Miller Big 40 won't weld no AC - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
    Re: Miller Big 40 won't weld no AC
    Looking forward to the outcome
    May 2010
    HUNTSVILLE, AR
    Hi again I finally got the rectifiers but is not doing any good, Tried to flash again and can make a grinder run slow as long as I have the 12v hooked to #5 and #6 but as soon as I take them away it quits so I am lost at this point. Sure would appreciate any other ideas. Sorry for taking so long but there was a mistake on the order for rectifiers and took longer. Thanks alot
    May 2010
    HUNTSVILLE, AR
    Hi has anybody got any more ideas, Duane have you seen this would like to hear from you. Thanks
    May 2008
    Orange, TX
    Should have asked earlier - can you post the unit SN then PM me an email address?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  5. #30
    May 2010
    HUNTSVILLE, AR
    Thanks the sn is HJ 198309 But I think someone may have changed the front panel as some of the wires do not match so I used a manual from about a year earlier which is the hh series. The manual is the 450d.
  6. #31
    May 2010
    HUNTSVILLE, AR
    I sent you an e-mail address
  7. #32
    May 2010
    HUNTSVILLE, AR
    Just to let you know I have to be gone tonight but will be on here in the morning Thanks again
  8. #33
    Are you running it at weld rpm?
  9. #34
    May 2010
    HUNTSVILLE, AR
    Yes I am running it a weld rpm although I haven't checked the rpm I think it would be up close to what it should be.
  10. #35
    May 2010
    HUNTSVILLE, AR
    Ok just to let you know the rubber tip on the carb needle seat broke off this morning so right now it won't run till I can get one. This thing had been sitting along time is the reason that happened i'm sure. does any one know the right kit # for the zenith carb on this? Also Duane I got your manual on this but would like for you to explain where to get the voltage readings you are talking about as I just want to be sure I am doing it right. Thanks very much.
  11. #36
    May 2010
    HUNTSVILLE, AR
    Just an update on this I got this to running again and did more testing only to find that I that I that a ohms check from wires 50 to 51 shows open and have checked them down to where they connect to stator and are ok to there so I assume I am looking at a bad stator although as I had said at the first of the thread I checked then and they showed ok so I am not sure what's happened but that's what it shows now. Any ideas appreciated. Thanks
  12. #37
    RRWRITER
    First - not meaning to hijack / just thought this was a very good place to ask question on BIG 40..
    * I have a question for you on flashing ... Where exactly did you hook your 12v dc to flash.. ( side note - I just learned via this thread you shouldnt disconnect the leads #5 #6 at all )..
    Right know all i have cell phone internet.. Light years better then not having internet. But takes 10 times konger when if had a laptop / 15 inch screen lol.
    Note on rectifiers.. If they are cheap i am replacing all 4.. Just because..
    Thx for taking time to document your troubles on a BIG 40G?
    Thx in advance for any input..
  13. #38
    Check connections on the corncob resistor things. I had the one behind the front panel burn replaced it. Now the one by the engine is messing up.
    The strap doesnt make a good connection around it.
    I can tell at an idle if it is or isnt because when it is it has a slight load on the motor. I think I fix ed it but had to jump up in truck and jiggle it or pull the wire off the strap and put it back on.
    I sanded strap and corncob along with female wire connector.
    I cant remember if it puts out ac power or not when those aren't working it was one or the other or both.
    Those 2 corncob things and r1 r2 most likely are why yours isnt working.
    The big 40 I'm finding to be a hell of good welding machine. Now that I'm gett the bugs worked out
  14. #39
    Nov 2012
    did you get the big 40 working yet?
