Powermax 45 purchase - what’s the best move here?
Results 1 to 17 of 17
    Oct 2013
    Long Island, NY
    So i am going to pull the trigger on the powermax 45 xp but I’m not certain which bundle to go with.
    I need the CPC port, and will be using it with a Langmuir crossfire that i intend to try and upgrade to have a Z axis and machine torch down the line.
    At the moment it only has a mount for a hand torch.
    Ideally I would like to have a torch for hand cutting and another torch for the plasma table. This is making me lean towards this bundle below. But why does it seem too good to be true that it comes with two torches? The 15 degree torch is actually ideal i think because it aims the torch hose up and out of the way.
    What’s going on that it cost $450 to buy the hand torch separately but this one comes with two for
    Barely any more money?
    https://www.bakersgas.com/HYP088124.html#25264
    www.FirehouseFabricators.com
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    Dec 2003
    Fairfield,CT
    Re: Powermax 45 purchase - what’s the best move here?
    Edit Post. I misread your post. Ya not sure does that mean either or, or both.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Oct 2013
    Long Island, NY
    After further reading into it, it’s both. It just seems too good to be true that for $2130 you get two torches and a cpc port but only the cpc port is $2080.
    The machine torch kit is not bargain either. It’s basicallt the same price to buy the machine torch separate assuming you intend to buy a hand torch as well. I’m a small operation I only have space/funding for one machine which makes that quick connect very enticing as well.
    Probably ordering it tomorrow.
    Lincoln 210mp
    Lincoln SW200
    Dec 2003
    Fairfield,CT
    Fired up my pm85 for the first time in years when i fired the machine torch on my table. I have an htp 380 for hand cutting since 2003 and still kicking. Yes the regular torch for the hypers are not cheap.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    Oct 2013
    Long Island, NY
    85?? That’s a big machine lol.
    Cutting bank vaults in your shop?
    Lincoln 210mp
    Lincoln SW200
    Dec 2003
    Fairfield,CT
    The PM85 is just for my plasma table. If I cant make money with the table maybe cutting vaults is in my future.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    Dec 2009
    Stevens Point, WI
    I'd like to have a separate machine torch for my table as well. Or even just a second hand torch.
    Oct 2013
    Long Island, NY
    At the moment i don’t have a height control so buying a machine torch is kind of silly. But i would like the 15 degree torch as kind of a pseudo machine torch. I use my table as a hand cutting plasma table too to save space. So being able to just snap in the other torch is a home rub.
    Lincoln 210mp
    Lincoln SW200
    Oct 2007
    New Hampshire
    There is a package price for a 45xp with a machine torch and a 75 degree hand torch. That is the one I would recommend. If you plan to use a hand torch on your Langmuir machine keep in mind that the CPC port will not start / fire a hand torch (the 75 degree and the 15 degree hand torches are fired via hand trigger switch), so to use one of those torches on a machine means you will need to read the wiring diagram in the service manual and hack into the internal machine wiring. The CPC port (pins 3 and 4) will fire a machine torch (no trigger switch, designed for machine cutting).
    Jim Colt
    Dec 2003
    Fairfield,CT
    Wow. That is some great info right there Jim.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    Oct 2013
    Long Island, NY
    I ordered the 75/15 torch kit and I guess I will have to figure it out to make it work for now.
    The machine torch/hand torch combo is no bargain really...It’s the same price roughly as the hand torch plus the machine torch separately. Maybe $100 cheaper. Kind of strange the 15 degree torch is only an extra $50.
    Jim, i assume doing what you stated to use the hand torch voids the warranty?
    Lincoln 210mp
    Lincoln SW200
    Oct 2013
    Long Island, NY
    I caved and decided to order the machine torch with hand torch kit...
    What does the remote pendant do? I see it is included and its not a cheap item.
    Lincoln 210mp
    Lincoln SW200
    Oct 2007
    New Hampshire
    The remote pendent is simply an on/off switch for using the Powermax plasma with a machine torch on non-cnc machines such as a track burner or a portable pipe cutting machine. This combination with the hand and machine torches is often used with those types of machines. For your cnc machine....which controls the start and stop of your Powermax there is no need for a remote pendent. Jim Colt
    Jan 2005
    The remote is momentary on or continuous cutting with it's dual mode switch. Works with Thermal Dynamics cpc too
    Esab 2200i-TA34
    Esab 160i caddy
    Thermal Arc Pee-Wee 85s
    Thermal 60i (Beast)
    Thermal 38XL
    Klutch P-300i/ 120 volt
    Klutch MP-140si
    Oct 2013
    Long Island, NY
    Not sure if it comes with the pendant. One website says it does, another says it doesnt. Part number 088123.
    I picked up the supplies to make my own CPC plug but I can salvage the pendant I guess if it comes with it for parts instead.
    Lincoln 210mp
    Lincoln SW200
    Oct 2007
    New Hampshire
    Powermax 45xp part number 088123 comes with a machine torch, a hand torch, CPC port installed and a remote pendant. Any questions about Hypertherm part numbers can quickly be answered by a call or email to Hypertherm customer service or tech service! If you have questions about wiring to the CPC port I'll be happy to help out. jim.colt@hypertherm.com Jim Colt
    Oct 2013
    Long Island, NY
    Was able to get everything working thanks!
    Do you recommend cutting at full amperage? After only a few simple shaped test cuts I seem to have blown out the nozzle already on the machine torch which is rather surprising. The electrode is fine.
    Lincoln 210mp
    Lincoln SW200
