Steam Boiler Build...
Page 1 of 3 123 LastLast
Results 1 to 25 of 59
    May 2015
    Saunderstown, RI
    I have built over 130 of these boilers over the last 20 years. These boilers are used in custom built steam boats, and to power steam generators, as well as various other applications.
    Typically, my customers send me a drawing of what they need, and I build it.
    I usually cut metal using a shear, ironworker, bandsaw, or I order burnouts from my steel supplier.
    I try to use semi-modern techniques, but once in a while I build these steam boilers for a customer of mine that builds small, custom steam boats.
    This job requires me to get back to a few down-and-dirty fabbing techniques, lots of hand grinding, etc. Pounds of grinding dust, all over everything, if you know what I mean!
    I want the boilers to be respectable, but I don't go crazy, trying to obtain the prettiest welds that I can. I don't clean all the welds, or remove the spatter. The customer does all that, then he sand blasts them, as well as paints them.
    The thing that I focus on with the welding is to make sure that they're GOOD, STRONG, WELDS! They get tested with 250 lbs./sq. in. of pressure! There can't be any leaks. So, I overlap all my restarts and stops.
    I've built quite a few of these boilers (as well as other designs, and sizes of them), but have never taken any photo's of the progress. This time I did.
    To some of you, this will just be "old hat", but hopefully, some of you will enjoy it.
    Here are the tube plates, with the tubes tacked in...
    to be continued...
    May 2015
    Saunderstown, RI
    Re: Steam Boiler Build...
    Next, I make the door coaming, out of 8" sch. 40 pipe. It gets squashed to fit the cast iron door...
    to be continued...
    May 2015
    Saunderstown, RI
    Then, the ashpit door gets built...
    to be continued...
    May 2015
    Saunderstown, RI
    Then, they get fishmouthed to fit the large tubes that they will eventually get welded to...
    Here's the outer tube, 18" pipe...
    ...and the firebox (inner tube), 16 in. pipe...
    Layouts for cutting out for the door coaming, and ashpit door...
    ...and the cutouts...
    to be continued...
    May 2015
    Saunderstown, RI
    Time to wrap a length of 1/2" square bar around the bottom edge of the firebox, to act as a filler piece, for later on...
    I tig weld this piece, because I don't want any weld above flush...
    to be continued...
    May 2015
    Saunderstown, RI
    The tube assembly gets set upon the firebox...
    ...then welded...
    It gets flipped upside down, to weld the inside...
    to be continued...
    May 2015
    Saunderstown, RI
    All the couplings get welded in...
    So, here is the inside assembly, and the outside assembly...
    Time to join them...
    Slide it down inside, until the door cutouts line up...then tack in the door coaming...
    to be continued...
    May 2015
    Saunderstown, RI
    Welding the door coaming to the firebox tube is pretty challenging, just because...
    The 1/2" square bar filler gets welded to the inside of the outer tube...
    Tabs that support the grate get welded in...
    to be continued...
    Nov 2013
    Livingston, New Jersey, United States
    Really looking good did you weld the tubes or roll them?
    John
    Sent from my XT1254 using Tapatalk
    May 2015
    Saunderstown, RI
    The door coaming gets welded to the outer tube...
    Here's a pic of 1 of the 2 pieces of grating inside the firebox. Wood is burned to make the heat to create the steam...
    Prepping the door, to hang it...
    The door cradle...
    to be continued...
    May 2015
    Saunderstown, RI
    The hinge components...
    Components, welded on...
    The door is hung...
    Ashpit door, ready to weld on...
    to be continued...
    May 2015
    Saunderstown, RI
    More ashpit door...
    to be continued...
    May 2015
    Saunderstown, RI
    Finishing it up...
    The boiler is done!! As far as my part goes....
    to be continued...
    May 2015
    Saunderstown, RI
    Shearing the hood's bottom lip piece...
    These are the pieces that will become the hood...
    Here's the cone part, tacked together...
    Rolling up the bottom lip..
    ...and the top rim...
    to be continued...
    May 2015
    Saunderstown, RI
    Here's the hood, tacked together...
    ...and, welded up...
    ...on the boiler. Later, a 3' tall stack will be attached, by the customer.
    Setting up my home made circle cutting attachment for my plasma cutter, to start cutting the baseplate...
    The base plate...
    to be continued...
    May 2015
    Saunderstown, RI
    Here we go!
    Rolled up the bottom lip. These pieces make up the base.
    to be continued...
    May 2015
    Saunderstown, RI
    Tacked up...
    And, finished.
    The End
    Rich
    Nov 2010
    Texas
    Man Rich that is one impressive build! Can tell that's not your first one to build! Roughly how much time do you have in it? Thanks for sharing!
    May 2015
    Saunderstown, RI
    Quote Originally Posted by johnrbauer View Post
    John
    If you're asking about the 16" and 18" tubes, they were purchased as tube stock.
    Rich
    May 2015
    Saunderstown, RI
    Quote Originally Posted by kuzineddie View Post
    I got faster at these, over the years. In the end, I could build the boiler in about 20 hrs. (not counting the hood and base...) In the beginning....quite a bit longer...
    Rich
    Nov 2013
    Yes I answered my own question you welded them in. They weren't rolled like a lot of big boilers.
    John
    Nov 2014
    I'm greatly impressed with your fab skills!
    I'm interested in the design....Looks like the firebox is surrounded by a pipe-in-pipe water jacket with about an inch spacing between them, so that should add efficiency.
    Being a vertical single pass firetube design, do they intend to operate with the waterline below the upper tube sheet, or with tube nest flooded and waterline maintained in separate steam drum above boiler?
    I'm also trying to identify the purpose of many of those 'connectors' or nozzles welded around the upper shell above the water leg surrounding the firebox.
    On the lower water jacket/water leg, those two larger nozzles must be one for feed water and the other blow down? Or if with separate steam drum, are those two large nozzles intended for downcomer tubes with feed being supplied to drum?
    Also, where did you obtain the design calculations and materials specs, or were those provided by the owners?
    Last question: What is the intended max operating pressure?
    Tanks for the GREAT thread!!!
    May 2015
    Barre Town, VT
    Great job! I've always been fond of steam engines and always wondered if people still made boilers for them.
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Jan 2008
    Lansing, MI
    You totally rock Rich!
    May 2015
    Saunderstown, RI
    Quote Originally Posted by wornoutoldwelder View Post
    Being a vertical single pass firetube design, do they intend to operate with the waterline below the upper tube sheet, or with tube nest flooded and waterline maintained in separate steam drum above boiler? I believe that the water is only between the tube sheets
    I'm also trying to identify the purpose of many of those 'connectors' or nozzles welded around the upper shell above the water leg surrounding the firebox. I only know what a few of the fittings are for...
    I should explain here...I am provided with most of the materials by the customer. The pieces are all cut to size, and the tube holes are drilled out . I "just" cut, grind, fit, and weld the rest of it together. I was provided with a set of drawings, way back in the day.
    So...I don't have an answer to a lot of your questions...sorry...
    I have NO input in the engineering and design of these boilers. I do what I do, they go back to the customer. He hydro tests them, blasts and paints them, and installs them into his boats. Some are sold and installed by someone else ( all over the USA, and outside of the USA...).
    Quote Originally Posted by Iain P View Post
    Yes we do! As a matter of fact, in 1999, when there was the fear of the "Y2K crash", we built 15 of these for a generator dealer in VT. He sold them along with generators that ran on steam. Needless to say...
    You make me blush......but THANKS for sayin' so!
    Rich
