Converting 90 amp AC welder to DC - Page 3
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 51 to 75 of 223
  1. #51
    May 2009
    Wyoming US
    Re: Converting 90 amp AC welder to DC
    The flattened copper tubing and solder,should give a good connection.
    On the aluminum wire they seem to use just a type of crimp type connector or nuts and bolts,maybe with some anti-oxide paste.
    Terminal strips tend to not work for high amperage,.they heat and work loose.
    I use one of these when I can,on copper tubing ,with solder.
    http://www.radioshack.com/product/in...uctId=2062636#
  2. #52
    lancaster,kentucky
    I found this in a box of whatever electronic parts,don't know no more about it than what is written on it.I'm trying to keep this conversion as cheap as possible by using what I have on hand.
    You would not believe what a 3-port wire terminal cost,too much for my blood so I reckon I will be using the copper pipe to make my connections.
    Would a 40 volt capacitor work?They have a 47,000uf 40 volt cap,actually it's $2 dollars higher than the 50 volt but they have more than 2 in stock.Plus it has a higher ripple current value.Almost double what the 50 volt cap has.
    Maxus Pro-125 Mig
    Chicago Electric 90 amp DC flux-core
    Lincoln Electric AC 225 tombstone
    O/A torch
    M/O mini-torch
    10 acres of flatland
    15 acres of holler
  3. #53
    May 2009
    Wyoming US
    You could use a couple of these in parallel for a resistor.:http://www.radioshack.com/product/in...ower+resistors
  4. #54
    lancaster,kentucky
    That's probably what I'll do for resistors,just go to Radio shack.Thanks for the find.I'm thinking about ordering the cap tomorrow.I'm going to take a chance and order the 47,000 50V and hope it's still in stock,if not I'll go with the 39,000 50V.They have a 58,000 50V in stock,which is the one I would really like to get,only drawback,$62 dollars.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  5. #55
    Jan 2009
    Sonoma County
    There must be someone reading this who has done it already. Did it weld better?
  6. #56
    lancaster,kentucky
    I've wondered that myself.I think everybody thinks it's not worth the time or money.
    I think the manufacturer's of these welder's keep an eye on these forums,they seen where everybody was putting caps in their Harbor Freight 131's,151's and 171's.Woodymayne bought a 131 off ebay here recently and it already had the cap in it.Maybe if my conversion works they will take notice and change these welders over to DC,I know they could do it for a whole lot cheaper than I can.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  7. #57
    lancaster,kentucky
    I ordered my capacitor today,just hope it's in stock when they get it so I can get the one I want.Went by Radio shack and picked up a couple of 100 ohm 10 watt resistors and some thermal heat compound for putting on the screws of the capacitor when I make my connections.I was checking out the schematics to the Lincoln Electric Power Mig 140 and it said to use thermal heatsink compound on all bolted aluminum connections such as the capacitor when reattaching,so that's what I will do.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  8. #58
    Feb 2011
    Near Dallas, TX
    You don't want to put that compound on the capacitor connections. It's for things like transistor mounting tabs and rectifier mounting studs where they attach to a 'heat sink'. It improves heat transfer, but does nothing to help electrical conductivity. For that, you need the stuff I bought called, Cool Amp. You apply it to copper and a chemical reaction occurs that leaves a thin sliver plating on the copper which DOES improve electrical energy transfer.
    Papa
    Lincoln Idealarc 250 (circa 1962)
    Lincoln Weldpak 155 w/Mig Kit
    Lincoln Squarewave TIG 175
  9. #59
    lancaster,kentucky
    Actually bought that to put in between a computer processor and it's heatsink.Lincoln recommends Dow 340 thermal heatsink compound, it's about $30 dollars for a tube of that size.I figured it was sorta about the same thing except this doesn't have silver in it.This is the same stuff as the dow thermal heatsink compound,even has the same stuff in it,this is just the cheap stuff.I'll check into it further just to be sure.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  10. #60
    lancaster,kentucky
    Here's what they each got in them.
    Radio Shack thermal compound:
    Polydimethylsiloxane
    Zinc Oxide
    Polytetrafluoroethylene
    Fumed Silica
    Dow 340 thermal compound:
    Zinc Oxide
    Grease-like Silicone Fluid
    Dow web site said this stuff can be used on heatsinks or electrical bolted connections.Especially aluminum connections like on a capacitor.I figured the Dow 340 would have silver in it but it doesn't.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  11. #61
    lancaster,kentucky
    I got my resistor connectors soldered on,here's a few pics,everybody likes pictures lol That capacitor has 10-32 screws with it so I used 2 ring connectors that fit that thread size.Should mount right on top of the capacitor with no problems.Wonder which is more accurate,the Fluke or the Innova?
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  12. #62
    lancaster,kentucky
    I ain't trying to prove nobody wrong,I just don't want people to think that I am making this stuff up.This is the schematic for the Lincoln Electric Pro mig 140.They recommend putting Dow 340 Thermal Heat Sink Compound on the aluminum connection of the capacitor when reattaching.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  13. #63
    Feb 2011
    Near Dallas, TX
    That's interesting. I don't think I've ever come across heat sink compound being used in that manner in my many years as an equipment tech.
    Hope it all works well when you get it done. Keep us posted.
  14. #64
    Jan 2011
    Fairview Park.,Ohio
    When I connect aluminum to aluminum I use Burndy P8A Anti-Oxidant Electrical Joint Compound.
    Also very good for coating the aluminum feed wires in your breaker box.
    Also has several other uses.
    http://www.galco.com/scripts/cgiip.e...ly=0&tabid=ovr
  15. #65
    Feb 2011
    South Plainfield NJ
    Should keep it all in the family and use a $2.00 HF meter . FYI 5 CWI 's and our Lincoln Electric service center said it is BS to do SSFCAW with AC , it should not work and is crap !!!! Will try myself this weekend . John
  16. #66
    lancaster,kentucky
    Quote Originally Posted by ltvtom View Post
    Dow Corning makes similiar stuff-Dow Corning 4 Electrical Connection Compound
    I don't know why they use the 340 stuff instead of the 4 on the cap connections.I just figure it is about keeping the heat out of the aluminum connection.I figure they know more about it than I do.
    I got one of those too,free with a coupon out of the Sunday paper.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  17. #67
    May 2009
    Wyoming US
    I suppose heatsink compound would keep the joint from oxidizing further and remove hot spots,but I have never seen it used that way.
    Shouldn't hurt anything,whatever the theory behind it.
  18. #68
    lancaster,kentucky
    Quote Originally Posted by Bluewelders View Post
    That's what I figured too,my nephew needed it for his computer so I told him to leave me a little for that purpose.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  19. #69
    Feb 2011
    South Plainfield NJ
    To DM the HF tester is good , tried against $ 500 .00 fluke read the same !!! Now stick it on the output af the HF 90 and show AC or DC ????? John
  20. #70
    Feb 2011
    South Plainfield NJ
    Go to HF website look up SKU 98871 open up owners manuel PG -8 tell me what you find ???? John
  21. #71
    lancaster,kentucky
    It is just AC,I measured it,on low-26.2 ac volts,on high 31.3 ac volts.
    The manual says it's dcen but it's not.It says ac output on the front like papaharley said.
    It's still AC.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  22. #72
    lancaster,kentucky
    Would a 100,000uf 50V cap be too much capacitance?Also wondering if a 40 Volt would work?Probably going to get an e-mail today saying they are sold out of the one I ordered.That's why I'm wondering about the 100,000uf, $7 more and I can get it.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  23. #73
    May 2009
    Wyoming US
    A larger capacitor shouldn't hurt anything,though physically it is a pretty big can.
    You could sell it for about what you have in it ,if it was not what you wanted.
    40v on a live torch is pretty low.
  24. #74
    lancaster,kentucky
    I could probably get it in there somewhere,it is 3" diameter X 4 1/8" tall.So the 40V is out of the question.Just have to wait and see I reckon.
    I did pick up some 10 gauge wire today,that 8 gauge wire is pretty stiff and hard to maneuver where you want it to go plus finding 8 gauge connectors is turning out to be harder than I thought.The bridge rectifier has spade terminals on it but I can't find any spade connectors for 8 gauge wire.I've just looked locally but could probably go to Lexington to an Electronics store and find them.That 10 gauge wire looks pretty skimpy compared to the 8 gauge wire when you put them side-by-side.I would like to use the 8 gauge wherever possible.
    Maxus Pro-125 Mig
    O/A torch
    M/O mini-torch
    15 acres of holler
  25. #75
    May 2009
    Wyoming US
    For the capacitor wiring,10ga is plenty.
    The duty cycle is low enough that super large wire is not necessary.
