small pitting problem while using spray arc
Results 1 to 11 of 11
    Oct 2018
    Montana
    Hello ive been welding some 150 ton hydraulic rams/cylinders that run 10,000psi for our company for around 3 years now. I only do around 10 a year. I use a millermatic 350p, LA100 wire .045, and was using a 75/25 mix. I decided to switch to 90/10 so i could use spray arc mainly for this application. On the first 2 ive done, ive had a decent amount of small pitting and have been having to grind and re-weld. The tubing is made out of 4140 Q&T i believe. I basically weld a large threaded cap onto the end of the tube that has a big v-groove, and i do anywhere from 3-5 passes. Any reason the 90/10 would cause this? The 75/25 did this every once in a while, but I'm just making sure that the 90/10 isnt the problem. Name:  WP_20160512_003.jpg
    Ct
    Re: small pitting problem while using spray arc
    Any pics of the pitting? I just dabble in spray arc myself, not enough experience with it to really be of any help
    Oct 2018
    Montana
    next time i will try to take a few pics of the pitting, its real small, but at times can be throughout a few inches or so. I'm starting to think it has something to do the the type of steel. Being 4140 i believe its pretty high carbon, so maybe that has something to do with it, since i weld a few similar applications as well, but using a more mild steel like 1018 and i never have pitting. I also pre-heat these with a torch before hand, not sure if that makes a difference.
    I just got done with a good sized job using 90/10 gas and ER70-S6. Went right into spray, and if my standoff was too long it would bubble. I figured it was the intense heat in the spray arc. I kept the standoff short and cured the problem.
    Perhaps bigger nozzle and more gas would help?
    Oct 2007
    Vandalia, Ohio near Dayton
    X2. intermittent traces of what you call pitting could be a sign you're right on the verge of inadequate shielding gas coverage. A picture of what you describe would be really helpful in confirming the cause of the problem.
    But I think shovelon's advice is a good place to start.
    Just switching from 75/25 to 90/10 shouldn't cause any problems.
    Benson's Mobile Welding at your worksite or place of business. Serving Dayton, Ohio and the surrounding metro areas.
    AWS Certified Welding Inspector (#XXX10731) and Certified Welding Educator (#XXX1008E)
    Oct 2018
    Montana
    Im running 25-30 cfh for my gas on my millermatic 350p, you would think that would be enough right? But it is possible I had the tip a little far off at times seeing how I am just getting into spray, and using one hand to turn my chuck while running the gun with the other. I only welded two cylinders yesterday, but if it happens again on the next set i weld i will definitely take some pictures. Basically looks like a handful of small pinholes.
    Feb 2015
    On the 350p in pulse spray it seems to run hot and wants good gas coverage. Try going down a guage on the thickness settings if you are moving slower. I have a 350amp Tweco velocity gun and run the tip flush with the bigger nozzle, gas about 35 and run a tighter arc on the machine settings. I think I have a 3 second pre flow. I push only with a very slight angle, to much and it will pit on the backside. Hope some of this will help you.
    Not there
    Lose the LA100 and get a roll of S3. No S6 either. The 90/10 shouldn't be a problem..........unless the idiot it the mixer is named Kutk-Roy
    Oct 2018
    Montana
    i will definitely try upping the gas a little, and work on my tip angle, i do catch myself angling it at times on long welds while turning my chuck with my off hand. I think those two things should help out. I will also look into this other type of wire as well. When i first started welding these a few years ago I had terrible pitting, and i believe it was er70, so i was lucky enough to get ahold of the guy that welded a few of these for us before i stated and he said to use the LA100 and that he had the best luck with it. But that doesnt mean he didnt try everything. Thanks for all the input guys!
    Mar 2013
    Since you're welding on alloy steel I would be a little careful with the selection of wire and how you use it.
    http://weldinganswers.com/how-to-weld-4140-steel/
    Oct 2018
    Montana
    Thanks for putting that website on the thread. I ended up posting to that thread and they told me to continue to use the la100 for my application. Learning a little bit everytime I use this forum. Thanks again!
