Oxygen generator for torch?
Results 1 to 21 of 21
    So for starters I don't know too much about oxygen generators. But a decent sized and pretty cheap oxygen generator was offered to me recently, and even though it would be a bit of a learning curve and setup I admit it would be pretty neat if I could hook it up in my garage shop to run my oxy/acetylene torch off of.
    Has anyone had experience with useing oxygen generators before? Nearly all Google searches come up with medical uses and barely any mention of useing one for welding/torch stuff. Is it because new O2 generators are too cost prohibitive compared to just filling an O2 bottle at the store? Or is it just a dumb idea that doesn't work well?
    Mar 2017
    bar stool
    Re: Oxygen generator for torch?
    They come in two different models, one that direct connects to the patient for want of a better description, and one that will fill small oxy bottles.
    The model that fills bottles can be adapted to run a torch, but I have no information on cost of operation.
    There is also the question of purity of oxygen delivered by the machine.
    Best advice would be try before you buy.
    Feb 2012
    Sweden
    I recall reading about someone who got a number of replaced oxygen generators from a hospital years ago, on another forum. I'm really not sure, but I think it worked resonably for cutting, but not for welding - unlike bottled oxygen the generators don't provide pure oxygen, there's still quite a bit of nitrogen in it, especially when the generator has to supply gas as fast as it can.
    Mar 2017
    bar stool
    Quick check of information indicates oxygen concentrators for medical use do not deliver pure oxygen to minimize the possibility of the patient becoming Hypoxic.
    Rough calculation indicates the machines are capable of 25% purity on the 2L per minute setting and max out at 45% pure at 6L per minute.
    Not really near the percentage needed to run a torch properly.
    Jan 2010
    Northwest Missouri
    Yep, the device in question is an “Oxygen. Concentrator”. They do only multiply the available o2 to around 40-45 percent of output by volume.
    Cost to operate? About the same as a small refrigerator on an annual basis.
    As far as welding? NOPE it ain’t gonna happen unless you talking a very small jewelers torch, and then it would be questionable. NOW, that being said, the glass benders and artist do utilize them to generate more heat in their air/fuel torches.
    Roger
    Old, Tired, and GRUMPY
    Salesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!
    Dial Arc 250HF
    Thunderbolt 225 AC/DC
    Assorted A/O torches
    Long Island
    Oxygen concentrators work by using a molecular sieve to remove the nitrogen from air. Because of this, at best, they can only deliver 95% oxygen, which is really not good enough for cutting. Add that to the fact that the output pressure and flow is too low to cut with, and you may not find one useful.
    Glass blowers however who heat with oxy-fuel use them often.
    Looks like this one only produces 93% 02 http://www.oxidationtech.com/og25.html
    I started looking at required 02 for cutting after a few of your responses. Turns or 95% will sort of work ok but 99.5% that comes from the cylinders is optional. Looks like I'll pass this deal by then.
    Mar 2017
    bar stool
    Pretty much the same process as Nitrogen generators sitting unloved in tire shops.
    Just a different charge in the cylinders.
    ct.
    Does anyone still use acetylene generators?
    I’ve never seen one in use, only seen pics
    and heard old timer’s stories.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Jan 2010
    Northwest Missouri
    I’m like you jpump, never have used one, but in my younger days I did work in a shop that had once used a gas generator. It was still in place and remnants of the rather sophisticated plumbing for gas distribution to the work stations remained. One of the old German coach builders explained how it worked to me. He made it perfectly clear to me that the young people of the day had it all soft and cushy (that was 50 years ago). From my understanding of the operation the threat of an inadvertent over pressure or leaks in the delivery system had to make them an interesting proposition. The old timers used them because it was what they had available. They knew the risks and planned accordingly.
    I’ll gladly leave the Acetyline generation to the commercial gas suppliers and continue to pay for the convenience of bottled gasses, Thank You.
    Roger
    Dial Arc 250HF
    Mar 2017
    bar stool
    Read up on how the city of Speedway Indiana came into being, and you quickly understand the fear of acetylene gas.
    Yes, I used one, 60 years back, and it was a wonderful thing beyond listening to Old Bill growl at me. Also chopped dry ice into a tank and held the hatch in place till the pressure kept it there to get Co2 to fill fire extinguishers. Both systems are long gone to remelt because Insurance Carriers decided something they couldn't understand was too dangerous to cover.
    Insurance carriers also decided acetylene and gasoline were unsafe fuels for home lighting and cooking, and forced replacement of hollow wire gasoline lighting systems with propane systems. Neither was dangerous when operated by qualified people, and some hollow wire existed in NE NY and Vermont into the 50s. Electricity didn't become totally available in NY until the mid 50s, and many farms still got electric from Kohler and DelcoLight plants that self started when the light was switched on.
    Dec 2008
    Way back I used to use a acetylene generator on my head.
    Let's see who figures it out first.
    Jan 2010
    Northwest Missouri
    You were either a coal miner or a coon hunter.
    Roger
    Dial Arc 250HF
    Northern Cal., Shasta County
    Quote Originally Posted by Rog02 View Post
    Lot of interesting stories the old timers used to tell about coal miners, acetylene head lamps and out houses. On the way out of the portal for the shift the miners would visit the out house & empty their bladders and empty their head lamps.......... out houses could be a dangerous place for smokers.
    Dec 2008
    The coal miner is close but not quite.
    ct.
    Or a spelunker?
    I remember one supplier of outdoor gear
    for hiking, climbing,caving etc. selling
    headlamps and calcium carbonate (I think)
    powder. Early ‘70’s.
    Millermatic 180
    Purox O/A
    Mar 2017
    bar stool
    Or a spelunker?
    Thanks for the laugh.
    It's Calcium Carbide, and it goes bad sitting on the shelf even in a sealed container.
    Now I gotta quit thinking of a fat cave crawler sitting in the dark trying to refill his lamp and wondering why his Celular device has no bars in the cave he just had to crawl into.
    May 2015
    Barre Town, VT
    I’ve seen a couple of old acetylene generators in an exibit at a local fair. They look interesting and I’m sure they worked ok back in the day, I even have a couple books from the 1940’s that go over how to opperate them. If I could get my hands on one I’d put it in the barn as a conversation piece but I think operationg it would be more trouble than it’s worth. I don’t know where you’d get the carbide and then you have the sludge to get rid of. Plus the possibility of going boom would make me a little nervous.
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Mar 2017
    bar stool
    You put the sludge in a double bag and drop it off at Ben & Jerry's ice cream factory. Once or twice a year they make a limited batch of Old Weldor from it.
    The generators are still made and still in use around the world where Wimpboys from Insurance Carriers who believed everything the instructor said was gospel don't rule.
    Only hazard is from overpressuring the gas chamber, and that usually follows some stingy plick wiring the safety down.
    ct.
    So Rex,can we now assume you were not
    mining, hunting or caving?
    Millermatic 180
    Purox O/A
    Dec 2008
    Sorry for the slow reply. Been busy at work.
    Spelunker is correct.
    In this part of Texas caves are a major source of recharge for our aquifer.
    In the early to mid '70's I helped a group of guys that were doing cave surveys for the state.
    All of the headlamps back then were acetylene. First battery powered one I saw was in the '80's.
    It was kinda tricky changing the carbide in the pitch black especially since we always carried out
    our carbide waste. But we did carry out our human waste also!
    Spent 21 hours in a cave in Mexico. Seemed like our packs were heavier coming out than when we went in!
    I really miss caving but I'm too stove up for anything but a walk in cave.
