Check out my new scooter - Page 6
Page 6 of 6 FirstFirst ... 456
Results 126 to 146 of 146
  1. #126
    Jun 2014
    Southern Illinois
    Re: Check out my new scooter
    My favorite YouTube welding instructor is Jody Collier of Welding Tips & Tricks. His favorite says is, “use enough amperage so the rod won’t stick with a short arc, then hold a short arc”.
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
  2. #127
    Mar 2015
    i ordered some lincoln 5/32 5P + for some 3/4" stuff to help a friend from church weld that has a skid steer attachment and skid steer/excavator rental business, got some 3/32 and 1/8 excalibur 7018 coming - all 10lb cans
    Lincoln AC 225 - S
    Lincoln Idealarc 250 ( 1980 )
    Oxy/Acet Victor Gauges/Purox Torch
    Hypertherm Powermax 800
    Miller Digital Elite US Flag
  3. #128
    Mar 2015
    so i noticed there are 4 extra holes in the back of the idealarc case was that for some kind of cable mgmt aparatus they offered/sold or was that for some other welder they put the case on ? i havent ever seen one with any cable mgmt on them that looked factory i should say it was some homemade thing that didnt look so great ;-)
    Lincoln AC 225 - S
  4. #129
    Jun 2014
    Southern Illinois
    Those 4 holes were for handle bars when the went to a different style undercarriage. This was after the stopped the tricycle like you have. My 1989 came with the new style. I put it on a tricycle! Here is what they looked like
    Steve
  5. #130
    Mar 2015
    aaaah ok so no cable mgmt.........im sure someone has made something reasonable but i havent seen it yet
    Lincoln AC 225 - S
  6. #131
    Jun 2014
    Southern Illinois
    I’ll take a picture of mine tomorrow and post
    Steve
  7. #132
    I used one at work many years ago. The only issue was, once you set your heat , we had a wood wedge that you stuck in between the dial and the cover. The thing would vibrate and shake it would change the heat.
  8. #133
    Mar 2015
    wow that was a pretty loose dial then, I dont think mine will vibrate that much
    i found these cable mgmt pix on another forum
    Name:  cable mgmt 1.jpg
Size:  132.9 KBName:  cable mgmt 2.jpg
Size:  80.0 KBName:  cable mgmt 3.jpg
Size:  47.1 KBName:  cable mgmt 4.jpg
Size:  184.2 KBName:  cable mgmt 5.jpg
    Lincoln AC 225 - S
  9. #134
    Jun 2014
    Southern Illinois
    There are tension adjustments that will hold the rotor and stop the movement. Usually they are tight from being on the same setting for years.
    Steve
  10. #135
    Mar 2015
    i noticed that inside, spring loaded bolt around the adjustment rod!!!
    Lincoln AC 225 - S
  11. #136
    You guys are making me drool again. Just don't see these coming up for sale north of the border. Anyone know of an AC/DC 250 for sale in North Dakota? I know these things aren't light so shipping them any distance is going to be a pricey option.
    Jun 2014
    Southern Illinois
    Quote Originally Posted by searcyfarms View Post
    Yes. There are 2 spring loaded adjustments that tighten a brake band. These are on both ends of the rotor. I had an old Lincoln service tech tell me don’t mess with them! If you get them to loose when you strike an arc the adjustment wheel will spin like an airplane propeller. So I never touch them. If one was loose I guess it would be ok to snug them up. Never saw one to loose
    Steve
  13. #138
    Mar 2015
    mine seems perfect, its nice and easy to adjust but firm enough to seem to stay put, one thing i noticed on these is that the 90% of the adjustment wheels have a band of corrosion around them that starts near the center bolt hole and fans out toward the knob/handle i wonder why that is, it seems very common maybe from the heat from welding the brace on the back
    Lincoln AC 225 - S
  14. #139
    Jun 2014
    Southern Illinois
    My guess it's the spot welded reinforcing from the hub to the knob.
    Steve
  15. #140
    Mar 2015
    id guess around 250 on shipping maybe less for freight, not really all that bad im sure steve can fix you up with one of his jewels
    Lincoln AC 225 - S
  16. #141
    Jan 2015
    Hamilton Ontario Canada
    whtbaron The Canadian ones are square on top, not tombstone shape but inside the same, I have one and Love it. I paid $250. for 20 years ago. So they around just have to keep looking! Ontario Canada here.
    Welders: IdealArc AC/DC 250
    Lincoln AC 225 converted to AC/DC
    O/A torches
    Lots of Hammers Clamps and Grinders
  17. #142
    Jun 2014
    Southern Illinois
    Here’s the cable system I’ve come up with for my round top that’s on a tricycle. 2” square tubing and some cross pieces with braces and radius cuts on some flat steel
    Steve
  18. #143
    Mar 2015
    u got some long monster cables on yours steve !!! and those slid/twist type connectors those look hand !!!
    I like everything tucked back behind rather than sticking out the sides as i have limited space
    Lincoln AC 225 - S
  19. #144
    Jun 2014
    Southern Illinois
    60’ on electrode 40’ on ground. 1/0 cable. Tweco female connectors on front panel so it’s easy to take them off for storage and transport
    Steve
  20. #145
    Quote Originally Posted by Ypop View Post
    Even the square tops are rare as hen's teeth around here. At farm auction they will bring $700 to $1400.
    Mar 2015
    yea theres one around here in great looking shape for 1100 i just couldnt pass on the round one for 100 and take a chance on it working
    Lincoln AC 225 - S
