copper sheet project - brazing, soldering or welding?
Results 1 to 15 of 15
    Hi all,
    I'm a first-time poster on the forum, and I'm quite new to metal-working as well. I have no experience brazing/soldering metal or welding.
    I would like to build a triangular construction from copper sheet-metal (sort of like a pyramid shape), but I'm having trouble figuring out how exactly
    I should go about connecting the sheets together. The copper will be cut into three (or four) triangles and then they somehow need to be connected
    on the sides. I want to use 0.5 mm (0.0197 in) thick SF-Cu sheets with dimensions approximately 1x1 ft. I thought about brazing or soldering, since welding
    seems a bit more complicated and the joints don't need to be very strong, but should hold together and be electrically connected. The joints shouldn't
    be too "bulky", but don't have to be perfect either. I've spend quite some time reading on the internet, but the kind of joints that are often illustrated on the
    websites don't apply in this case (most information is for copper pipe joints, or overlapping copper sheets). Here I would like to solder edge-to-edge.
    I already have a 30%/70% propane/butane torch and some CuP brazing sticks. I've tried test-brazing two small pieces of copper sheet together by having their edges touch,
    heating the joint and then applying the copper braze but I ended up with black pieces of copper sheet and a ugly blob of braze sticking to one but not both pieces. I did not
    use flux. Could someone with more experience maybe give me some advice about how to proceed? I'd really appreciate it. Thanks
    cheers
    Jan 2016
    Re: copper sheet project - brazing, soldering or welding?
    SOLDER...use 50/50 low melting point ..tac the edges a few inches apart using a soldering gun( less distortion than torch and more control) then fill in between tacs..use flux...
    Hi Hobbytime,
    thanks for the quick reply! By 50/50 I assume you mean Sn/Pb. What does it mean to "tac the edges " ? (english is not my first language)
    What kind of flux do you recommend?
    Northern Cal., Shasta County
    Something like 0.0197 thickness I'd be exploring a soldering iron, and any of the conventional tin/lead/zinc solders.
    Jan 2016
    Quote Originally Posted by bre View Post
    Hi Hobbytime,
    tac like in make a dot of solder to hold the pieces together and then go back and make a solid solder joint..regular flux non acid or the copper will turn green...50/50 solder like this https://www.amazon.com/Canfield-50-S...50%2F50+solder
    Thanks for the info Sandy and Hobbytime. Will the heat from a soldering iron be enough for copper sheets this size?
    From my experience with soldering electronics it is quite difficult to solder to large metal surfaces with a soldering iron.
    Is there a lower power limit you recommend for the soldering gun?
    Port Orchard, WA.
    bre I’m a wanna be welder myself! I have played around with Tig welding copper.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Central pa
    A butane pencil torch works great heat from the underside and dab solder on the top side as you go be sure to clean bright and smooth as possible and brush with flux
    Sent from my XT1254 using Tapatalk
    That 0.0197 is about the same as some flashing material, pretty dern thin. Thinking of some of the wire sizes that get soldered with as little as a 40 watt soldering iron. They make clear up to 500 watt or more soldering irons and guns. Wild guess is that an 80 watt or 100 watt would be plenty. Shiny is the key. That and a pre-tinned tip. If the tip isn't pre-tinned and shiny it won't transfer the heat. You should be able to get a spot going and just slide on down pulling the solder with you.
    Sep 2009
    Colorado
    Soldering edge to edge is going to be troublesome, I think. When you try to solder one area you may unsolder another area. One step forward, two steps back. Holding them aligned while you solder sounds troublesome as well. I work in copper a lot, but I usually TIG weld.
    I recall one soldering project where I ended up making some joints in silver solder (high temperature), and the rest tin-lead. I silver soldered first, and then never had to worry about the silver solder joints unsoldering, as the tin lead temperature is much lower. However, you would want an acetylene air torch for silver solder.
    Jewelers manage to make complex assemblies with solder, but they often use several different alloys, each with a different temperature. There are three or four different silver solder alloys. I am not aware of anything comparable in tin-lead; (I looked during the soldering project that I mentioned above). The people who are highly skilled make it work with a single alloy, kind of impressive.
    I suggest starting small, then scaling up once you have a process that seems to work. This project sounds challenging to me, even for a skilled solderer. Keep us posted.
    Hi all,
    cheers
    Sculptures in copper and other metals
    http://www.fergusonsculpture.com
    Syncrowave 200
    Millermatic 211
    Readywelder spoolgun
    Hypertherm 600 plasma cutter
    Thermal Arc GMS300
    Victor OA torch
    Homemade Blacksmith propane forge
    Mar 2017
    bar stool
    Pretty much regardless of process, beyond soldering it up with a copper or soldering gun will develop black oxidation and annealing.
    Since you allude to a pyramid shape, and say it has to be electrically conductive I'd give consideration to reinforcing the inside of the corner with copper wire, to increase bonding area and minimize strain on the completed corner joint. Wood pinch type clothespins are helpful in such constructions,
    Secondly you don't mention appearance or use. Solder particularly when fluxed on copper loves to travel across the fluxed surface. This can be minimized by damming off the travel before flux is applied with White Out.
    Again, not enough information is posted to determine how to build or in what sequence.
    Apr 2010
    bre
    I have no experience brazing/soldering metal or welding . . .
    Without: pics, prints [specs] your request is akin to 'describing
    a color over the phone'
    Please provide 'something to see' - or, the 'voluminous advice
    responses'
    will be forward/beyond - your tech/skill level . . .
    Opus
    Nov 2004
    Southern Montana
    After reading OP's post, and all of the subsequent suggestions, I thought about how I would approach the task. Since we have a grand master tinner in town, who I try to emulate from time to time, I think his solution would be to just cut the pieces with enough extra metal to bend into a flange along the joining edge. This will allow for an overlap to rivet or clamp to the adjoining edge to provide a space, sufficient for filling with solder. The joint can, easily, be filled with solder by heating with a propane torch, or by an iron (shown in photos), heated by the torch. Add flux, prior to soldering.
    Hi guys,
    thanks for all the advice, and I'm sorry if I didn't provide all the necessary information. The purpose of this build is for a "art" project. But like
    I said, the joints don't have to be perfect, just not too bulky or deformed either. Also I'd prefer if the copper stayed red and did not oxidize.
    Below there are some representative images of what I am trying to achieve, however these ones were done with sheet steel instead of copper.
    I think they did TIG welding, which I do not have the equipment for, nor the knowledge. From all the suggestions I have gotten I think
    getting a heavy-duty soldering iron/gun (200W or so) and some good flux and solder could be worth a try. That should be affordable and
    I have some experience with soldering electronics so maybe that will help.
    Jan 2016
    Hi guys,
    yes they look tig welded and the seam grinded and buffed to match the stainless, you wont get that unless you fold an edge on the copper and solder from the backside, otherwise you will have silver seams on the copper from the solder..
