*** Metallurgy - Practical Knowledge, Useful Guides, and Advanced References *** - Page 3
Page 3 of 3 FirstFirst 123
Results 51 to 75 of 75
  1. #51
    Mar 2014
    Re: *** Metallurgy - Practical Knowledge, Useful Guides, and Advanced References ***
    That was frigg'n awesome!
  2. #52
    Jan 2013
    ...Shoulder of Orion...
    @ HT2 - solid cutaways and inside look at the thin-film and convection cooling passages on turbine blades, courtesy of AJZ....
    The superalloy blades are operating hundreds of degrees above their melting temps. Engineered and fabricated brilliance.
  3. #53
    Jan 2013
  4. #54
    Jan 2011
    This is the first text book I ever read about Metallurgy, mid 80's, probably outdated, but if anyone want's any pages, let me know, I'll scan any of it you might need/want.Name:  DSCF6014.jpg
    Mastering others is strength, mastering yourself is true power.
  5. #55
    Anyone having QuickPass Certified Welding Inspector AWS/CWI Study Guide ? Please share it ...
  6. #56
    Jan 2013
    Useful Solutions for Standard Problems - Mike Ashby.
    Sections 9 and 10, respectively, list formulae for stress concentrations and sharp cracks.
  7. #57
    Laredo, Tx
    Quote Originally Posted by ManoKai View Post
    That's a good one. I'm saving it in my Google drive along with everything else. I wonder everyone is doing the same....
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  8. #58
    Jan 2013
  9. #59
    Jan 2013
    A visual journey into the Ni superalloys of turbine blades. From milli to micro to nanometers and finally to atoms. Incredible visual works.
  10. #60
    Jan 2013
    American Institute of Steel Constuction (AISC):Structural Steel Connections.
    Nice companion to AWS D1.1 in understanding terminology & geometry of bolted/welded connections.
  11. #61
    Jan 2013
  12. #62
    Jan 2013
    Swiss leader TRUMPF shows the laser metal deposition practices on an assembly. Their high-powerd, N2 cooled CO2 and Ar-shielded CW/Pulsed fiber lasers are on the leading edge of additive manufacturing. Creating, buildin up, and repairing using powdered Co, Cr, Cu, Ni, Ti, and other elements are making waves in industry.
    The future's so bright, I gotta wear shades.
  13. #63
    Jan 2013
  14. #64
    Mar 2016
    Minneapolis MN
    Can anybody recommend a good book on TIG welding for beginners?
  15. #65
    Jan 2013
    @ cloudman - see TIG section on p2. at Welders Universe.
  16. #66
    Jan 2013
    Rust on Stainless Steels. A very practical guide exploring why SS rusts.
  17. #67
    Jan 2013
    AHSS 101 - Evolving Use of Advanced High Strength Steels for Automotive Applications
    Interesting to note/infer how the rescue tool manufacturers (Hurst, Holmatro) are pulsing the increase us of these high-performance steels, to ensure their jaws of life can safely attack components (A/B pillars, longitudinal side members, etc) during extrications.
    Keywords: AHSS, Dual phase (DP), Ferritic-bainitic (FB), Complex phase (CP), Martensitic (MS), Transformation-induced plasticity (TRIP), Twinning-induced plasticity(TWIP)
  18. #68
    Jan 2013
  19. #69
    Jan 2013
    Heat-Induced Shrinkage. Metamaterials. Micro STL additive manufacturing.
  20. #70
    Jan 2013
    The Whys and Hows of HCl Acid Pickling, courtesy of Pete S. A comprehensive look at using hydrochloric acid to pickle steel for a chemist's POV.
  21. #71
    Jan 2013
  22. #72
    Jan 2013
    Cleaning and preparing materials and components is an important step in the fabrication process. Checkout this Primer on Solvents, courtesy of PopularWoodworking.
    KeyWords: petroleum distallates; mineral spirits, naptha; toulene, xylene; alcohol, lacquer thinner; acetone, MEK
  23. #73
    Jan 2013
    Electron Beam Welding. An illustrative guide of welded assemblies over the course of a 30-yr career.
    EBW -> vacuum accelerating the electon's mass to fuse dissimilar/refractory metals with a D/W ratio of 40:1 and minimal HAZ.
  24. #74
    Jan 2013
    Recent thread, centering on the pros/cons of various MWFs (metal working fluids), prompted insight between Vegetable and Mineral-based MWFs.
    BLUF of the paper: "The results indicate that as straight oils, all vegetable based stocks, and the vegetable based ester, perform significantly better than the mineral oils."
    Key Words: Cutting Fluids, Metal Working Fluids; Tapping; Oil Type; Naphthenic, 50/50 Blend, Canola Oil, Soybean Oil, TMP Ester; Tagat V20
  25. #75
    Jan 2013
    Stainless Steel Finishes on Sanitary Equipment, courtesy of Apache Stainless Steel Equipment Corporation (Beaver Dam, WI).
    Key Words: RA, roughness average, surface smoothness, 2B finish, 4 finish, 4A finish, 3A dairy standards, passivation, pickle passivation, electro-polishing
