Welding a atv rear axle to its ring gear - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
    Jun 2017
    AJO, ARIZONA
    Re: Welding a atv rear axle to its ring gear
    How loose is the gear on the axle, if it's sloppy loose then it may cause more damage if it's not centered on the axle, if it shoulders up against something on the shaft, then I would seat it against the shoulder and add some pressure from a press or something similar and the give it a couple of smallish tacks 1/4" or very slightly more, 180* apart to keep things straight, otherwise it may mess with the tooth contact pattern.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
    I built a roller deal so I can turn suspension links while I weld.
    I think I'd burn it from start to finish.
    I to get away with alot using 7018. Id probly grab a rod and burn it all the way around.
    Might even be able to make that look pretty
    This hasn't came apart on my jeep axle yet
    Dec 2009
    Stevens Point, WI
    Thats pretty excessive!
    I usually just weld the spiders that ride on the pin and let the axle spiders float. It all gets the job done though.
  5. #30
    Nov 2014
    PDX PNW
    Preheat the metal first before welding
