POWERTIG 255EXT STICK WELDING 120V OUTLET. breaker goes off.
Results 1 to 2 of 2
    Canada, Ontario
    I just started doing stick welding with this unit and seem to find that at 80 or more amps with a 1/8th 7018 electrode my breaker keeps tripping?
    is this normal for stick welding with this machine?
    i have it in normal setting, standard electrode feature,no other options selected. Just 80 amps.
    DCEP Hobart rods.
    Nov 2008
    Re: POWERTIG 255EXT STICK WELDING 120V OUTLET. breaker goes off.
    Yes, it is normal if you exceed the breaker capacity. The unit draws over 30 amps IIRC on 120V to achieve maximum output.
    Sounds like you are welding on a 15 amp breaker. Try it on at least a 20 amp breaker with a slow trip design.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
