converting engine drive compressor to electric
Results 1 to 8 of 8
    Nov 2015
    big rapids mi.
    Picked up a compressor with a bad engine.
    10hp engine.
    Wantto add a 1phase 220v electric motor.
    any idea of motor size and other parts I'd need to buy?
    this is the info. on tank. 40 gallon
    buckeye boiler co. 1979
    W.P. 200
    Temp 450
    Heads 108
    Shell 124
    Head radias E
    Feb 2010
    anoka co mn
    Re: converting engine drive compressor to electric
    One hp electric = two and a half hp gas.
    Dec 2008
    You need to know the flow rating of the pump.
    That will dictate the HP of the motor.
    Roughly 4 cfm per 1 horsepower.
    Sechelt, BC
    Before you waste any more money on it, have the tank certified. That’s pretty old.
    Jun 2016
    Not there
    Quote Originally Posted by rexcormack View Post
    That's about right
    Sep 2005
    Cave Creek AZ
    I have a compressor from that era. I just replaced the tank as it was getting fatigue cracks. The idea of recertifying the tank is ridiculously stupid, as the cost to do so will exceed the value of the compressor. I looked into it when working on mine. The other problem inherent in thos, I found, is that every other component has the same wear as the other. So when the motor goes bad the pump and tank are not far behind. I replaced my tank and about a month after my motor started smoking. Then the pilot gave up the ghost.
    Also, when looking at pumps, most are rated for a certain cfm at a certain HP, at a certain speed hof the pump). If you can find a 7.5 or 5 horse you can change the size of the pulley to accomodate the motor. Easiest if you can find pump specs for it. It does take a wee bit of hunting to find them though.
    Nov 2015
    big rapids mi.
    Well, glad i only paid 25$ for it. I'll probably put it in a local auction.
    Thanks for your replies.
    Apr 2012
    Flat lands of Colorado, where the wind blows
    most likely a 3 hp electric should run it, (add a pressure switch on it and either up the unloader, or put the pressure switch a few pounds under the unloader, and if your in a situation where the unit is fast cycling, then put an aditional switch that by passes the presure switch and let the electric run and let the unloader do the work,
    I had set up a compressor that way that had limited storage tanks, and when doing some heavy air usage it was nice to let the unloader pop on and off, rather than the motor starting a few seconds after shutting off, and doing that a few times a min, it worked well,
