Miller Bluestar 2E
Results 1 to 16 of 16
    Louisiana
    Miller Bluestar 2E
    Hey guys, I have a Miller Bluestar 2E AC/DC machine that I would like to get rid of before I load it out for scrap. The machine welds and generates power as it should before the engine went down on it. I was going to do a motor swap on it but I don't have the time or interest. I have made an adapter plate to go from the bell housing to a HF predator engine. You will need to modify a coupling from the armature to the shaft. I figure it's worth $100 if someone wants a project to play with. I am in Rosepine Louisiana.
    Miller XMT 304 CC/CV
    Syncrowave 180 SD
    Lincoln PowerMig 255XT
    TermalDynamics 52
    Lincoln 305G
    Comlpete machine shop to back it up
    May 2008
    Orange, TX
    Re: Miller Bluestar 2E
    Thinking if I'm interested or not. You're 1-1/2hrs away.
    Any chance you could post a couple photos of the unit?
    What happened to the original Tecumseh engine? Still have it?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Louisiana
    I still have the Tecumseh, it was running but would idle down and shut off after a few minutes of running. I put a carb kit and a fuel pump on it and helped but did't fix the problem. The armature drive coupler on the engine side broke when I was trying to remove it. I will get a few pics for you. I will try to post some pics.
    Syncrowave 180 SD
    TermalDynamics 52
    Lincoln 305G
    NE Iowa
    man wish you were closer to me. I would love a project like this!
    May 2008
    Orange, TX
    Yeah, those adapter plates take a little finesse to remove and prevent breakage. I've got one kicking around here somewhere.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Louisiana
    duaneb55, I will try to get a snapshot or two for you today. It has been so long since I posted a pic on the forum I will have to figure out how again.
    Larry
    Syncrowave 180 SD
    TermalDynamics 52
    Lincoln 305G
    Louisiana
Size:  206.4 KBName:  welder2.jpg
Size:  200.5 KBName:  welder3.jpg
    Syncrowave 180 SD
    TermalDynamics 52
    Lincoln 305G
    Apr 2008
    NW ON Canada
    Miller Bluestar 2E
    I always loved how my old blue star 2E welded. In fact, I prefer the 7018 arc of the 2E over the 7018 arc of my newer 250 bobcat. Wish I never had sold the 2E. Mine was dc only. This one is ac/dc.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Mar 2013
    If it wasn't a 5+ hour drive I'd be interested. If you're going to be any closer to Fort Worth before it sells let me know
    Miller Maxtron 450
    Miller 330 A/BP
    Linde UCC-305
    Esab Migmaster 251
    Esab PCM-500i
    Lots of other random stuff...
    USA
    Dang i wish i was local i need a generator welder ,i hope it goes to a good home
    Jan 2019
    I know I'm new and it's a few days old but usually what happens is the valves wear into the block over time. When the valve heats up it expands and you loose compression. A quick fix is to grind down the end of the valves to get some clearance.
    Louisiana
    I have too many projects around the shop and replaced it with a Lincoln 305g. Hate to see it go to scrap but it has more than $100 bucks worth of copper in it.
    Syncrowave 180 SD
    TermalDynamics 52
    Lincoln 305G
    May 2008
    Orange, TX
    I'm pretty sure you'd find out there isn't that much copper value in that unit. Most of the weight is steel and the copper that's in it it's not "clean" copper due to the varnish insulation that reduces its value at the scrap yard.
    Unfortunately I too have too many things going on at the moment so I don't think I'll be able to take it off your hands.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Louisiana
    I totally understand about having too many irons in the fire!
    Syncrowave 180 SD
    TermalDynamics 52
    Lincoln 305G
    Apr 2008
    NW ON Canada
    Quote Originally Posted by sbluke55 View Post
    Valves can be lapped and re seated. Valve guides can usually be replaced too.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Any chance that you would sell some parts off of this machine. I have one and would love to buy the carb and face plate and possibly fuel tank
