ID some tools....
Results 1 to 12 of 12
    Jun 2007
    ID some tools....
    I bought a box of tooling and I'm not sure what some of this stuff is for...
    Outside of Raleigh, NC
    Re: ID some tools....
    Kevin, I Can’t say that I recognize any of them, but am interested in learning more.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Dec 2008
    The one just to the right of the file handle "looks" like a knurling tool.
    new york city
    i'd be interested in what that thingamabob clamped onto the file is.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Jun 2007
    I also got these 14 ??? Kinda looks like line up tools. They are all stamped with a size.
    One the bigger one the stamped size is the middle step. One the smaller ones the size
    makes no sense. The name REED MFG Co. is also stamped on each one. 1/4" hole in
    each handle. All are bored 3/4 of the way threw. Ends are not sharp so they can't be
    punches.
    Jun 2007
    The things that look like files I was thinking they look like scrapers bit
    they look to be soft metals.
    Jun 2007
    Typing in google Reed Tools Punches I found something that's called flare punches.
    Maybe that"s what i have...
    https://www.amazon.ca/Reed-HF2-Hamme.../dp/B001H4M0BK
    EDIT....
    Yep that's what I got... Wonder what they flare?
    https://www.ebay.com/i/232773928336?chn=ps
    EDIT... Again....
    Suited for flaring Type K copper tubing with water in the service line.
    Make 45-degree flares with pressure relieving hammer flaring tools for copper tubing.
    Hardened and tempered to resist wear.
    Wonder if they need an anvil ? Guess these are for flair nuts.
    Apr 2012
    Amity, OR
    Items marked RED are turret lathe/screw machine tooling. Far right one is a box turning tool
    Marked PURPLE is base holder for a grinding wheel dresser for a surface grinder, or at least it is similar to one I have.
    Marked ORANGE are brass center inserts for rifle barrel turning to prevent damage to the bore.
    Marked YELLOW is an internal roller burnishing tool for final sizing bushings and bores.
    Marked GREEN are Anderson hand scrapers for rebuilding machine tool slide ways.
    Jun 2007
    Doesn't the hand scrapers have to be hard steel? What are the slides for?
    Apr 2012
    Amity, OR
    The slide thing locks the insert blade on. https://andersonscraper.com/product-...hand-scrapers/
    Mar 2017
    bar stool
    The Reeds are "hammer flares" used on K copper tube as was once common in underground water lines from main to house.
    Type K wall thickness is more than the well known conical flaring tool will handle, but it's easy enough to flare with a ball peen hammer once you get to above 1 1/4 size. Takes a man who knows what he's doing about an hour to flare 11/2 with a hammer. Takes about a week for him to stop bichyn if he forgot to slide the flare nut in place first.
    Hammered flares are also one of the best reasons to apply a finger full of grease between copper & nut when making the joint up so you don't gall hell out of the flare and get leaks.
    Jun 2007
    Thanks.... Learned something new today....
