Porosity while using flux core wire
Results 1 to 16 of 16
    Hi there,
    why might I be getting porosity in my welds while using flux core wire? The wire I am using is virtually new. It's Lincoln brand. TIA.
    Re: Porosity while using flux core wire
    Reverse polarity???
    More info would help
    type of wire, type of machine, type of metal being welded, what kind of prep, settings on machine, etc...
    Port Orchard, WA.
    Are you talking about self shielded wire, or dual shield wire?
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    I am using a Lincoln Promig 180, self shielding wire, A36 mild steel, prepped to being shiny steel, voltage setting is on "C" with a wire speed of 4. The steel thickness is 1/8". The wire is Negative. Thanks.
    Port Orchard, WA.
    How much stick out are you running? With T-11 self shielded wire I run about 3/8”.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Between 3/8 and 1/2,
    Port Orchard, WA.
    What is the number on the wire you are using?
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Quote Originally Posted by cep View Post
    what is the number on the wire you are using?
    nr-211-mp
    Not there
    Lost here.
    Are you pushing your weld like hard wire/gas or (correctly) dragging with some angle to keep the flux out of the puddle ?
    Lost here.
    I'm dragging the weld. I have always heard "if it's slag, you drag". Maybe I don't have enough angle of drag.
    You getting the porosity in the first pass, but not after that? If so your not hot enough.
    Just running single pass so therefore I probably need to turn up the heat some. I'll give that a shot and see what happens. Thanks
    Jul 2012
    Lincoln video on how to run NR211MP
    Northern Cal., Shasta County
    I don't care for a steep gun angle, I run almost perpendicular a lot of times.
    I believe the video above from Lincoln would be twice as helpful if it showed a clear view of puddle behavior.
    When I manage to get things where I can watch puddle my bead improves measurably. Instructions always warn about slag inclusions when puddle outruns wire or excess heat cause's agitation but how can you tell when you can't even see the puddle. Watch some videos where the camera show's puddle clearly then do what ever it take's until you see your puddle ( cloth covering back of your head,lighting the surface well,corrective lens and/or cheater lens.
    Nov 2004
    Missouri
    I agree. I would think a company the size of Lincoln could afford a filter plate for the camera so you could watch the puddle.
    Trailblazer 302
    Hobart Stickmate AC/DC
    Lincoln SP 135 T
    Smith torch
    Spoolmatic 30A
