Lincoln Sa200 won’t start
Results 1 to 10 of 10
    Jun 2018
    Texas
    Recently got my sa200 f162 back from the shop and it’s been running and welding great. I was told everything on the machine checks out. Every part on the machine is brand new except for the mag. Never been rebuilt and doesn’t need to be. One day I’m welding with it and the next day I go to start it and it just won’t start. It’ll turn over fast and sometimes it sounds like it’s struggling to turn over and sometimes the starter won’t engage. It’s like a click. When it does turn over I see very little white smoke coming out of the exhaust. What is going on?
    Oct 2013
    cntrl FL
    Re: Lincoln Sa200 won’t start
    When I have a problem like that, I always remember the Fire triangle. Oxygen, fuel, ignition. It's the simple things that will drive you crazy.
    SA 200s : 1944 1963 1965 1969 1980 1982
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Jun 2018
    Texas
    Quote Originally Posted by BYW200 View Post
    Not helpful, but thanks. New fuel, new spark plugs and plenty of oxygen.
    Oct 2018
    Have you pulled the plugs and made sure that it is not flooded with to much fuel?
    Oct 2013
    cntrl FL
    Are you getting spark too the plugs? I've had the coil go bad in the mag, crusty points, bad condenser (even new ones), points were gapped wrong or closed, oil getting on points from a bad shaft seal, the stud that passes through the housing has bad insulation and grounding out the points not allowing the engine to start, hair line crack in the distributor cap.
    How is the float setting on the Carb? It could be hanging the needle valve open causing it to flood. Also the float could have a crack in it, letting it fill with gas not letting it come back up to close the needle valve.
    Sent from my Moto Z (2) using Tapatalk
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Oct 2013
    cntrl FL
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Jan 2016
    northeast USA
    Quote Originally Posted by good.weld View Post
    its obvious you dont have much mechanical ability to work on engines, your best bet is to have a qualified person look at it before you make it worse...some know what to do some dont, its not a bash at you but from your response it shows the lack of knowledge to work on it..
    Jun 2018
    Texas
    It was the magneto.. thanks. It got water in it.
    Oct 2013
    cntrl FL
    Glad you figured it out
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Nov 2015
    Northford, Connecticut
    Ignition is today’s winner .....Time for some new gaskets on our Mag!
    1968-'70 Lincoln SA 200 code 6633
    Millermatic 200 serial#JE834063
