New: 2016 PowerPlasma 50S 120/240V dual voltage Plasma Cutter (50 Amp IGBT)
Results 1 to 25 of 35
    Nov 2008
    The PowerPlasma 50S represents a complete redesign of the PowerPlasma 50 unit of the past few years. This new model features improved cut capacity and improved pilot arc operation with a tip saver feature which helps to extend consumable life. The unit now uses the more durable i PT60 plasma torch, which is a commonly used torch across many brands. We've selected the iPT 60 torch because the new torch offers better cut capacity (severance @ nearly 1") with cleaner cut results during testing. The torch also has improved consumable life and reduces start delays associated with some blow-back designs of previous models. This unit also features a CNC port for light CNC use. CNC torches are also available for this model. The 50 amp PowerPlasma 50S will operate on either 240V or 120V as well, with reduced output while operating on 120V.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Feb 2016
    Re: New: 2016 PowerPlasma 50S 120/240V dual voltage Plasma Cutter (50 Amp IGBT)
    I just bought this plasma cutter, shoukd have it by monday, i called and was told, i would be receiving tge iPT60 torch, would you haveca link, to where i can order the consumables. .
    I searched the web, can't seem to find the, also i heard there were different sizes, based on materials being cut.
    Nov 2008
    Yes, If you go to our site and look under the consumables, select plasma cutters, the PT/ipt 60 consumables are listed.
    The PT or iPT 40 consumables fit as well, and are available from different suppliers, only difference is size of orifice. HTP offers them as well as plasmadyn. We are stocking the 50-60 amp ones in abundance. http://www.everlastgenerators.com/ca...ma-consumables
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    Thanks for the response, just curious, is a drag tip available, from anyone..
    Jan 2016
    I ordered a powerplasma 50 through HomeDepot. Was not sure what I would receive as it is still referencing the older PM50. I can confirm that I did receive the PowerPlasma 50S. It came with a PT-60 torch and five extra consumables. The tips had a 1.2mm orifice. The tip in the torch (pretty much wiped out for testing) had a 1.1mm orifice. I picked up a set of electrodes and tips from harbor freight and the electrodes look identical. The tip are .9mm however. This make sense since the HF unit is only 40Amps.
    I think it is going to be interesting playing with the different tips, airflow, and amp combinations.
    Now for something real important. How about a manual for the 50S? Not one to be found.
    Nov 2008
    It's online on our manuals page on our website. For some reason it was not showing up, but I think it is now. Try it again. Clear cache if needed.
    But here is direct link if you don't see it.
    http://www.everlastgenerators.com/si...asma%2050S.pdf
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    Quote Originally Posted by msimpson99 View Post
    I too bought mine at Home Depot, bought it there, because, they offer a 90 days return policy, and if i find its not working well, back it goes..
    When i saw that it had shipped, i figured ibwoukd call everlast, and ask which model, i was shipped, sure enough, i was sent the 50S, which i was very happy to see. .
    Jan 2016
    Thanks for the link. That's what I needed.
    To be honest I would have purchased the 80s if they had been available through HomeDepot. It show out of stock on line. Any idea when these will be available through home depot as I need one of these for research of my books.
    Correct me if I am wrong:
    For the PT-40/60 any tip 40 amps or under can be used as a drag tip (contact cutting as labeled)......... At least according to the diagrams/part numbers I have seen.
    Plasmadyn has some dedicated extended drag tips:http://www.ebay.com/itm/20pc-PT-60-P...YAAOSwEppUTZvi
    Nov 2008
    We suggest under 30 amps, but the tips you posted have the stand off for drag built in.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    Quote Originally Posted by punisher View Post
    Thanks for that link, i am gonna have to order them up..
    Jan 2016
    Got a set of the drag tips and electrodes linked above. Not having much luck with them. On very thin aluminum they work ok. On steel I find that the tip welds its self to the stock slightly and sticks. This makes them very difficult to work with. I just get the impression these are just a kludged version of a real drag tip system.
    Nov 2008
    No, but they are designed for use under 30 amps. These type tips have been around a while.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Jan 2016
    I tried 40 Amps and no go. At 30 Amps still a little sticky on clean steel. Well I have 10 sets so I have a few to experiment with.
    Feb 2016
    I just ordered the above mentioned tips, I plan on using them on 1/4 inch steel plate.
    Any suggestions on amps setting, for 1/4 inch, how about psi, would 60 psi, be fine..
    Thanks Eric
    Nov 2008
    Don't lower psi if you have the correct tips. Doesn't make sense. My rule of thumb is this: 20 amps for the 1st 1/8", 10 amps for every 1/8" over that.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    As some of you guys might know, i am new to plasma cuttters, so i was wondering, i have the PT 60 torch, which came with my Everlast 50 S, will all parts that state they are for PT 60, fit the Everlast PT 60 torch, i guess what i am asking is, is the PT 60 a universal torch..
    I was thinking of trying out a Retaining/Ceramic End Cap, heres the link, of the item
    http://pages.ebay.com/link/?nav=item...739087&alt=web
    Thanks Eric
    Hobart Handler 190
    Everlast Powerplasma 2016 50S
    Nov 2008
    I would think so. This is something new I think. It makes it look more like the S75, but the cup itself is pretty durable, the original one that is.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2016
    I just spoke to Richard over at plasmadynusa, who you recommended, and he said they are much better then the stock units that come from Everlast, he did say, the only disadvantage is, if you drop the torch, the ceramic ring, will break, very easily..
    I am gonna order up one, plus extra ceramic rings..
    He also suggested watching the swirl ring, he said if that takes a dump, it will destroy the entire torch, justvwhat to lookout for, i forgot to ask..
    But he was very helpful
    Hobart Handler 190
    Feb 2016
    I opened up my 50S tonight, I never realized the amount of electronics that are involved with the working of a plasma cutter..
    Hobart Handler 190
    Delaware
    Always buy top quilaty swirl rings like the Trafimet PE0106, stay away from the copys or you may damage your torch.
    Here is a swirl ring that starting to burn from using S45 consumables on a PT40 torch. The plunger on the PT style torch's only move a little. The S45 plunger moves twice as far as the PT this will cause the pilot arc to try and find ground jumping to the torch body through the swirl ring.
    Primeweld dealer and tech support
    Feb 2016
    Ok, heres my plan, i want to build a splitter for my 220v outlet, cause when i start to build my bumpers, i will be using both my Everlast 50S plasma cutter, and my Hobart 190 Mig, during the build, but, NOT at the same time..
    I hate the idea of cutting some parts, unplugging the cutter, and plugging in the welder, so i figured i would build a splitter.
    Now to my question, would anyone know, what the amp/power requirement be, for the plasma cutting, when ON, but not being used..
    I am thinking it can't be much, cause there is no demand on the cutter..
    Basically, i would like to keep both items ON, and go back and forth between them, but never at the same time.
    Btw, i am running a 50 amp breaker, wired with 6 gauge wire..
    Thanks
    Hobart Handler 190
    Feb 2016
    This is the one, i was looking at, its from plasmadynusa, a great seller on ebay
    http://pages.ebay.com/link/?nav=item...724164&alt=web
    Hobart Handler 190
    Delaware
    Quote Originally Posted by Liveinxs View Post
    Its a cheap copy.
    Feb 2016
    Which would you recommend...link?
