Everlast Customer Service - Page 2
Results 26 to 38 of 38
    Re: Everlast Customer Service
    Quote Originally Posted by Copper_Head View Post
    The China tag does not bother me. I will certainly open the covers and inspect the welder and post photos. I have repaired very many machines over the years and know that good design and good components make a machine durable, not necessarily country of origin. Although really bad designs and mystery electronics are most likely to be encountered in Chinese tools, I have purchased a handful of jewels as well. I have a no name milling machine that is virtually identical to a top import name machine that a friend of mine has, except for the color. No way did anyone clone the castings so perfectly. I'm almost 100% certain it's from the same factory though I paid one third the price of the brand name import.
    Conversely, I just repaired a neighbor shop's plasma cutter. Ughh!!! Sub-boards and ribbon cables everywhere. Fortunately, board mounted fuses where OK and a thorough cleaning and cable reseating cured it for now, although it took awhile to clean all the (way too many) internal connection points.
    Be glad that box wasn't filled with skin care products. JUST KIDDING, Lug.
    Fabricator 252i
    FP120
    Cutmaster 42
    Nov 2010
    I have really wanted to purchase their multi process 221 welder but I am just too concerned if I have trouble getting it or have problems. I am just a small business and cant afford to make a mistake.
    Tom
    Sep 2012
    Cupertino, California
    I've had good and imperfect experiences with Everlast, but mostly good! I don't expect perfection, but I do expect to get attention when I complain by phone and to lugweld who is a responsive liaison. Just be upfront, honest, and patient with your complaints. So I'm STILL a happy Everlast customer, despite the lack of perfection. If you always expect to receive perfect/good customer service from any manufacturer--good luck with that! My .02
    Agape Guy
    Everlast Power I-MIG 200 (dual voltage)
    Everlast PowerArc 200 stick
    Hypertherm Powermax 30
    Way too many power tools
    AWS Member
    Sep 2012
    Hi Copper Head, so what's the update? Pictures please of some welding with the Everlast and what your initial assessment is of the product quality after using it, at your convenience.
    So, talking with the sales person six weeks ago, they said Everlast costs a little more than the cheapest imports but is much better quality, because they are NOT made in China, but Korea or Indonesia or something. OK, I can accept that as they do publish a 5-year warranty...
    Ummm.....LOL
    Attachment 1690045
    Well whatever, "the proof is in the pudding" so we will put her through a couple jobs to see how she stacks up before I take her home to my workshop.
    Sorry, IDK why these are rotating
    Attachment 1690046
    Attachment 1690047
    Agape Guy
    AWS Member
    Aug 2018
    Quote Originally Posted by Agape Guy View Post
    The older Syncrowave 210 has a smaller, smoother, more focused cone. Seems to heat better at less amps.
    The Everlast is fine on outside corners, even running these without filler, the puddle moves very well and smooth and flat.
    It just seems to fight on inside 90s, Tee joint. This should be an easy weld but it seems to need significantly more heat than the Miller to get a puddle going on this type of weld.
    Using the pulse does improve things, yet I feel like the amount of pedal I'm using to get the weld I want is border line too much and certainly more than on the Syncrowave.
    It is nice and compact and should be a good home gamer machine, which is the whole point to begin with. I want to get more confidence with it on mild steel then try some aluminum before I take it home.
    I've been super busy, 65+ hours a week right now. If I can get a chance I should do some side-by-side photos of the welds, Everlast vs Miller.
    Nov 2015
    Beacon and Pawling, New York
    Everlast customer service is why I now own a HTP221!
    Nov 2008
    Cone focus is a function of AC frequency and somewhat less, balance. Also amount of pedal needed is a relative thing based of linear qualities of the pedal potentiometer. The 210 unit has a very linear potentiometer now. Also the quickness of the wetin will depend upon the wave form.
    If you care to post up your settings, maybe we can figure out a way to improve the areas in which you are struggling with the unit.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
  8. #33
    Aug 2018
    Ummm not using AC right now, welding mild steel. I'm leaving the amps up all the way and using the pedal.
    I'm having someone watch the amps and basically I am welding just under 90 amps on the Syncrowave and it takes about 120 on the Everlast.
  9. #34
    Nov 2008
    Worth checking calibration on both machines. Amps are amps. Volts are volts. Won't make a difference.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  10. #35
    Apr 2017
    North Jersey
    I've had nothing but good CS so far. I just communicated thru Emails finding out when my i MIG 140 would be shipped because it was on backorder. They were a little tough to communicate with when I made the purchase over the phone though, but it all worked out. Inverter arrived when they said it would.
    THAT'S HOT!
    EVERLAST POWER i MIG 140E
    *SOLD - Forney Easy Weld 299 125FC
  11. #36
    Oct 2016
    USA
    glad he got his order but can't stress enough that complaining here is not the way to get customer service from Everlast. This forum is provided as a convenience so we can discuss their products and maybe get light tech support from person like lugweld. A phone call is the first and best policy, short of a face to face meeting.
    There is so much email traffic now, legitimate and otherwise (decidedly otherwise thanks to entire underground networks of spambots) email is really the method of last resort if you are expecting any kind of immediate response. My own experiences certainly mirror that.
  12. #37
    Jan 2017
    Greeley, Colorado
    I have been an Everlast customer for almost 3 years. Up until now I have never had to contact customer service. Recently I discovered that on an older shipment an error had been made by the Everlast shipping department. I thought that too much time had passed before I discovered the error for any compensation to be considered by the company. I decided to at least let the company know of the problem, with no real hope or expectation of anything. Within a couple of hours an offer of compensation for the error was made and accepted. Thank you so much for the awesome Everlast customer service.
  13. #38
    Same thing happened to me get a tracking number and didn't ship the unit they said they had in stock. Then I call and was told its 30 days out. I requested my money back and they tried to tell me I had to wait no refund. So I had to cancel my credit card purchase and file a complaint with my cc company. Awhile later I get a call and was told they would refund me. Total nightmare, its a shame because if they were as good as they claimed I was going to update the whole shop with new equipment. I still want one to try but cant get past the way I was treated. I dealt with the SF CA office.
