    Glad you survived with no more injuries than what you received.
    Of course evil minded me, I'm thinking popped ballon and paper bag tricks right about now .. I'll bet you're gonna be gun shy for quite awhile after this ..
    Sep 2008
    SF bay area, CA
    I would just say years of neglect let the bottom of the tank rust. Once it got a small fissure open the rest was history.
    Jul 2005
    Davenport, Iowa
    Quote Originally Posted by jpump5 View Post
    I have.....
    Mike, glad you're still with us....heal well...
    Aug 2008
    I usually don't look in the "Safety Forum", glad I did today. Hope you mend. My sympathy goes out to you. Take care, and hope you're behind the wheel soon
    http://www.farmersamm.com/
    Jun 2010
    Louisville, KY
    Mike, I am glad you made it through this one. I have seen incidents where people ended up in a box because of an air tank explosion.
    For anyone interested: This is exactly why you hydro test with water instead of a pneumatic test with air.
    Mar 2007
    Vero Beach, Fl.
    Wow.....and what everyone else said.
    Glad you are still here to talk about it. Thanks for giving us all a wake up call to what most of us take for granted.
    This is a good reminder to those of you with the "it will never happen to me" attitudes that it can happen to you.
    I am what I am, Deal with it!
    If necessity is the Mother of Invention, I must be the Father of Desperation!
    Sep 2006
    NJ, USA
    Wow.
    Just wow.
    Your guardian angel was definitely working fast on that one.
    You got banged up a bit. Understatement there, you had six (SIX!!!) broken bones including a femur (femurs usually don't break easily). Heal well.
    (and I was just recently mentioning/admonishing on another forum that pressure vessels are NOT to be taken lightly or messed around with. I'm going to post this there to FURTHER r-e-m-i-n-d some of the folks who were taking things waaaaay to lightly IMNSHO that pressure vessels are not to be f'ed with, including a self-proclaimed CWI who was advising someone to just weld on a pressure vessel. No WPS, no hydro-test, just go and weld on an air tank. Grrrr. )
    Oct 2010
    Bethel, CT
    WOW! that sucks! Glad nobody was killed. Thanks for posting those pics. Just goes to show it can happen to anyone. We use small 4 gallon compressors everyday, and we are guilty of not dumping the air everyday. Not after seeing that. Looking at all that rust on the inside tells me my compressor may look like that. We bought a new Rigid about a year ago. You were nervous about 150 psi shut off pressure. Our new one shuts off at 160 psi. Our older compressors (campbell hausfeld) shut off at 120 psi. You got me paranoid now.
    kidtigger24
    They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
    Jul 2010
    Texas
    Wow, that gives me the shivers. Very glad to hear you're ultimately "alright". Heal up quick but take all the rest and happy pills you need to get by. (And try to get off them soon as you can!).
    I think you just convinced me to buy a big new compressor when the time comes.
    Lincoln AC225 and Cart
    Lincoln WeldPak HD and Cart
    One hand
    Oct 2008
    Skelton in cleveland,ENGLAND.
    Congratulations on your "LUCKY" escape, certainly gives food for thought. Seems to me like a wrongly set relief v/v or maybe it was a bit sticky, As he had to pull it at 130psi to make it lift.
    Lincoln SP-170 Mig
    Hypertherm powermax 45
    Lorch T220 AC/DC Tig
    Butters FM 215 synergic Mig
    Kemppi 180 adaptive mig
    RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE
    GUIDANCE OF WISE MEN.
    Soda springs,Id
    thanks, monica. i've never been much for prescription pain killers, but i'm taking these percosets religiously. my left arm and leg both tell me i will or suffer the consequences
    and thanks to everyone for all the well wishes. after looking at the pics closer i believe the strap the wheels were mounted on saved me from more extensive injury as it appears to have restrained some of the expansion on the side facing me.
    mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Nov 2007
    Wow. Don't know what to say except I'm glad you are still with us. I haven' been to the Safety Forum in months but for some reason I decided to check it today. I've always been leery of OLD pressure tanks and I'll be more so now after seeing this.
    I have a DeWalt compressor out in the garage that shuts off at 210 psi. I may start going out side when it runs. It's pretty new so it shouldn't be dangerous yet.
    Nov 2010
    NH
    Wow, thanks for posting!
    I think a new compressor is in my future. Mine was used, 20 years ago...
    Heal up quick!
