New Owner - Everlast Power I-Mig 275P Quickstart Help
Results 1 to 4 of 4
    Hi all,
    I just received my Everlast Everlast Power I-Mig 275P Unit. This being the first unit I've owned with so many different settings (and not just settings for wire feed speed and volts), Im finding it hard to get my head around it all, and actually getting anything near decent welds.
    Im only welding steel at the moment, and that being only .8mm to 1.5mm steel.. Can anyone assist me with a good starting point with the settings so i can work my way from there?
    I'm using .6 solid wire.
    Many thanks in advance.
    Bos.
    Aug 2016
    Re: New Owner - Everlast Power I-Mig 275P Quickstart Help
    use this for my multi process everlast ...
    syng: 3/32 thick junk
    1/8 steel...use this setting:
    That is a lot of welder, for $1800
    Charl
    Nov 2008
    Go here and download the Power i MIG 200 chart and use it for thinner stuff. The stuff you are welding should fall in that category. But I'd personally stay away from .6 wire and use .030". And don't worry with pulse for now. On this unit set your arc force to 70%. Also download the manual from the site.
    https://www.everlastgenerators.com/s...33b71ac913.pdf
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Thanks guys, gave that a go and so far much much better
