Commercial Fishing Vessel- Sponson & Lengthen
Page 1 of 7 123 ... LastLast
Results 1 to 25 of 167
    May 2013
    Oregon coast
    Going from 54x17 to 58x24- Will post progress pictures from start to finish, ask away...
    May 2013
    Oregon coast
    Re: Commercial Fishing Vessel- Sponson & Lengthen
    Removing old bow
    Sechelt, BC
    Holy crap! Don't keep us in suspense, want more pictures!!!
    This should be a great thread!!!!!
    How deep are the 2 foot sponsons going to be?
    EDIT: Oh yeah on what Xsbank said.. post up plenty of pictures
    Mar 2005
    Under a Rock
    Wow !
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    May 2013
    Oregon coast
    Removing stern, cutting out lazzarette, fuel tanks etc... to the aft fish hold bulkhead. Bow cut back to the engine room bulkhead. We removed about 10,000 lbs of concrete in the bow and lazzarette. Pre fabricated bow to be installed next... For timeline purposes, the torch was first lit on 08/20/2018. All the work performed by three incredible craftsmen
    Jan 2012
    West Rutland, Vermont
    When I look at something like this I first think WOW! That's some kinda special work. Then I wonder if it wouldn't be almost the same $ to just build a new one?
    May 2013
    Oregon coast
    Bow being installed, 60inch bulb which will be the fresh water tank. Side plates of hull cut out to expand engine room and fish holds...
    Apr 2016
    CA
    Quote Originally Posted by beaver View Post
    ask away...
    Who's the person wearing the Seagul $hit Shield on the front of the boat in the first picture? Joke Looks like a lot of work.
    Lincoln, ESAB, Thermal Dynamics, Victor, L-tec, Miller, Dewalt, Makita, Kalamzoo. Hand tools, power tools, welding and cutting tools.
    May 2013
    Oregon coast
    This is literally a fraction of the cost of a new 58 footer
    May 2013
    Oregon coast
    Very well planned process, the boat was 3D laser measured so the naval architect had a perfect model to build around, we have 4 modules that were designed and pre cut, labeled and marked.
    Jul 2013
    Thank you for sharing this re-build with us. I find projects like this very inspiring. Look forward to seeing her splash in her new form.
    Sechelt, BC
    Im sure you have though of everything [8^)] but don't forget to install a clean-out in your water tank, I just had to clean mine out once again after having installed 4 hatches to get in there...
    Jan 2010
    Northwest Missouri
    Thanks for sharing the project, Beaver! Keep the pics coming.
    OK, just out of curiosity, I assume you have to do some sort of weight/balance/stability certification after such a major rebuild. Kind of similar to what we have to do on aircraft whenever we make an airframe modification. Who has authority? Coast Guard or some other agency. Do you maintain a separate ships log for maintenance and repairs?
    Roger
    Old, Tired, and GRUMPY
    Salesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!
    Dial Arc 250HF
    Thunderbolt 225 AC/DC
    Assorted A/O torches
    May 2013
    Oregon coast
    The coast guard requires a new survey and a stability test, both performed by private parties. We have weighed all of the steel and concrete and noted where it came off the boat for the naval architect. And yes we have maintenance log ever since we’ve had the boat
    Tampa, Florida
    Love watching these types of large scale projects, keep on posting!
    -Mark Smith
    Vulcan ProTig200
    Vulcan MigMax215
    Everlast PowerArc 210STL
    Hypertherm PowerMax45 Xp
    Jun 2011
    Aiken SC area
    Thanks for posting, great to see this build. Bob
    May 2013
    Oregon coast
    Before side plating, new stainless fuel piping in. After plating, using long sheets very few weld seams. Time to start welding out while waiting for stern pieces to arrive
    May 2013
    Oregon coast
    Here's what we are waiting for from the cutter, stern section, built in fuel tanks, large lazzarette. This is a large piece, it will be built onsite and then installed as one module. it is 24ft wide x 15ft long
    Jan 2012
    Amazing stuff. Hard to fathom (no pun intended) this type of work. You make it look easy.
    Wenatchee Washington
    Thank you for taking the time to post and explain the project. I really enjoy seeing these types of upgrades Keep em coming, good stuff!
    Lincoln Precision TIG 185.
    Flex-Loc 150 torch.
    Super-Flex hose.
    Lincoln MIG 180.
    Victor Oxy/Act torch set.
    DeWalt Bandsaw with SWAG stand
    Jul 2011
    Bossier Parish La.
    Will the rudder and steering gear be located in this new rear compartment or fitted back where it was originally? Hard to tell from the pix if that area was removed or not. I see the rudder is missing, but figured it may have just been removed to make the work easier. How much extra fuel capacity will this add to the boat?
    May 2013
    Oregon coast
    Rudder removed but will go back in same spot, we completely removed all of the stern to the back fishhold, steering will be in same place before but overall stern will be 2ft longer, our fuel capacity will go from 2500 ish to 6500- six tanks, new fuel transfer system which we didn’t have before so we can trim the boat with various loads and weather
    Jul 2011
    Bossier Parish La.
    So you're going to end up with about 150% increase in fuel capacity and be able to go out farther or stay out longer without the fuel and freshwater restrictions you had before. The next limiting factor to remaining out on the fishing grounds will be the amount of food for the crew that can be taken along.
    Oct 2011
    Hamlin, NY
    Excellent work, I can see the craftsmanship from here!
    Ryan
    CK WF1 TIG wire feeder
    Miller Spectrum 375 Xtreme
    Optrel e684
    Miller Digital Elite
    Miller Weld-Mask
