3 point winch/pole setup
Results 1 to 14 of 14
    Has anyone built a winch/pole setup for the 3point on a tractor? I have the poles, winch, channel iron etc to fab it. Looking to get more lift capacity off the rear. Plus I could adapt it to fit the bucket on the FEL to place rafters or items where extend reach would be nicel Any pics or thoughts?
    PDX PNW
    Re: 3 point winch/pole setup
    Welcome to the forum
    Quote Originally Posted by brushtrooper View Post
    In the mid 90's I built one for a farming outfit that fit the quick hitch on a 4850 John Deere tractor, Had an 18' boom made from 4"x6"x1/4" tube, used a 5"x36" cylinder to raise the boom from 0 degrees to 75 degrees. It had a set of feet that were used as outriggers when you set the 3 point down, had a 2500# hydraulic winch with a snatch block with 3/8" wire rope. They used it to setup and repair Center pivot irrigation machines. It was very easy to hook up and unhook, place the boom at zero degrees, drop a "kickstand" on the end of the boom and set the 3 point down til it sat on the outrigger feet. Pop the hoses and locks on the quick hitch and drive away. No, I have no pics from back then.
    Thank you, I was registered as saltbranch here at one time. I cant recall the PW so after a few tries I created a new account. I think I would be classified as a hobby welder. I am not a pro by any stretch, but I do enjoy the fabrication side and learning from folks in the business.
    Soda springs,Id
    farmersamm was starting a project on one but he got himself on a forced"sabbatical'" for now. maybe he'll return.
    Mike
    Jan 2011
    Tx
    Mike
    What the hell did Sam do now?
    Miller Bobcat
    Harris cutting outfit
    Miller spectrum 625 plasma
    Variety of shopmade tools
    I did a forklift on a 3 point
    Works great in and shop
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Soda springs,Id
    Quote Originally Posted by jw3 View Post
    Don't know for fact but I'm guessing he let the barleycorn start doing the typing.
    Mike
    Mar 2017
    bar stool
    Just look up AgCrane
    They come as close to doing it safely as can be done.
    Relying solely on 3 point arms and the toplink once the boom goes above 45° gets very unstable, on the boom even if you don't flip the tractor.
    What in Sam Hell !
    Usually curved for three point. If you have a front end loader, why the 3 point?
    As a teenager, I didn't have a loader, and my tractor was a Farmall Cub. I had a 1936 1-1/2 ton Dodge truck with an A frame off the front bumper. It was all come along work. I'd erect it laying two 20 foot trusses made from curved 2x1x1/4" channel on the garage roof. I'd pin the base of each to the truck bumper, then bolt them together on the roof. 2 comealongs were hung from the top, along with two cables. One went to the rear of the truck, I'd use it to hoist the A frame, then connect the cables to the rear corners of the truck frame. This was crude, but served as a means of lifting things too heavy for mortal lift.
    When I first owned a three point tractor, I contemplated such a device, but found a loader to adapt to it. I was dumbfounded to find that although it came from a very different tractor, it bolted to mine.
    I still have that tractor, 32 years later. #2 son removed the loader 'cause that day he believed it'd be slightly more convenient without. It never got put back on. These days it's the Case 580K multi tool, or a IH 385 with full hydraulic loader.
    There are things that my FEL does not have the power to lift. With the W/P setup I can get more leverage to lift heavier items.
    Have you checked how much Hydraulic pressure the tractor is putting out?
    If it’s low you can shim The pressure relief valve spring.
    Oct 2011
    Elkhorn, WI
    Well?
    Till the Front Axle breaks!
