Drill press variable pitch pulley - repairable?
Results 1 to 14 of 14
    Bemidji MN
    On the school wood shop 15 inch, Craftsman, variable speed drill press.
    Mod: 351.229350
    Code: 200001
    The motor pulley assembly is spring loaded to maintain correct tension for the variable pitch spindle pulley.
    The upper and lower pulley have seized together and require a hammer to move.
    I have taken it off and will take it apart at the home shop.
    Any chance these clean up to where they function again?
    (part is no longer available)
    Thanks in advance
    Airco 300 - Syncro 350
    Bemidji MN
    Re: Drill press variable pitch pulley - repairable?
    I forgot the part numbers.
    Upper motor pulley: 16006
    Lower motor pulley: 16007
    Since the lower pulley is the one no longer available, I'll bet it's the damaged one when I take it apart tonight.
    Sounds like it's similar to a snowmobile clutch and drive setup. Probably all scored up. May need to make up a bushing or a sleeve to get a new bearing surface.
    Mar 2009
    MN
    Some new bushings and maybe a shaft should fix it if a clean and polish job doesn't. Had to go through that on my bandsaw. Not a big deal if you have a lathe handy.
    My name's not Jim....
    Bemidji MN
    Cool guys thanks, I'll post up the damage tomorrow
    Bemidji MN
    I was able to pound it apart with a wood mallet.
    No bushing in it, just steel on steel.
    Looked like galling was the problem.
    Cleaned it, oiled it, spun them together to let them "seat" to each other and clean each other.
    Put back together with some wheel bearing grease, works perfectly again
    Mar 2009
    MN
    You didn't get out the mics or buy any fancy measuring tools? Not even a rant about poor fits from the factory?
    Jun 2008
    Probably made in North America not in some offshore 'shop' :-)................Mike
    Bemidji MN
    Heck, before I owned all my fancy measuring tools, my calibrated eyeballometer and "that feels like the right amount of clearance" were all I used
    I bet you know exactly what I mean
    Pensacola , Fla
    Not the same but some have used these for variable speed change on a drill press, it uses 2 belts and the movement of the pulley position changes the speed. It is mounted to a lever and to change speed you push the lever back and forth.
    https://www.ebay.com/itm/MTD-ORIGINA...sAAOSw43pcsLiK
    DIY CNC Plasma table & CandCNC DTHC-IV MP 3100 Feather Touch option
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Bemidji MN
    That's really interesting - I'd really like to see how that works
    Mar 2009
    MN
    John Deere used that on older garden tractors like a 214. Called it a varator.
    Our potato packaging machines used to have those and I’ve used them on conveyors I’ve built. Simple and work really well.
    Pensacola , Fla
    some explanation
    In this video you can see the center pulley changing to vary the speed
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
