Low budget rider leaf vac
Results 1 to 25 of 31
    Soda springs,Id
    Been working on this for several weeks. Got the chipper @ yard sale for $75. The screen frames were made from a bunch of clothing display racks I bought at a yard sale. The stock panel wire I already had. The discharge adapter can be removed just like the factory chute. I extended the tractor hitch out so it's vertical axis center is the same as the two elbows for turning rotation, Works very good so far. I have a screen door spring holding the two ells together. I built the tailgate hinges so the gate can swing all the way around to the side frame for dumping. I moved the tlr axle back so it would have enough angle to dump everything out. Then gave it a good spray of penetrol and two coats of paint. The tongue slides in & out so I can make it any length I want, Tho I like it the way it is along the the extended tractor hitch it makes backing the tlr very easy. I made this mainly to vacuum leaves in the fall but I'll also use it for chipping wood for mulch. I just need about 2 1/2 ft of 8" flexhose to reach from the deck chute to the chipper intake. I found some on the web for $10/ft min. 12 1/2 ft order. If anyone knows where I could buy some at a better price let me know, I'd appreciate the tip. I tried it w/ a piece of AC duct and it sucked up all the leaves I spread on the grass very well. I also like it higher off the ground so I don't have to bend over so far to stuff wood in the chute.
    Mike
    Soda springs,Id
    Re: Low budget rider leaf vac
    More pics
    Jan 2006
    In A Nice Comfy Chair
    That will get the job done in a hurry!!
    Nice job..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Oct 2010
    western kentucky
    nice job you did...
    i have a wagon just like the one you used, when you get it loaded they get top heavy pretty quick..
    get the flexible hose in there and you'll be good to go..
    again nice project.
    Soda springs,Id
    Thanks, guys!! If it acts a little tippy w/ a full load of chips or leaves I'll figure a way to put in a longer axle w/ outer bracing if need be. I figure if that chipper sucks as hard as it blows it'll do the job on the leaves this fall.
    Mike
    Apr 2010
    Shamrock, TX
    Looks good.
    Check out McMaster Carr and flexible duct for the hose. They have a large selection and 5' minimum order on what I got once.
    Millermatic 252
    XMT 304's
    Dynasty 280DX
    Hypertherm PowerMax 1250
    Miller Trailblazer 302 EFI
    Optima Pulser
    XR feeder and XR Edge gun
    and more at
    http://members.dslextreme.com/users/waynecook/index.htm
    Jun 2011
    Wallingford, CT
    That's some cool fabrication.. Those are popular here in New England for fall cleanup.
    Soda springs,Id
    Quote Originally Posted by irish fixit View Post
    Looks good.
    Thanks, Irish!! I'll check that out.
    Mike
    Lizella Ga.
    Amazon has 8" for $11.95 per foot.
    [ame]http://www.amazon.com/gp/product/B0006616BU/ref=noref?ie=UTF8&s=hi&psc=1[/ame]
    Aug 2009
    Sunnyvale, CA
    Nice useful, time saving contraption you have there. It looks like you welded onto some chrome plated steel in a few places, beware of hexavalent chromium production when doing so:
    http://weldingdesign.com/safety-regu...ews/wdf_54872/ and http://www.osha.gov/SLTC/hexavalentchromium/index.html
    Miller Dynasty 200 DX
    BuildPro TMA52238 (38" x 22")
    Miller MP-10 & Jackson Nexgen EQC
    Jet 414457 Mitering Bandsaw
    20 Ton Press & Swag HD Press Brake
    Oct 2010
    Fort Collins, CO
    Quote Originally Posted by dhem View Post
    uh...chrome? looks like galvanized to me...
    Soda springs,Id
    Yep,it's chrome. Clothing display racks. I had my swamp cooler going the whole time.
    Mike
    Livingston, MT/Houston, Tx
    Nice setup, and a different tire would help with the trailer being so tippy. Those tires that are on there are basically wheel barrow tires, upgrading to the same tires that are on the front of your mower would probably make a world of difference.
    Feb 2008
    Indiana
    Looks useful, the one I had would clog up with sticks.
    Makes a yard look nice after the leaves fall.
    How does the stove pipe "knuckle" work out? I wonder if it would bind and come apart. \Mine had the motor on the the trailer and flex hose going to the mower.
    Tim Beeker.
    May 2011
    wisconsin
    i wonder if u sucked up small rocks ,if they would blow through the stove pipe , prolly not real likely . ........... nice engineering !
    >Innovations are what i leave behind for History<
    Feb 2008
    Indiana
    I do know that hickory nuts make a heck of a racket.
    Tim Beeker.
    Soda springs,Id
    So far the knuckle works real good. I've driven around quite a bit and intentionally jack knifed it w/ no problem. I guess time will tell. If it starts giveing me grief I'll cut a couple of flanges out of 16 ga to run against each other attached to each ell.
    Mike
    Dec 2009
    Stevens Point, WI
    I built a leaf blower for the front of our mower out of a 55 gallon drum and a briggs. After using it a few times I think it would work better as a sucker like you built here.
    Jul 2006
    you may wear out the stove pipe. you will wish there wasnt a pair of 90's in it, and you'll wish it shot into the trailer higher up.
    I see why you have the stove 90's, because your engine is on your mower. they pivot at the hitch...but I think it may come to annoy you there.
    if you shoot more into the top of the trailer you can fill it a lot more.
    corigated culvert is cheap, while the proper smooth internal flexi hose is $$$
    a large corigated plastic culvert will handle tight turns and any bending due to hills, hitting trees etc... and they do last a year or more.
    i like your stock panel and fabric sides. alot, and the nice rear door.
    not to hijack, heres mine
    I ended up making a stainless chute from fan to hopper. it splits at the fan, as such is easy to clean out if it clogs when the hopper overfills because it pivots up with the hopper when you dump it anyway.
    also the mesh top sucked. replaced it since with rabbit hutch fence wire. about 1/2" square openings.
    why stainless? cause i just bought a TA185 and i had access to some old food service fryers that were scrapped. and hey, no rust!
    Jul 2006
    and edited
    Jul 2006
    edited
    Soda springs,Id
    Good job on the blower. How'd it wind up for balance? I like the plastic culvert, hadn't even thought of it. I'm going to go ahead and get two 8" adj. ells and some straight pipe to make the transition from deck chute to chipper intake. Once I get the ells in the desired position I'll tack braze them to hold that position. I'll see how long they last and then try the plastic culvert. Thanks for the ideas.
    Mike
    ps: were you hungry the whole time while welding that stainless,LOL??
    Jul 2006
    i balanced it by putting a shaft through it and some bearings and letting the heavy side roll to the bottom. then grinding a bit.
    the bearings were not even the correct size fo rthe shaft.
    The bearings were just sorta setting on my table and a stool next to the table. nothing fancy,
    it eats hedge apples.
    it gets yearly inspection. i have had to straighten them, and re-weld a few that started to fail. i run over fewer hedgeapples now.
    also, eventually the straight keyed coupling came loose and hammered my crankshaftt to death.
    i replaced it with a taperlock, (and new engine)
    It's a LOT of abuse for a briggs crankshaft. there really ought to be a torsional coupling. I get about 5 years out of a crankshaft doing my 2 wooded acres
    any looseness is instant death on the straight keyed shaft. even the taperlock works loose eventually. locktite it on the shaft.
    get a tapered and or splined shaft engine if at all possible.
    Ive devised a way to repair broken crank engines without taking apart. then they go into log splitter duty running a pump or somehting with no shock load.
    Soda springs,Id
    Do you think you could offset it and convert to a belt drive?
    Mike
  25. #25
    Jul 2006
    absolutely, but it would take up lots more space. and bearings. and pulleys etc...
    the little chipper like you used is a homeowner version and you will put more hours on it than the crankshaft was intended to take by vacuuming leaves. not knocking it at all, just saying. 200 hr design life on residential mowers. maybe 50 on little chippers, log splitters. etc... it's sad really.
    bright engineer I work with worked for Kohler, (they overbuild BTW . but he knows the design life and weak spots of all the competition having been responsible for testing and development. he was astounded that my fan lasted 10 hrs direct mounted on my crank.
    but then agrifab does exactly the same.
    I'm sitting in the vicinity of two broken crankshaft 6hp engines. mine and my neighbors . well i repaired mine and put it on a go cart, his is still broken.
    this is why you really would want a tapered crank engine wher the crank tapers up to about 1" and you draw the hub on with a nut. preferably and not the 3/4" straight keyed crank which is most common. I think i got 5 years out of my original engine.
    if belt driven it may last "forever". if not, I bet you get 5 +/- 2 years of collecting 2 acres of leaves. maybe a wash for cost. the extra crap will run some $$ and weight.
    taper crank example
    http://www.wallacecompany.com/machin...cp_6687-1a.jpg
    straight crank.
    http://www.arkansas-ope.com/BS_698172_H.jpg
