How clean does the tungsten have to be?
Results 1 to 24 of 24
    Nov 2018
    Quebec, Canada
    When I dip the tungsten (which happens a lot still ) and I go to grind it it looks like this.
    I always wondered if it makes any difference if I it's not all clean?
    Re: How clean does the tungsten have to be?
    Yes it does make a difference. What is that deposit below the grind?
    Nov 2018
    Quebec, Canada
    Not sure this particular one but probably silicon bronze. Sometimes it's not that bad but still some oxidation from taking the torch away too fast and loosing gas coverage.
    Ct
    "not that bad" tungsten contamination makes a huge difference I've found its more pronounced when welding aluminum,, seems like you can get away with more when welding mild or stainless steels
    Long Island
    +1 Don't be so cheap. Grind that one back another 1/4"
    PDX PNW
    That’s a half a$$ grind job
    Nov 2018
    Quebec, Canada
    Only because of the length or something else wrong with it?
    I grind my tungstens by chucking them up in a cordless drill and I grind them on my belt sander. if I have a mess like that I will wrap some sandpaper around the tungsten and giver it a spin with the drill before I grind it off. Cleans up the shank pretty nicely.
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
    PDX PNW
    Quote Originally Posted by PatriceL View Post
    Looks like there’s still filler rod or base metal on it. Grind it all off so it’s all silver
    Dec 2009
    Stevens Point, WI
    I typically just grind deposits off the sides. Scratch lines don't seem to bother the arc much.
    Nov 2018
    Quebec, Canada
    Thanks guys, I also do the hand drill trick so some sandpaper to clean the sides sounds good.
    I like the bandaid....
    Dec 2009
    Stevens Point, WI
    A hello kitty bandaid would have been great.
    +1
    ...and grinding off another 1/4" would take 15 minutes or so.
    Mar 2014
    Michigan... temporarily
    +1
    15 minutes? You using emery cloth?
    Apr 2010
    PatriceL
    Not sure this particular one but probably silicon bronze . . .
    It's probably not Sil-Bronze - while welding - you can dip the electrode into the puddle, it
    coat the electrode Gold. S/B doesn't 'wick the puddle' like SS or Black Iron.
    I'm a hack TIG welder - but have welded '100's of feet' of bronze, and '1000's of feet' of
    Black Iron.
    Black Iron [even with good prep] rapidly deteriorates the electrode - so I don't invest a lot
    of time in precision sharpening.
    [As mentioned] Use a battery drill - and a 90° die-grinder with a 3" wheel [of various grits].
    It is quick - and you can rotate the disc to dress the 'wicked area' on the side shaft.
    I know: the really good/great TIG welders are grinding-their-molars over this low-budget
    advice - but, unless you are welding professionally/doing spec. work - the 'quick & dirty'
    method should serve you for years . . .
    Hope this helps . . .
    Opus
    Mar 2012
    Australia
    this is just me personally, I'm not someone that is very fussy when it comes to joint fit up or tungsten grind or whatever but that looks fine to me, I've welded some pretty import stuff that's been x rayed and passed with far worse of a tungsten, if I remember correctly this SS pipe root run was put in with a ball on the end after i touched the filler and I was to lazy to change the tungsten, the only time a massive knob on the end of the tungsten bother's me is when the welding inspector is measuring my heat input as a big ball spreads the arc out a fair bit so I have to travel slower or bump up the amps so it makes it pretty easy to pump in 1.5-2 KJ/mm when most WPS call for under 1kj/mm.
    Not everyone has wings on their fingers like you.
    Mar 2012
    Australia
    you say that but honestly I'm a fairly average welder, there are plenty of guys that are faster than me, that produce nicer looking welds than me and that have fewer failures than me (i've had 5 in ten years, I know guys that are 40 years in with no failures in the last 30), just like the spartans profession in the movie 300 is war, mine is welding, and I'm average in all area's in that profession.
    You say that but you can make do with what you got. Me, I need mine needle sharp and have a polishing wheel in close proximity. I sharpen 10 points at a time most days. Today I welded ammunition belt guides made from 4130 steel and one little dip kills the point for an ugly weld. So I am spoiled enough to swap it out.
    Dec 2009
    Stevens Point, WI
    I've mentioned it before, I've taken pliers and snapped the end off the tung while in the torch yet and kept weldin. Some days you just want to get done.
    Apr 2018
    TN
    Theres a huge difference in mild steel and "the rest" when welding. Mild steel is already full of so much crap in and on it that you're not adding anything. Mild steel is the meatloaf of metal. Ally, titanium, etc are clean metals and you can't introduce anything.
    Nov 2018
    Quebec, Canada
    Thanks again for the info. I will not take a chance and clean the whole tungsten especially since I rarely weld mild steel.
    PDX PNW
    Quote Originally Posted by One1 View Post
    Try welding brass
