Compressor Relief Valves?????
Results 1 to 19 of 19
    Hey...…….I'm in the middle of some driveline work, and using the compressor to run tools.
    For about half a year, my compressor has started to leak down when not in use. It always held air for long periods on non-use. Then it started draining down within a few days.
    Fast forward to about 3 weeks ago...………….It quit leaking down...…….Cool says me...……
    But now the dam thing starts squeaking (at least I thought it was a belt squeak) when it comes up to 175psi...…..and it runs on without shutting down.
    The squeaking is at the top of the compressor, not down on the side where the shutoff switch/pop off valve is.
    Is there any way to check the valves at the top of the compressor cylinders???????? Dunno if soapy water will work, it's pretty hot on top of the cylinders, and breezy, what with the cooling fan running a few inches away I can't check for a leak when it's not running now, since it started holding air again...……..unless I just shut it down before it fills, or when it starts squeaking...…………….
    Hell, I might have answered my own question...…….GEEZ
    Dec 2008
    Re: Compressor Relief Valves?????
    Sounds like a head gasket leak like the old Harley panheads and shovelheads used to do.
    Soda springs,Id
    See if you can jerry rig an airtight connection to the intake side and put air pressure to it while it's stopped.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Without knowing what compressor you have it's a guess. If it has a centrifugal governor, there is a shrader valve inside a sleeve which may not be sealing. If a pressure switch, it may not be sending air to the head to signal shutoff, and it may be belt squeal.
    My first thought was belt squeal, but belts appear tight. Hard to feel with the stupid safety cage.\\
    Like I say...…………………..it quit leaking down, and the squealing started (shrug) Now it squeals, and won't shut down at pressure. I'm thinking it might not be a squeal, but air escaping from one of the pop off valves. Didn't get a chance to look at it yesterday, and won't today.
    Sounds like your pressure switch then. Original leak down from the switch or related piping maybe.
    ---Meltedmetal
    It reaches 175psi (the proper setting for switch), then starts squealing, doesn't pass 175psi, doesn't shut down, but keeps on running while squealing.
    Could the top pressure in the cylinders cause the belts to slip when it reaches top pressure?
    The compressor drive wheel still turns, it doesn't stall when it squeals.
    Jun 2011
    Aiken SC area
    Check the contacts in the starter with the power off, see if the contacts are welded together from arcing thus the reason it keeps running. Next, the pressure switch contacts not releasing when reaching preset due to being welded together from arcing, or possibly an obstruction in the pressure lines. Bob
    Dec 2008
    Those relief valves are not proportional, they are popoff valves.
    If any of them ever opened you would know it!
    They are probably not the source of the squeal but anything is possible!
    Watch that pressure for obvious safety reasons. Maybe try your mechanics stethoscope to listen to the relief valves. I still suspect the pressure switch as it should shut off.
    ---Meltedmetal
    Soda springs,Id
    I think the reason it keeps running after reaching 175 is a pressure switch problem. The pressure relief valves must be working else it would continue pumping past 175. One easy way to find if the belts ares slipping is, with a spray bottle of water, squirt the belts while it's squealing.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    That is a centrifugal governor underneath that round cover. If it's leaking there it won't shut off.
    I just had a bit of time yesterday to throw this together. Needed to air up a rear tire before going up to the hay meadow.
    Anyways...…………….I'm leaning towards either the motor bearing, or belts
    BUT THEN THE STUPID THING QUIT MAKING NOISE AFTER POPPING ALL THE VALVES
    Soda springs,Id
    Maybe it was just crying and needed a little lovin'!!
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Mar 2009
    MN
    Clean or replace the tank check valve. They can get gummy over time and not seal. This will allow leaking back through the head or pressure switch. Other symptoms can be hard starting and failure to reach shut down pressure. Symptoms can be intermittent.
    You say it hits 175, but won't shut down. Verify pressure switch is functioning correctly by backing it off a few turns to shut down at a lower pressure.
    My name's not Jim....
    Jan 2015
    Hamilton Ontario Canada
    Boostinjdm Has it right, too high of pressure will make the belts squeal as the motor has to overcome the pressure in the compressure that it was not designed to do.
    Welders: IdealArc AC/DC 250
    Lincoln AC 225 converted to AC/DC
    O/A torches
    Lots of Hammers Clamps and Grinders
    But is it shutting down normally and dependably now ? They don't usually just fix themselves. Lol.
    How was it running and not building pressure. That is a lot of air to be going nowhere. If it was turning pressure should have been rising if switch wasn't shutting down at 175. ????
    I think you guys were right about the belts.
    I haven't used the compressor till today.
    Turned the switch down to a lower cutout pressure like suggested, and let her run. Still wants to run up to 170 before shutting down.
    And...….the sound does come back when it's at 170, but pressure doesn't rise. Gotta be belts are slipping......she ain't turning enough to put pressure out maybe...still turning, but not making additional pressure.
    I dunno crap about these things.
    Apr 2011
    minnesota
    Depending on how many hours you have on it the valves in the head could need to be rebuilt. Does it start normally or is it slow to go with pressure in the tank? If slow to start could be the tank check valve. If the tank check valve is leaking it will continue to leak out the unloader when not running
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
