Gas mixer - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Gas mixer
    Jul 2018
    Cumbria, UK
    Re: Gas mixer
    you hope they are...
    I plan to copy some of these setups sometimes soon though, I want to mix sureshield 5 (5% CO2, 1% O2) with pure argon to make Stainshield (2% CO2 with traces of O2) for MIG welding stainless.
    I will deffo be adding check valves to my setup though... for the small cost of them it seems worthwhile.
    SoCal-LA
    Re: Gas mixer
    You would better spend money on a pressure gauge to calibrate the flowmeters. If they are the same you are good to go. Neither can get pressure past the other regulator. Don't forget that the flowmeter with the slightly higher output pressure will overpower the other output pressure until the system normalizes at some 3 psi. That could be a very long surge time with the higher pressure output gas at a temporarily higher concentration, especially if the mig regulator output pressures are at some 80psi. If you are tacking you will never reach your desired concentration, even with check valves.
    My recomendations would be source lower output pressure regulators to keep surge pressures low and surge time shorter. My singles are 25psi output, and duals arse 30psi output. Also shortest gassaver hoses for reduced surge volumn, portable pressure test device for calibration from Netwelding.com. Also a portable gas flowmeter to confirm final gas flow at nozzle from Netwelder.com .
    Re: Gas mixer
    Quote Originally Posted by metalmagpie View Post
    Be careful with those Y setups - they should have check valves. Otherwise if one tank has different pressure than the other, gas will flow from the one with more pressure into the one with less. Mixing your gases unintentionally. Very bad.
    metalmagpie
    If they were connected directly to each other that would happen. You are forgetting that they have regulators on them that are both set to the same pressure.
    If your mixing gas then they probably aren't set to same pressure but your right none the less. The regulator is never going to let the one with higher pressure go backwards through the other regulator and overcome the bottle pressure to get in the other tank that is for dang sure.
    Seattle
    Re: Gas mixer
    What do you suppose the probability is that two regulators are set to exactly the same value? Answer below.
    I have two flowmeters. One is set to 50 psi and the other 30 psi.
    I cannot say for sure that gas can flow backwards through a flowmeter, though.
    The answer to the question above is zero. No two analog properties are ever precisely equal.
    metalmagpie
  5. #30
    Laredo, Tx
    Re: Gas mixer
    metalmagpie
    While what you're saying is 100% true in context, in application two identical flowmeters both intended to be set to the same output pressure will indeed work to provide the necessary flow percentages to get a gas mixture. Might it be up to your liking/standars? Going by what you are saying, probably not. But for me, it works just fine, and that is what matters to me.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
