Harbor Freight 62204 plasma cutter sometimes does not fire
Results 1 to 12 of 12
    I bought a Harbor Freight model 62204 plasma cutter a couple of years ago. It's worked ok until a few months ago when it began to work intermittently. I cut a few items then it won't fire. After several minutes it will fire again. I only cut 1/8 inch steel and not too much at a time. cuts are either one inch long or 8 inches long. I have tried different settings and new consumables. I searched the topic on this site and found some posts, but they appear to be for older model cutters. Any help would be greatly appreciated. I have repaired some circuit boards on other electronics in the past but have no real knowledge of whats what. So pictures go a long way... thanks, paul
    Re: Harbor Freight 62204 plasma cutter sometimes does not fire
    Sounds like the consumables.... I know you said tried new ones and still the same issue??? are you sure the new consumables are good/right? are you changing *all* of the parts? also.... you do have good air pressure when this happens right??? and filters/driers are not plugged or partially restricted?
    Delaware
    Well you covered about most of the items I would have told him to check. But one of the biggest questions is are they original consumables from Italy or Chinese copy's. I hear about this all the time and find they were using cheap consumables sold on ebay or amazon.
    Primeweld dealer and tech support
    I have been using ebay consumables for more than a year. They have been working great. I guess I figured a HF unit would use generic . I was actually using drag tips when it started to act up a few weeks ago. I switched back to some generic regular tips. Still a problem. Sounds like I should order some from Harbor freight.
    I have several water filters including a Motor Guard sub micron filter last. It’s dry.
    I checked my ebay records and it turns out my drag tips came from your ebay store, so they should not be the problem. I didn’t realize the originals came from Italy.... i think I have one new set left, going to put them in and try it.
    Delaware
    If you got them from me then they are the right ones. They run at 40 amps and 70 to 75psi. There are 4 parts electrode, swirl ring, tip and retaining cup. Check the little contact pins and make sure then are spring in and out and making contact with the ring on the retaining cup, also check the electrode it should push in then spring out, there should be about 1/8" of movement. If its none of these I would start looking for a air problem.
    Sep 2011
    USA
    I have the same problem with my plasma cutter, if you look at the end of the electrode and inside at the bottom of the tip I believe you will find it is carboned up. The carbon or black film doesn't allow the electrode to start the ark. I take a small wire bush and clean the electrode tip and inside the cutting tip. This works for awhile and then it needs cleaned again. George I believe is right seems like an air problem. I run my air thru a Motorguard filter also. I would like to know what is causing the contamination in the filtered air. The air filter is connected right at the cutter.
    ________________________________
    Everlast PA140ST
    Everlast PowerPlasma 50
    And no you can't Borrow them
    the carbon sounds like yours is moist air??? have you thought about a drier right after the motorguard? how often do you put new filters in? and is your compressor fairly small and putting lots of moisture in or a 60-80+ gallon tank?
    I put in the last new set I got on your site, and it's cutting like a champ right now. I will check out the other items you mention, and order more drag tips and electrodes.... THanks!
    Been running at 35 amps and 80 psi. I am cutting 1/8 inch steel, mostly 4130 but some 1075/80 as well.
    I will try the settings you are recommending on the next batch I cut up.
    I make clam hoes...
    With new tip and electrode from your site, it cut good for about 10 8 inch long cuts in 1/8 inch 4130 steel. After that it continued to work but the misfires started again. when I took it apart the electrode seemed to be stuck in. I pushed on it a few times and it began to pop in and out but not always coming all the way out. does this get any kind of lube or service? or are there parts to replace? It definitely does not snap out all the way some of the time.
    George,
    This has been very helpful, I changed my setting to 40 amps, re calibrated the air flow. But what what I think may have solved my problem was the 1/8 " movement of the electrode. It seemed to be sticking as each time I took it apart it was stuck in. I worked on it for a while and applied a tiny amount of an oil called deoxit (which is for electrical contacts) where the electrode screws in. Then I just worked it in and out until it was very free. Once again, cutting like a champ... hope it holds up. Also, I may have been over tightening the retaining cup.
    Thanks, Paul
    Delaware
    A very little silicone grease will work also, that is what is recommend by Tecmo. Over tightening the electrode will cause the plunger to swell and cause it to stick also.
