Wanted carbon rods for hole build up
Results 1 to 11 of 11
    These were advertised in farmer type magazines, for welding holes back round. But they no longer are available. I would buy a whole set, but am most interested in 1 3/4" Thanks
    Steve 402-322-3132.
    Jan 2016
    northeast USA
    Re: Wanted carbon rods for hole build up
    do a search on amazon for carbon rod, many choices come up if those are the ones your talking about
    Thanx I'll give it a try.
    Mar 2005
    Under a Rock
    I've only seen carbon arc rods for old style cutting torches... carbon arc torch..
    I know you can still get the rods at local welding supply.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Dec 2009
    Stevens Point, WI
    How about copper or aluminum?
    I just watched a video on FB of a guy that used an (aluminum I think) form/profile to build up teeth on a gear. Looked like a stupid amount of work but he got it done and it looked like the aluminum block held up great.
    NW New Jersey
    Available in limited sizes from mcmaster.
    https://www.mcmaster.com/=1h95xx1
    Might have to machine to size, and a little bit pricey in 2", as would copper (if solid). Maybe aluminum ?
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Bemidji MN
    If a person needs a large round of aluminum, one can be cast inside a piece of pipe and then split lengthwise to get it out.
    Use anything you have handy to melt scrap aluminum inside the pipe.
    Then just grind it to size after it cools. Doesn't have to be perfect for this application.
    Airco 300 - Syncro 350
    Jan 2011
    Hutchinson Kansas
    Search for Graphite rods. They are used in EDM. They can be machined to the size you need. Not cheap though $250 for 1.75x12"
    Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
    Oct 2007
    I know where there are several cases of carbon rods-- I think either 3/4 or 1 inch (by 12)
    Are you interested in any that small ?
    Tim
    Sep 2005
    Cave Creek AZ
    I think I bought some on Mcmaster and some on ebay.
    Jul 2016
    Midwest
    I have a bunch of Metric and regular carbons I'd like to liquidate. Mostly close to 1/4" up to 5/8" and a couple 1 or 2". For all your small carbons you can just peel the copper off of Arc Air rods. They come in about 1/2" and down and are cheap. Let me know if you want a list of what I have.
    Thermal Arc 320SP
    Cobra Pythons
    Thermal Arc 300 AC/DC
    Thermal Arc 161STL
    Thermal Arc 190S
    Cut Master 82, 42.
    Victor Gas App.
    Ellis 1600
    Evolution Compound Mitre.
    Boxes of welding crap.
