Welding a atv rear axle to its ring gear
Results 1 to 25 of 30
    Hi I would like to stick weld my axle on my atv to the ring gear it is slipping, any suggestions about rods etc
    Jun 2007
    Re: Welding a atv rear axle to its ring gear
    Ni-cads... Nickle rods any time that you weld hard or two different kind of steel together.
    Jan 2009
    North Chili N.Y.
    It will take the heat treat out of the gear.
    TIG brazing would be lees heat...
    SoCal-LA
    Er312 is your friend. Lincoln used to sell it as their "All Purpose Maintainance Filler". You can also find it now labeled as "SuperMissileWeld".
    I use it on gears and bearings. The high ferrite content and fast freeze attributes help prevent cracking. Tensile is above 100ksi which is a better match to the gears. You can find it as Tig filler or stick electrodes.
    Thank you I thought it would be different welding the too parts together I will read up on the nickel rods
    This is where I want to weld the housing slides over it so if it doesn't work or it breaks I can take it apart
    Thank you I will try to find out about er312 rods
    Dec 2009
    Stevens Point, WI
    Good advise to follow. Should weld up nice and away from the teeth. have at'er
    Quote Originally Posted by VPT View Post
    Which rod would you use
    How could I figure out what metal the parts are
    Northern Cal., Shasta County
    A lot of axle material and even the gears have a teeny bit of vanadium. Increases toughness and corrosion resistance. Do a search with 'axles crankshafts vanadium' .. Don't know that an atv would warrant a more expensive alloy but still it is pretty much standard practice.
    Mar 2009
    MN
    Id be worried about the axle wanting to break at the weld if that's a one piece axle like on a sport model.
    My name's not Jim....
    Jun 2017
    AJO, ARIZONA
    I think I would do a couple of good tacksmaybe 1/4 to 1/2' long 180* apart.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
    Dec 2009
    Stevens Point, WI
    Quote Originally Posted by Buzzboxer View Post
    The mentioned er312 or, since I have them on hand, I would use er308l, either will get the job done. Just don't cook the axle to much.
    +1
    Probably don't need much.
    Also, if I didn't have any super duper NASA missileweld, I'd probably use 7018, cross my fingers, and call it macaroni. I've gotten away with a lot of things I probably shouldn't have with 7018.
    Dec 2009
    Stevens Point, WI
    can't delete post, been drinking....
    Would you do a couple of tacks or weld all the way around? Does it need to be heated first ?
    Jun 2017
    AJO, ARIZONA
    I would do a couple of tacks, this will minimize heat input which will help with warping
    , the gear at least will have some heat treatment and the axle as well, if you don't know what you are doing then preheating may affect the heat treat. a couple of tacks with the 312, quick & easy, don't overthink it, make sure you get it cleaned of the gear oil, whatever you do, DON'T USE A CHLORINATED SOLVENT OF ANY KIND, you can use non chlorinated brake cleaner, spray carburetor/fuel injector/throttle body cleaner etc. I think the key is to minimize heat input, thus the 2 tacks, the first tack is going to try to pull the axle, and the second will pull it back, hopefully the gear is not sloppy loose on the shaft, if it is then maybe 4 tacks working to make sure the gear is straight and the backlash is right. Honestly I think 2-4 1/4" tacks will be just fine. Lotsa folks tend to overweld things like this.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    I have tried to find the er312 stick welding rods but I can't seem to find them even online any idea where to get them?
    May 2018
    the Netherlands
    Try searching for 312L-16.
    https://store.cyberweld.com/hobart-3...80630-rdp.html
    https://www.ebay.com/itm/Stainless-S...-/323155709819
    Certanium 707SP is also 312L-16 as far as I know but very expencive.
    https://www.lawsonproducts.com/Certa...rode/P12610.lp
    And the Super Missileweld Shovelon mentioned.
    http://www.harrisproductsgroup.com/e...ssileweld.aspx
    https://www.netwelder.com/harris-sup...18-electrodes/
    http://www.airgas.com/product/Weldin...y/p/HARULSMW60
    In Europe Lincoln has the Limarosta 312 but I can't find that one on the Lincoln USA site.
    I have 312L-16 rods from Lastek, but those are probably not available in the USA.
    If You really can't get some 312 rods, 309 will do it.
    Kemppi minarc 150
    Esab powercut 400
    hey, it seems like not a big, but a strong weld is needed for the first time only. then you can notice the performance and optimize how good it is performing. if you still hear those noises or whistles, do not ignore that alarm if you don't want to cause it to your life. Take is to an axle repair service to be maintained easily and properly.
    Never seen an atv axle. Do they just stick out like a stub, or are they supported at the outboard end by a bearing?
    Like this?????????????
    How in the smurf does the axle fit the ring gear......press fit?
    No differential????????????? I'm all confuseled
    Most all the {atv's} have solid axles on the rear, this is why they sell so many tires for them
