Everlast 140st issue
Results 1 to 13 of 13
    May 2015
    Barre Town, VT
    After many hours of trouble free welding my little 140st seems to have developed an issue. When it is plugged into 240v and I turn it on the amperage display briefly displays the set amperage an the fan starts up. Then display flickers off and displays 000 and continues to flicker with the power and warning LEDs lit. On 120v the display just stays 000 and doesn't flicker.
    It seems to be a control issue because it never went bang or smoked like they tend to do when a filter cap or IGBT gives up the ghost.
    Anybody know if there is a schematic for this welder or am I going to have to make it up as I go along?
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Nov 2008
    Re: Everlast 140st issue
    Just call tech support. 877 755 9353 ext 207. Easiest way (and best) way to get help. 9 to 5 Eastern.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    May 2015
    Barre Town, VT
    Thanks, I'll call them tomorrow. If it's set up like a typical switch mode power supply I'd say this smacks of an issue with the power supply to the oscillator board.
    My "collection":
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    May 2015
    Barre Town, VT
    Well I fixed it. It had a burnt out 12v regulator near the top of the welder. It's a standard L7812CV regulator which I happen to have a drawer of. I added a small computer fan to keep it cool and added a metal handle to take the place of the less than useful shoulder strap. I'm taking a page out of Mister Tig's book and calling this new and improved welder the IP140. It came from the factory as a good little welder now it is a great little welder.
    Here's the video of me fixing the thing and adding the fan plus handle.
    My "collection":
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Dec 2015
    Hey,
    I scrubbed through the video, whicle catching some points, even though I hardly know my way around a multi-meter.
    But you've obviously got some mad electronics troubleshooting skills, dude!
    SE Massachusetts
    Excellent troubleshooting, video and repair! Great idea to add additional cooling on the voltage regulator too.. The Everlast welder appears to be well made.. What's your opinion on build design and quality aside from this one flaw?
    May 2015
    Barre Town, VT
    Quote Originally Posted by Raybonz View Post
    Thanks! Their build quality seems top notch and all of the components are brand name. If you are really interested in how it works just look up "half bridge converter" in google because that's what this is designed around. It's a text book inverter circuit. I'd buy other Everlast welders.
    My "collection":
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    I am an interested lurker in these forums but registered for the specific purpose of complimenting you on this thread and your troubleshooting video. Outstanding.
    May 2015
    Barre Town, VT
    Well it’s been 8 months since the rebuild and it has been working flawlessly. Today me and a coworker were welding on a bridge joint and wanted to run two welders without having to drag two engine drives to the job so I brought in the 140st and ran it off the Miller Trailblazer’s 240v output while my coworker welded with the Trailblazer. We were burning 1/8 7018 at 125 and both machines were handling it fine!
    My "collection":
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Nov 2008
    That's just so neat.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Iain. I tinker in electronics. Your explanation of how that circuit works was excellent. Thank You!
    This was very informative. Thanks!
    Mar 2019
    Pittsburgh, Pa
    Thanks for the electronics lesson, now we know how these inverter welders operate.
    You should start your own welder repair company, you could get a lot of business from this forum, I bought a 252 Everlast machine and it already crapped out, two of the machine functions quit the first time I used them, the HF degraded and totally quit. It has AC TIG and the arc is unstable, it randomly stops for a split second and leaves contamination on the weld metal. Everlast was suppose to test and repair the AC circuit, got the machine back with the HF repaired but the AC circuit still does not operate correctly.
    Had a question I thought you might answer, will these Everlast welders operate in AC TIG mode with out High Frequency working?
