Ironworker Dies, Tubing Roller, Grinding Wheels
Results 1 to 1 of 1
    Apr 2012
    Wisconsin
    Cleaning up my shop and I have a few items I'm looking to sell.
    - Ironworker bottom dies, here's what dies I have:
    - Slot die: Width = .187" Length of slot = .385"
    - Slot die: Width = .260" Length of slot = .387"
    - Slot die: Width = .293" Length of slot = .575"
    - Slot die: Width = .262" Length of slot = .385"
    - Round die with notch: Hole Diameter = .580" Notch width = .104"
    - Round die with notch: Hole Diameter = .505" Notch width = broken off
    - Square die: .638" square
    - Round die: Hole diameter: .095"
    - Round die: Hole diameter: .451"
    - Round die: Hole diameter: .324"
    - Round die: Hole diameter: .246"
    - Round die: Hole diameter: .230"
    - Round die: Hole diameter: .262"
    - Round die: Hole diameter: .142"
    *****Dies are 1.375" O.D.*********
    $160.00
    - Nice used Airetool Tube Rolling/Expanding Gun. Comes with a bunch of tooling, not all is pictured in the pictures. $2,500 OBO
    Airetrol Air Driven Motor
    Airetool motors control expansion by accurate measurement of torque. They automatically stop expansion accurately according to predetermined setting. This prevents over- and under- expansion of tubes, assuring uniformly tight tube joints, providing maximum holding strength for individual tubes. Strong, lightweight aluminum housings provide easier handling and less fatigue. Rugged drive combines precision control which measures torque output. All AIRETROLs include torque sensing cams designed and manufactured specifically for tube expanding applications.
    Model Number 850-1250A
    Part Number 8405399
    Free Speed RPM 1066
    Maximum/ Minimum Torque 126 to 9.6 In. Lbs
    (14.2 to 1.08 Nm)
    Overall Length 12 1/4"
    311 mm
    Weight 10.5 Lbs
    4.76 Kg
    Side to Center 1 7/6"
    36.5mm
    Operating Hose 1/2"
    10mm
    CFM @90psig* 48
    Square Drive 3/8"
    Tube Capacities 1"
    25.4mm
    Chucks** 3/8" QC incl.
    - I have Qty.2 brand new still in the original packaging Brilliant Abrasives bonded grinding wheels. Brilliant part #29091. Size: 10" DIA x 1-1/2" x 1-1/4" T1 A36-O-V. MAX R.P.M. 2483. $18 each
    Thanks for looking!
Size:  166.1 KBName:  IMG_3781.jpg
Size:  104.5 KBName:  IMG_3782.jpg
Size:  105.9 KBName:  Grinding Wheel 3.jpg
