Miller s32p wire feeder problem
Results 1 to 5 of 5
    South GA
    I just acquired a miller s32p wire feeder when i hook it up to my trailblazer and turn it on and adjust the wire feed it starts feeding wire. Pulling the trigger on the gun has no affect on it. I swaped out the gun and it has no affect
    Re: Miller s32p wire feeder problem
    Unplug the gun trigger. see if it stops. Might have a gun problem. Or a control pcb is bad.
    South GA
    Yeah ive tried unplugging the the gun. Same thing its like once you turn the power switch on the motor has power and starts feeding wire
    South GA
    Ok so I’ve unplugged the gun it won’t feed with the gun unhooked. But I took the new m25 gun off my millermatic 200 and it’s the same way. So the gun is not the problem
    Jul 2012
    Check ground wire/ cable or replace it.
