2016 PowerMTS 251Si Multi-Process 3 in 1 DC 250 Amp Pulse MIG/Pulse TIG/ Stick Welder - Page 3
Results 51 to 75 of 102
  1. #51
    Re: 2016 PowerMTS 251Si Multi-Process 3 in 1 DC 250 Amp Pulse MIG/Pulse TIG/ Stick We
    Good to know
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  2. #52
    I believe it was another forum member that put a colored dash on the feed roller and filmed it while welding. With some simple math he was able to determine actual feed rate. It's hard to do it otherwise.
    Everlast PowerMTS 211Si
  3. #53
    Oct 2016
    Orange County, CA
    Just purchased the new unit. I haven't un-boxed it yet but cant wait to test it out. Oleg Said it should come with the adapter needed to run the 12" Spool and i insisted many times that i wanted to order it so i will give an update on that as well when i do my unboxing tomorrow. Please if anyone has any suggestions or questions regarding this new unit before i open please ask so i can make notes and give you feedback. Box has some damage but doesn't look like it penetrated.
Size:  80.0 KBName:  IMG_1069.JPG
Size:  59.8 KBName:  IMG_1070.JPG
  4. #54
    Nov 2008
    Couple of things.
    First, the adapter is to fit the 8" roll. None needed for the 12" roll.
    Second start off with simple settings before working into more advanced ones as you get the feel of the machine.
    Third, if you have any trouble pm me and I'll get in touch with you and we can test things together, as I have a unit here that I am currently working with.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
  5. #55
    Oct 2016
    Orange County, CA
    Great, thanks for the information and the support. Will be in touch tomorrow hopefully with some test welds as well.
  6. #56
    Oct 2016
    Orange County, CA
Size:  106.8 KBName:  IMG_1076.JPG
Size:  63.8 KBName:  IMG_1075.JPG
Size:  73.8 KBName:  IMG_1074.JPG
Size:  95.9 KBName:  IMG_1073.JPG
    Looks All good so Far. Adapter is indeed for the 8" Spool and fits perfectly. New Drive roll Assembly looks bulky and strong. I used a similar competitor machine to come up with a Settings Chart. I know some people like the Miller Ap and i cross checked all the setting with different thicknesses and wire and they matched right up. I figured it would be easier for starting point reference then pulling out a phone everytime i had to check. Ill attach that in next post. Plugged her in to my 240V and she fired right up. Cant wait to lay some test beads.
  7. #57
    Oct 2016
    Orange County, CA
    Attachment 1526141 Attachment 1526151 Attachment 1526161
    Here is the Picture of the Chart and the Unit on. I know its nothing special i am just excited to show it. Also the Reel is a modified air hose reel i have mounted to my Mobile Welding Table that hold my 50' Cord. Will check back in once i get started.
  8. #58
    Nov 2008
    Don't coil your cord when it is in use. Bad idea.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  9. #59
    Oct 2016
    Orange County, CA
    Yes strictly for storage. Its plugged in but that was just to start the Unit. I know that the coil can generate a lot of heat under use and melt insulation over time. Very expensive cord i dont want to damage nor do i want to start a fire.
  10. #60
    Nov 2008
    It can also change the voltage, and create a magnetic field.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  11. #61
    Sep 2015
    Quote Originally Posted by MadWood&Fab View Post
    Looking forward to hearing about the performance. I've been back and forth between the 211si and 251si so this should help me make a decision.
    FYI - the attachments are not accessible.
  12. #62
    Quote Originally Posted by WeldMore View Post
    Get the 251!
  13. #63
    Quote Originally Posted by KMA View Post
    Get the 251!
    I 2nd that! 12" spools and pulsed spray
  14. #64
    Oct 2016
    Orange County, CA
Size:  127.2 KBName:  IMG_1080.JPG
Size:  120.5 KBName:  IMG_1079.JPG
    Not sure why pics didnt work here they are again.
  15. #65
    Sep 2015
    Quote Originally Posted by -Kevin View Post
    Hi Kevin and KMA,
    Some detailed performance reviews would be great. ALWAYS GOOD TO KNOW WHAT QUIRKS HIDE UNDER THE HOOD.
    I've been trying to get updated (DETAILED) specs on the 251Si to decide if the differences are worth the extra bucks. The web site has not be updated yet. Anything else besides pulse MIG (nice to have) and roll capacity (not needed) to squeeze the hard earned dollars out of my tightly clenched fist? Certainly the dual feed roller is also a plus if I want to run longer MIG cables (even if I don't run 12" rolls).
    Then there is the manual issue. I would expect the 251Si manual will not be available for quite some time after the 211Si manual (whenever that is).
    But I am still probably 251 bound.
  16. #66
    Oct 2016
    Orange County, CA
    Weldmore.
    The HF start for TIG is a prettty awesome feature and one of the reasons I picked up this unit. Also pretty good duty cycle compared to similar machines. Mine did come with a manual and it has the 251si part # on it but I haven't cracked it open yet. Will be doing so tomorrow. I am curious to see if it actually does reflect the current model as I have read that the manuals are usually outdated and useless. I will follow up tomorrow about that.
  17. #67
    The manual is a joke really. I wish they would hire someone to write a proper one.
  18. #68
    Nov 2008
    Hi Kevin and KMA,
    The website is up to date on the 251si. I'm working on final details of the pictures, but the information provided should be correct.
    http://www.everlastgenerators.com/pr...si-tig-package
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  19. #69
    Nov 2008
    I write most of the manuals. But it takes time and when you have a dozen manual updates and new ones to write along with other duties, it is no easy or quick feat. They need to be correct as possible and user friendly as possible. I tell customers that I talk to, to call me if they have any questions about the unit or its operation until it the US manual is updated. I have to use and test the unit and take notes along with trying to get a feel of the unit and all this takes time. But I am glad to test or work on an answer for any customer while I have the unit.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  20. #70
    Sep 2015
    The reason I thought the specs were not up to date is they still show 8" max roll diameter.
  21. #71
    Oct 2016
    Orange County, CA
    Well the manual i got is for the new model but its Choppy at best. Very hard to understand. I think the general basics are clear but nothing in depth or useful in trying to get max potential from the machine. Better off watching youtube or calling in if you need help. Lugweld.....do i need to register my unit or just hold on to the manual page that has what i think is a serial #?
  22. #72
    There's the initial "manual", and then there's the "real" manual that Lugweld writes for it after it had been released.
  23. #73
    Nov 2008
    I'd do both.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  24. #74
    Oct 2016
    Orange County, CA
    Well i definitely agree that they should hire an outside source to pick apart all the functions and write a legit manual. I dont think i will have an issue by just playing with the machine but still something that should be done.
  25. #75
    Oct 2016
    Orange County, CA
    Well i laid my 1st bead today using some scrap 2x3(3/16") just using some std chart settings. 19.5 volts,290 wire feed, inductance at 30%. .030 Wire w/ C25 @ 18cfm
    I am very happy to say the least. I cant wait to experiment a whole lot more. My shop is at my office so what little down time i have is when i screw around with it. Here is a pic of the bead. Nothing too amazing at but i m happy for only being a new found hobbiest welder for about a month now.
