Flashback arrestors...do they go bad?
Results 1 to 11 of 11
    Aug 2007
    Kind of an odd question, but short of any obvious damage, do flash arrestors go bad? I picked up a couple sets in a package deal of stuff, and while physically they look OK, they are clearly not new. Any reason to avoid using them?
    Re: Flashback arrestors...do they go bad?
    I have the acetylene ones plug up to the point where there was almost zero gas flow.
    Aug 2007
    Was it fairly obvious by looking at them?
    Yeah, they had a somewhat wet black soot in them.
    Feb 2010
    Northern MN
    Aren't they basically a brass foam filling? I'd say short of plugging or being mechanically damaged they shouldn't go bad
    According to the manufacturers they should be replaced every 5 years. At least thats the way it was the last time I looked into it. With that said I have not done that with my personal ones. When I was a supervisor for a large construction company I did it every 5 years.
    Aug 2007
    Here are a few pics...
    Jan 2016
    they are cheap enough to replace for what they may save you from, why temp fate, buy a new set..heres hobarts for a reasonable price less than $8.00 a year if you replace every 5... https://www.amazon.com/Hobart-770506...hback+arrestor
    Apr 2008
    NW ON Canada
    I've had them fail in the past, wouldn't allow any gas to pass through. It's not real common but it can happen.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Not there
    I just run at the regulators.50 feet of acet hose exploding is kinda neat.
    I like a light handle. Nothing there. These are 12 or so years old. They don't get hot way over there...probably why they stay mint.
    Mar 2017
    bar stool
    It generally begins with the flashback preventers hanging around with dusty regulators in a dark corner of the shop.
    Then you catch them rolling their own
    Then they get plugged up.
    Saw one open look at the contents and post seeking suggestions on how to MIG them back together.
